Northwest AK, ID, OR, WA
Old 03-16-2013, 09:51 PM   #15
HATED1
HATED1's Avatar
Drives: 86
i saw it, sounds awesome! i def. can hear the rumble, would you say it sounds like the wrx's in person?
HATED1 is offline   Reply With Quote
Old 03-16-2013, 09:58 PM   #16
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Love it, Feels like a lot more low end torque/power, around town drive-ability is so much better. top end... meh still feels slow compared to my last 2 cars (supercharged 350z and r33 skyline)
This video is actually only audio :-P
http://i147.photobucket.com/albums/r...ps426ea536.mp4
also updated first post with youtube embedded
JesseE is offline   Reply With Quote
Old 03-16-2013, 10:00 PM   #17
Mickeyt86
Mickeyt86's Avatar
Drives: FR-S Asphalt M/T
Love it
Asphalt FR-S M/T Airaid intake/5Axis wing
Mickeyt86 is offline   Reply With Quote
Old 03-17-2013, 02:24 AM   #18
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Dayam! That sounds GREAT! I want!
Doing some research... official product page here:
http://www.borla.com/products/frs_br...rt__17284.html
$652.64 directly from Borla!?! Can you tell us if you found somewhere with a better deal?
Old 03-17-2013, 03:35 AM   #19
JesseE
JesseE's Avatar
Not sure how much its going to cost yet, hehe working it out with my distributor on what kind of discount I will get :-)
Old 03-17-2013, 03:40 AM   #20
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Do you have a Check engine light on? Or did you get a tune?
Old 03-17-2013, 03:56 AM   #21
JesseE
JesseE's Avatar
No tune, no check engine light yet... only been 7 miles...
The o2 sensor basically is a 0-1 v graph, and rear o2 sensor should be fairly steady because of how the inside of the cat converter chemically reacts to the fuel air mixture of the exhaust, as the exhaust passes through the cat the cat reacts, gets very very hot from the reaction, and then once the air has gone through the cat it will have a very steady oxygen reading. Basically if your rear o2 sensor is a pretty constant voltage, the computer assumes cat is working great. but when the cat is removed, or stops working because it gets coated with crap, the rear oxygen sensor, goes up and down just like the front o2 sensor, and that's how the computer understands the cat has failed.
So basically its just a matter of time when the computer see's constant rear oxygen sensor voltage jumping up and down and then decide when to set a code after a few trips of failure
Old 03-17-2013, 06:19 PM   #22
JesseE
JesseE's Avatar
and that time went by fast, lol cel came on on the way home from autox today
Old 03-17-2013, 06:42 PM   #23
Chen
Regional Moderator
Chen's Avatar
Drives: 13' ZN6 / 00' AP1 / 20' A90/ 15 EVO
How would you fix this?
Chen is offline   Reply With Quote
Old 03-17-2013, 06:50 PM   #24
norsamerican
Drives: WRB BRZ
Get it tuned
Old 03-17-2013, 07:14 PM   #25
JesseE
JesseE's Avatar
very easily actually, like ^ said you can get a tune and they can turn that stuff off, but other thing is you can get little o2 sensor extenders that make the o2 read off of a very small amount of exhaust gas and usually that will not set codes
Old 04-02-2013, 05:25 PM   #26
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
I've heard bad things about these exhaust extenders.
Have you noticed any performance degradation since the CEL popped up? I could live with a CEL as long as there are no issues. Not really wanting to get a tune if I don't have to.
Jaylyons1 is offline   Reply With Quote
Old 04-03-2013, 04:08 AM   #27
JesseE
JesseE's Avatar
There can be nothing bad about one... rear o2 sensor is only for monitoring cat... it will NOT affect performance in any way... front o2 sensor is what can affect performance... but that is not affected as its before where the cat would be anyway
Old 04-03-2013, 06:57 PM   #28
Goodguy889
Goodguy889's Avatar
Drives: Hyundai genesis 2.0t
I could be very wrong but I believe once the cel comes on the car goes into limp mode which dims down performance. I know on my car (genesis turbo) once the cel comes on it's in automatic limp mode which cuts off boost. I believe you will also run rich and get crappy mpg. I could be wrong though
Goodguy889 is offline   Reply With Quote
Search this Thread:
Advanced Search
Borla UEL Header, any dynos yet? FR-S Matt Engine, Exhaust, Transmission 111 05-16-2016 10:31 PM
Borla UEL Header - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 533 04-01-2015 01:10 AM
Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ RiskyTrousers Engine, Exhaust, Transmission 155 08-16-2013 10:05 PM
Borla cat-back w/ UEL header tested at the track BeltedBiscuit Engine, Exhaust, Transmission 17 12-30-2012 03:57 AM
