#379 | |
Drives: 2013 Scion FRS & 2022 GR86
Sent from my SM-G920I using Tapatalk
2013 Scion FRS 2022 Toyota GR86 |
#380 | |
Sent from my HTC6535LVW using Tapatalk |
| The Following User Says Thank You to MurderousPandas For This Useful Post: | Exrald (05-12-2017) |
#381 | |
#382 |
I did the left side standing in my dark driveway with my gf holding a flashlight, it took an hour because I dropped my socket but I fished it out.
No need to jack anything up or do anything crazy. Just remove what's in the way and get wrenching. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Exrald (05-12-2017), Icecreamtruk (05-12-2017) |
#383 | |
#384 |
Drives: 2014 frs
Coilpack went out at 58k, so I'll go ahead and do the spark plugs while I'm at it.
With regard to lifting the engine, the video does not mention anything about the steps in prepping the engine for being jacked up besides removing a couple of covers. Can anyone pinpoint the bare minimum that needs to be done to jack up the engine? Thanks in advance. |
#385 |
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I think the consensus here is that there is no need to jack or lift the engine. Just unbolt /remove stuff that's in the way to reach the coils/plugs.
Anyone feel free to correct me if I'm wrong as I'll be doing this in like a month 😬 Last edited by Kronos; 05-12-2017 at 05:37 PM. |
#386 | |
The most important part to me is patience. I was getting frusterated working in a tight space, made the job harder. Just take your time and be patient. One took me 20 minutes, smaller fingers would've been nice. Sent from my HTC6535LVW using Tapatalk |
| The Following User Says Thank You to MurderousPandas For This Useful Post: | Kronos (05-12-2017) |
#387 |
Drives: 2014 frs
I just did it today. While not completely necessary to unbolt the engine, IMO, you're making your life MUCH harder by not doing so. It is VERY easy to do. Unbolt the fuel line bracket, the HPFP heat sheild, and the strut bar, in addition to the two bolts on the bottom and just jack up the motor. It was really easy to do, and this is my first real DIY deal that I've done that involved this much work.
I will post a pic of my old spark plugs. My sister's FRS is approaching 60k miles so I will make a video tutorial when I do them. I was getting the p0351 code and after replacing the coil and all four plugs, the car runs WAY more smoothly. My old plugs did not look like they wore very evenly - stay tuned and I'll post pics tomorrow or something. |
| The Following User Says Thank You to PulpBrah For This Useful Post: | Exrald (05-14-2017) |
#388 | |
#389 |
Kouki-Monster
Am I correct to understand that there was a revision made to parts but no TSB or support from Toyota / Subaru?
Rich Anderson
EMPOWER AUTO |
#390 | |
I'm curious to know this as well. I'm also wondering how people are lifting their engines to access plugs and coils easier. I assume you need some special tool or jack to lift the engine up? Last edited by Kronos; 06-21-2017 at 09:32 PM. |
#391 |
Drives: FR-S Whiteout
FYI I just got the P0353 at about 43K miles. I changed out #1 coil at about 32K-ish? Just to confirm what we already know. The #1 and #3 coils on the right bank are weak points, so dont be too surprised when they need to be replaced.
Intent > Content
cowardice is the mother of cruelty. |
#392 |
I've gotten #1 and #2 a few times, will likely swap the coil packs this summer when I do the spark plugs for 60k.
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 06:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 06:29 PM |
