Old 08-10-2016, 01:05 PM   #337
Dipstik-sportech
Dipstik-sportech's Avatar
Just curious if anyone would be interested in an lq9 coil retrofit kit for our cars? It would mount them elsewhere to get them away from the heat by using a short plug wire. These coils are so strong using a wire would result in a negligible spark loss.
Old 08-13-2016, 01:35 AM   #338
s0sl0w
Proud of Boxer
Well I may as well add to this thread, OFT stage 1 93 Grimmspeed tune and ive been getting P0351 pretty consistently in the summer heat in 3rd 4th & 5th gear hard driving.
Has anyone had any luck with going to a heat range colder plug or is truly just a ambient heat issue thays killing the coils?
s0sl0w is offline   Reply With Quote
Old 08-13-2016, 09:45 AM   #339
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
My thoughts are because #1 fails more often than the others combined it's the heat. Especially if the factory header and heat shield are removed.
I've only had one fail (#1) and I wrapped the replacement with heat tape and have had no issues since including several summer track days.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
s0sl0w (08-14-2016)
Old 08-15-2016, 09:45 AM   #340
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I just had my first fail and I have the open flash header. No wrap. it's definitely from that plus my many spirited drives into the mountains.
Does anyone think an oil cooler will help prevent or slowdown these failures do to excessive heat?
Or maybe even E85 if you have a tune for it. I know E85 runs cooler. Just not sure if it's enough to make any difference.
Anyone have any other cooling ideas? I might get my header wrapped but I hear that accelerates the life of the header.
Kronos is offline   Reply With Quote
Old 08-15-2016, 11:07 PM   #341
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Wrap you shit. I had unwrapped headers kill coils in the past in my Saturn SC2.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Kronos (08-28-2016)
Old 08-16-2016, 08:04 AM   #342
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Only time I've got coil open error was in my Mustang after my dumbass sprayed the engine with a hose. There wasn't full contact but there wasn't no contact, so I got some dieletric grease and that fixed it.
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 09-14-2016, 01:01 AM   #343
df.dima
Drives: FR-S and Mazda 3 Sky
I got 0351 today 3rd gear. All stock, just axle-back, street driven, I only have 34k kms, so just under 22k miles - not impressed.
Code cleared after 3rd restart, as I was about to clear it with the scanner...
df.dima is offline   Reply With Quote
Old 09-16-2016, 05:48 PM   #344
Felix7007
Drives: Scion FR-S Black
Originally Posted by F1point4 View Post
FYI there is a 652 part number now. I've been using a pair in my car for several thousand miles and a pair of track events. Wrapped mine in gold tape.
http://www.ft86club.com/forums/showp...0&postcount=78
Just wrapped my coils. We will see...
Felix7007 is offline   Reply With Quote
Old 10-12-2016, 04:34 AM   #345
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
Wrapping the coils definitely helps.
As I track my car, I had repeated problems with those ignition coils and had to change them every 6 months.
However, I have wrapped those coils approx. a year ago; CEL did not come back. It seems it solves the problems, or at least decrease the frequency of failure.
vgarcin is offline   Reply With Quote
The Following User Says Thank You to vgarcin For This Useful Post:
xkalelx (11-09-2016)
Old 11-10-2016, 07:18 AM   #346
ajc209
Drives: GT86 Cosworth
Am I lucky? Cars done 13k miles and about 10 trackdays.
The first 5 trackdays were with a stock car, and a couple of those were hot days where oil hit around 140C.
No coil pack issue yet...
ajc209 is offline   Reply With Quote
Old 11-10-2016, 10:52 AM   #347
Icecreamtruk
Drives: Track preped NA FRS
I would say lucky or not as hot as you though it would be. If you have an unwrapped and uncoated header it makes it come on faster. I did around 10 track days with the car stock as well and never had one. Changed the whole exhaust system and did around 6 track days, and my first coilpack (A) poped. I changed it but didnt wrap them (my mistake) and it came back (same coilpack) after 4 more track days. Both times it poped was during very hot and humid days. I have since then wrapped them as best as I could without taking them out. If it pops again I`ll wrap it better with it out before putting it in (oh that phrase needs a context :P ).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
ajc209 (11-10-2016)
Old 11-27-2016, 05:15 PM   #348
kandiflippin
Just clarifying, it sounds like the best replacement for these is still OEM and then wrapping them? It doesnt sound like there has been a reliable replacement yet. Just got my first CEL for this after 2 seasons of autocross. Cars being built for STX but currently running header, ecutek, and running on 93 so nothing to crazy. The code was thrown when I was shifting from 2nd to 3rd at WOT.
kandiflippin is offline   Reply With Quote
Old 11-27-2016, 06:49 PM   #349
Kronos
Kronos's Avatar
Has anyone on here replaced the coils themselves? The coil itself is only like $80 but the dealer estimated like $300-$400 for labor. They said they would need to lift the engine out to replace the coil since its a boxer and the area they needed to access is on the side.
Seems a bit extreme, can anyone verify this?
I'd rather just do it myself, but not if I need to lift the engine.
Old 11-28-2016, 02:23 AM   #350
FT86RGV
I've replaced them all without having to lift the engine. Just takes a lot of patience. There was a good diy posted earlier in the thread for the harder coil to get. You would follow similar steps for all of them.
edit: just found it. page 15
FT86RGV is offline   Reply With Quote
Search this Thread:
Advanced Search
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 06:29 PM
