#323 | |
Drives: 2013 Firestorm FR-S
Guess I'll just be ordering one and changing it myself.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | ZionsWrath (05-24-2016) |
#324 | |
Thanks
It's an easy job, i needed to buy a 1/4" flex head ratchet to fit in the space to change it.
#325 | |
Road-hole
Drives: 2013 Whiteout FR-S
depends which one as to how easy it is to replace.
Considering I'm now replacing my engine, I'm going to make sure I replace all the spark plugs and everything's good before I put the used engine I got in. Then I get to break apart my old engine and start the build up for some serious power. ![]() I lucked out on this used engine $2500 with 35K no core charge... compression test came out 225 on all 4 cylinders... Jaden |
#326 | |
Thanks
#327 | |
Road-hole
you couldn't?
Jaden |
#328 |
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I've threw a p0353 code at least 4 times over the past two months. I think it's time to buy some ignition coils.
Just a quick question for all who have already been through the process. I'm looking online and I'm seeing prices ranging all over the place..How much should I actually be paying for one or a set of new coils? And have you guys been replacing your spark plugs too? Sent from my iPhone using Tapatalk |
#329 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Kronos (06-07-2016) |
#330 |
Thanks for the info
Found them here for a good price for any who is following this thread and needs some http://www.toyotaonlineparts.com/oe-toyota/su00304713 http://www.toyotaonlineparts.com/oe-toyota/su00304931 Sent from my iPhone using Tapatalk Last edited by Kronos; 06-07-2016 at 01:35 AM. |
| The Following User Says Thank You to Kronos For This Useful Post: | phrosty (12-01-2016) |
#331 |
Drives: FR-S Whiteout
Looks like my coil took a dump as well, and it happened while just driving normally on my way to a buddy's wedding. Say we replace the coil pack have any of you done any preventative measure to try to prolong the life of the coils? Heat shielding? What about these guys posted earlier in this thread? Are these more robust than the factory units?
http://www.okadaprojects.com/usa/products_direct.htm
Intent > Content
cowardice is the mother of cruelty. |
#332 | |
mate I think their was an update to the coil hardware that is better, but I did here that the later cars the actual plug on the coil pack changed, however their was updated coils available for the 2013 I believe the earlier part numbers are check with the parts supplier though all 4 coils same below are revised part numbers 22433AA652 22433AA651 22433AA650 |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (07-10-2016) |
#333 | |
Intent > Content
#334 | |
I believe so, but im not 100% as I have not had to replace one yet here seems to indicate they are revisions http://www.ebay.com/itm/SUBARU-OEM-1...-/121783750070 |
#335 | |
Drives: frs
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 06:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 06:29 PM |
