Old 02-13-2016, 08:39 PM   #295
Teseo
Drives: frs
Originally Posted by Bonburner View Post
Test: 450 miles of downshifting into 3 4 5 at 4-7.4k rpms
Results: not 1 CEL
Theory: after ignition coils get worn in and used a small amount of resistance builds up and our Stock batteries goes down the gutter too .. I don't think the coils went bad but just don't get enough juice at higher rpms.
What to do for prevention?
Old 02-13-2016, 10:06 PM   #296
Bonburner
Purchased 6/22/12
Bonburner's Avatar
I don't think there is any prevention of the resistance of the ignition coils .. it's bound to happen overtime .. unless there's a better aftermarket option
I'm assuming getting a better battery is going to be my method of dealing with it ...
The Following User Says Thank You to Bonburner For This Useful Post:
Teseo (02-13-2016)
Old 02-23-2016, 02:35 PM   #297
weepel
Dr. Fünke, Analrapist
weepel's Avatar
Drives: 2013 BRZ Limited, 2004 WRX STI
Originally Posted by smbstyle View Post
Took the car to @ and we wrapped the header, added a ground and went to 1 step colder plugs last Friday.
Then, at Sebring, we did some testing. Session 1 in the AM, ran for 15 minutes, no CEL. Session 3, mid-day around 1 PM, in the heat of the day, CEL came on towards the end of the session (~20 min in) for P0300 and P0302.
Then, we had the unique opportunity to test at NIGHT at Sebring, significantly cooler and making more power (shift points were noticeably sooner) and the CEL would "blink" on the long, high gear straights at high RPM, but no code would be thrown. We ran the car for about 1 hr 30 min with a 5 min break in the middle, with no code, so it does appear to be a heat issue, but need to find a better cooling solution.
Next step, maybe a CF vented hood?
Ran one day at Barber this past weekend (5 x 30 minute sessions and ~65F ambient) and had the same CEL blink during WOT on the back straight (coming out of turn 9). Fortunately all coils are okay (no codes on any yet) but another 86 owner (all stock) threw P0351 on his. I just ordered a spare coil to keep on hand and am too looking at a CF vented hood. I know @ATL_BRZ just installed the Velox vents on his hood - interested to see if it makes a difference for him.
2013 Subaru BRZ Limited
2004 Subaru WRX STI
My Garage, past and present
weepel is offline   Reply With Quote
The Following 2 Users Say Thank You to weepel For This Useful Post:
ATL BRZ (02-26-2016), smbstyle (03-02-2016)
Old 02-28-2016, 08:00 PM   #298
Bonburner
Purchased 6/22/12
Bonburner's Avatar
So my CEL for the same code came up while on the onramp that does a full circle going steady 6.5k rpm in 2nd :/
Old 03-21-2016, 10:00 PM   #299
phrosty
Blah, just got P0352.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-21-2016, 10:03 PM   #300
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
@phrosty what year is your Frs? Do you have any mods or a tune?
Edit: nvm I looked on your profile
What do you plan on doing? I'm considering bringing it to the dealer even tho I'm running oft stage 2 uel 91 tune.
I just got p0353. Coil pack on cylinder #3. Does anyone know if that's right?
Kronos is offline   Reply With Quote
Old 03-22-2016, 12:06 PM   #301
phrosty
I cleared the code, and got it again this morning when I went WOT. Interestingly enough, there was no misfire. I'm not sure if this is normal.
http://datazap.me/u/phrosty/cel-log2...zoom=8768-8865
Old 03-22-2016, 06:44 PM   #302
phrosty
FYI, I was quoted a little under $400 all-in to get it replaced by my local Subie dealer.
The Following User Says Thank You to phrosty For This Useful Post:
Kronos (03-22-2016)
Old 03-22-2016, 07:44 PM   #303
Kronos
Kronos's Avatar
Good to know. Thank you.
Yeah I didn't get any misfire either. It's the third time I've got the code in the last month and never a misfire, at least that I'm aware of. I'm assuming they are pretty noticeable when they occur
Old 03-25-2016, 03:55 PM   #304
phrosty
Had Subie replace coil B and problem is gone.
Kronos (03-25-2016)
Old 03-25-2016, 03:59 PM   #305
Kronos
Kronos's Avatar
Thanks for the update! Good to know. Seems to be a weak part in the engine due to heat from what I've been reading. It almost seems like we'll have to replace these every 30k miles or so if driven hard on a regular basis.
Edit: I'll update when I hear back from the dealer as well. I got the code P0353, supposedly coil pack on cylinder #3
Old 04-23-2016, 05:01 PM   #306
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
I've had the P0351 code for a while, letting it clear itself (3 drives method), or using my code reader for roughly the last 15k-25k miles (maybe more). In that time I've done about 7 or 8 track days, and strangely it has never come on at the track.
It seems that after driving for about 10-20 minutes, if I approach 6k or above it triggers it. I've got 52k miles on the car now, and am thinking to replace spark plugs soon. From what I've read, changing spark plugs and using the newer coils (part number ...652) should cure the code, correct? Any idea what, if any, damage I may have produced by continuing to drive the car with the code? As far as popping sound, I've never heard anything, but I did notice the car feels a little sluggish (might be a mental thing).
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
The Following User Says Thank You to mx5 2nr For This Useful Post:
Kronos (04-23-2016)
Old 04-24-2016, 12:54 AM   #307
zombieite
zombieite's Avatar
Drives: 2017 Limited Edition, manual
Thanks for all the info. Here's another data point for you. 2013 FRS, 28K miles, fully stock motor. I just did the Big Bend Open Road Race, hot day, 30 minutes at redline the whole time. The car was great, but at the end, it threw CEL P0351 Ignition Coil A and at the same time the stability control light came on for a second, even though I had it 5-second-full-off. It kept running fine and is still running fine. There was no popping sound. From the sounds of it I can put off fixing this for a couple weeks, I hope, since I am in the middle of a big road trip.
zombieite is offline   Reply With Quote
Old 04-24-2016, 07:33 AM   #308
toby714
Drives: whiteout
if someone made a head shield, i would be interested in buying one.
toby714 is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 06:29 PM
