| View Poll Results: Do Your Coilovers Knock? | |||
| Yes, and I have BC Racing Coilovers. |
41 | 44.09% |
| Yes, but I do not have BC Racing. |
13 | 13.98% |
| No. |
39 | 41.94% |
| Voters: 93. You may not vote on this poll | |||
#29 |
BoostedBRZ
Drives: Turbo BRZ
so is the general solution to tighten the top hat nut underneath the damping setting?
| The Following User Says Thank You to pgranberg11 For This Useful Post: | NickGTI32 (02-24-2015) |
#30 |
Drives: gt86 FIRST edition #86
Hi i write to you cuz i have the same issue from rear left coilover, i live in italy and i had buy my coilovers from UK...
After few controls BC decide to send to me 2 new rubber top mounts but i am afraid that not fix the problem, i have read who some people had fixed the issue with replacement of internal cartridge,do you know somebody who have fixed this problem with rubber top mounts? Please can you sent to me any documentation or the mail received from bc racing to talk with reseller for have the same treatment. There are some news? I copy here what bc racing have tell to reseller: "BC have replied to say that recently they modified the C-89 rear top mount so they will send a pair of these rubber rear top mounts for you to try to see if that eliminates the problem. They have said some people have confirmed the noise goes once replacing the .dampers with the new design. They have asked that you please try these and then confirm whether or not you still have the issue as they want to get to the bottom of it for you." |
#31 |
The Silver Shnerfer
Drives: 2013 SWP BRZ 6MT
Is there a way to tighten the rear bolt without taking the coil over off of the car?
#32 |
Lurker
Drives: '14 BRZ Ltd 6MT
Peel back your trunk lining, take a ratchet, and tighten it down. Just remove your dampening adjustment knob (if applicable)
Instagram : @brampbell_candon Facebook : Hipster Vision Photography |
| The Following User Says Thank You to shifter907 For This Useful Post: | NickGTI32 (02-26-2015) |
#34 |
Drives: 13 BRZ SSM
I had BC coilovers years ago on my WRX. They began knocking about three months into ownership.
Things to Check... Tighten Strut shaft top nut. Check the spherical strut mount bearing for wear. Check spring preload. 5mm preload on the spring seat is a good starting point. Check swaybar endlinks If none of these are your problem, try to recreate the noise by bouncing the car at the corner where the noise is. I eventually tracked the clunking to the struts and it was internal clunking from the shock/struts. They got progressively worse. In the end my BC coilover valving was shot and one more autocross finished all four struts. They ended up needing full replacement struts. I hope you guys have better luck with yours. Mine lasted about eight months. Rember this was when BC first was released in the US. I hope they have improved since then. |
| The Following User Says Thank You to turbocat For This Useful Post: | NickGTI32 (02-26-2015) |
#35 | |
The Silver Shnerfer
Any idea if they come out of the box with any preload? |
#36 |
Lurker
Some coilovers do, some don't. If you can spin the spring and all of the perches freely, there's no preload set, but I've heard of some manufacturers shipping their products pre-preloaded.
| The Following User Says Thank You to shifter907 For This Useful Post: | turbocat (02-27-2015) |
#37 |
bc racing have send to me new top mount but the noise continue... i have a question: have somebody tried with rear lower camber arms for fixing the problem?
#38 |
Drives: Subaru BRZ
hey guys, so i got bc coils about a month ago, i am getting like a squeaking sound in low speeds, and a knocking from the rear left wheel. any ideas?
#39 | |
What license?!
Drives: 2015 Scion FR-S
Im on Megan Street series.
#40 |
Drives: Subaru BRZ
#41 |
Drives: 2015 FRS
Hey, so I bought the bc extreme lows
And I'm getting hate mail out the ass saying they are the cheapest coils put on earth Can u guys give me some input |
#42 |
Drives: Scion F-RS 2013 Asphalt MT
Take off the dampening adjustment knob and tighten the top bolt. This fixed the clunking in my coils. Also if the preload is set too loose clunking might occur, try setting the preload to factory specs
| BC Racing coilovers help! | chuyjr85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 08-27-2015 11:01 PM |
| GI: BC Racing Coilovers | RavenFR-S | Brakes, Suspension, Chassis | 13 | 02-07-2013 11:53 AM |
| BC Racing Coilovers | Dustin@Dynosty | Brakes, Suspension, Chassis | 5 | 01-27-2013 03:36 PM |
| BC Racing BR Coilovers | Blaster | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 07-22-2012 07:11 AM |
