Old 12-11-2013, 04:49 PM   #57
Ryan@Nameless
Ryan@Nameless's Avatar
Drives: 2014 SWP BRZ Limited
If you plan on getting a header in the future, I would add it. It will be cheaper to do it now in the long run than to have to try and add it later. It is also a fairly inexpensive addition at $65.
-Ryan @ Nameless
Ryan@Nameless is offline   Reply With Quote
Old 12-11-2013, 05:09 PM   #58
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
-Ryan @ Nameless
and how long to make and ship out wight the resonator and non resonated?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 12-11-2013, 05:18 PM   #59
Ryan@Nameless
Got your PM.
Our lead time right now is right around 3-4 weeks for fabrication, seeing as we build almost every single part to order here in our tiny shop in La Center, WA.
The helmholtz resonator has no impact on the lead time, however.
-Ryan @ Nameless
Old 12-11-2013, 05:22 PM   #60
ScionFR-S
ScionFR-S's Avatar
Got your PM.
-Ryan @ Nameless
okay perfect then ill just go with the helmholtz just to play it safe
Old 12-13-2013, 09:34 PM   #61
Pen.suhl
Drives: 2013 WRB BRZ Limited
-Ryan @ Nameless
Hey, thanks again about adding the resonator onto my downpipe today. Hope I didn't cause too many issues.
Pen.suhl is offline   Reply With Quote
The Following User Says Thank You to Pen.suhl For This Useful Post:
Ryan@Nameless (12-14-2013)
Old 12-14-2013, 11:28 AM   #62
Ryan@Nameless
No problem, we caught it at the perfect time
-Ryan @ Nameless
Old 12-14-2013, 12:21 PM   #63
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
pumped to get my fp/dp combo. gonna put it on with the revworks header sitting here. have to wait till the snow clears though....
cruizin01 is offline   Reply With Quote
Old 12-16-2013, 01:03 PM   #64
ARK Performance
ARK Performance's Avatar
Drives: Subaru BRZ
We are speaking about ours specifically, because we go for thicker piping and different design ours is meant for manual transmission, we designed it originally on a manual transmission first and did not produce an automatic transmission one. Not quoting all helmholtz designs in general just to clarify.
Interesting.
We had no problems designing one that fit both an Automatic and Manual transmission.
The Helmholtz resonator is specifically designed to target a drone frequency that we experienced with a header installed. A big contributor to rasp in the exhaust is removing the cats from the system, and has little/nothing to do with the Helmholtz resonator.
All of our initial testing was done with no tuning applied to the parts. Sorry to hear about your troubles, but I am happy to hear that the car drives well now. It would be interesting to see datalogs/dyno graphs of the car with the tune and without the tune.
-Ryan @ Nameless
ARK Performance is offline   Reply With Quote
Old 12-17-2013, 03:25 AM   #65
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Why is the catted Nameless DP listed as "OFF-ROAD only"?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 12-17-2013, 03:46 AM   #66
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Because our communist overlords have deemed it illegal to tamper with any emissions equipment on automobiles.
So barring a failure you can't "legally" remove or replace cats.
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
Ryan@Nameless (12-17-2013)
Old 12-28-2013, 09:09 PM   #67
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Would the catless op/dp with the helmholtz be raspy? I don't mind a little volume but cannot deal with the pissed off bumblebee sound.
As far as emissions are concerned...screw the overlords.
shaunsweeney is offline   Reply With Quote
The Following User Says Thank You to shaunsweeney For This Useful Post:
tbertran (12-28-2013)
Old 08-28-2016, 01:47 AM   #68
Sgtfluffy16
Drives: White BRZ Limited
I have an equal length header, a nonresonated/non catted front pipe, an overpipe, and a q300 catback. Since I went forced induction my car obviously became really loud. I'm trying to quiet the car down. I don't really have any rasp, but it's too loud. Without doing a catalytic converter would your Helmholtz resonater quiet the car down?
Sgtfluffy16 is offline   Reply With Quote
Search this Thread:
Advanced Search
Will Helmholtz resonator decrease power? shu5892001 Engine, Exhaust, Transmission 31 01-07-2015 10:37 AM
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 02:40 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 08:24 PM
Ordering Nameless Exhaust - Helmholtz Resonator?? Umbie Engine, Exhaust, Transmission 16 12-03-2012 02:48 PM
