Old 12-01-2013, 09:03 PM   #29
jamesm
Originally Posted by Sportsguy83 View Post
I would like to see this
i am in the process of writing one up using yikes' spreadsheet... it's really pretty simple though a monkey could do it (if said monkey had opposable thumbs and could open excel).
you can just use the yike's spreadsheet instructions as a guide. the key difference being that 'af/cor #1' is STFT, and 'af learn #1' is LTFT, and pre-filter your log for fuel system status 2... 4 is open loop. then in yike's spreadsheet, just prefill all the columns with 'CL' in the 'CL/OL' column so the filtering will still work. then just paste in all the values (including your maf table), click 'filter', then 'plot maf changes', apply them, log again and repeat.
using this method a few times got me from +/-20% LTFT to +/-2%... so it works.
The Following 3 Users Say Thank You to jamesm For This Useful Post:
PantsDants (04-15-2014), s2d4 (03-08-2014), Sportsguy83 (12-01-2013)
Old 10-27-2014, 05:15 PM   #30
diodelphi
diodelphi's Avatar
Drives: 86
thanks all
useful information
diodelphi is offline   Reply With Quote
Old 08-06-2015, 12:47 AM   #31
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Is there any value in simply making CL AFR's follow OL within a couple of points?
Downsides besides economy? Will it effect LTFT learning?
Old 08-06-2015, 03:59 AM   #32
Kodename47
Kodename47's Avatar
Drives: UK GT86
IIRC if you set it all to 14.7 (0 in Romraider) then you effectively switch off LTFT. There's no point in setting it below 14.0 as you'll be in open loop, that's if your minimum open loop enrichment is set to 14.0 as it is stock. Mine is a mirror of my OL fuel map, one of my spreadsheets generates this for you.
I guess delays play a part, I've set all mine to 0 to ensure it switches to open loop if the fuel map dictates less than 14.0, however if you have the standard delays then it may be worth allowing values down to 13.5 (-1.2) so that the CL tries to richen up a little. I'm not sure how well that works though as I've not tested it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-06-2015, 04:14 AM   #33
Wayno
Wayno's Avatar
Ok, it's good to know someone else has made CL mirror OL.
I can think of one reason why the delay is there - so that the ecu can learn the highest bracket ltft.
I limited CL to 12.5, not that it will likely ever hit those cells.
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 02:15 PM
i've been out of the loop! VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 0 02-16-2013 12:25 AM
Injen installed, open/closed hood dynoed Bahraini86 Engine, Exhaust, Transmission 55 02-15-2013 12:24 AM
Carbon fiber trims/skinning - gauging interest Hawk77FT AUSTRALIA 37 01-20-2013 08:35 PM
Who was on the 202 loop SMOKETREES Southwest 5 09-15-2012 12:31 AM
