#15 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Whether the filter is magical or not, it would be interesting to see Dyno runs of other DIF, before anyone makes an assumption that other filters are better.
Must take note that the ECU does take a good 20 to 40km to self adjust to the driving conditions you push the car too. (There is a thread confirming this as I am not technically qualified) I have seen dyno tests done on various DiF, complete new intakes, UniChip, exhaust replacements and yet to find anymore gains than what this Works filter has shown. If there is better, it would be nice to share with back up dyno charts. |
#16 |
Drives: Skoda Yeti DSG diesel 4x4
The independant dyno chart showed a net loss for the Works filter, not a gain. It made the torque dip deeper and longer with more loss there than the top end gain.
#17 |
Drives: Red high Spec 86
Hi Ryan
I see your reg is nu>>>i am from the same area...Wyebank..kloof...We must hook up..i have installed an aftermarket filter as well...jr or something from speedshop in kzn...they say it is as good as k&N.my MR2 tuner recommended..said they used on skyline gtr's so i figured worth a try... |
#18 |
car seems slightly better in the lower rpm..but my performnce app in the car still records 0-100 in 7.4 and 1/4 mile at 15.4 so not too sure about gains...
gonna look at a dyno test soon but the tuner i use has issue wid his dyno...might attend the one coming up this weekend... |
#19 |
Road Warrior
Think I passed you this morning by Hillcrest Toyota 0740 odd.
#20 |
Drives: Toyota 86 Auto Satin Pearl White
I just couldn't resist
| The Following User Says Thank You to NamSin For This Useful Post: | projectXTR (03-11-2013) |
#21 |
Just dynoed 118kw in 3 and 121 in 4 190 nm. Car has filter.mAke is rj or jr
#22 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Impressive. And with the OEM filter?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#23 |
Drives: Toyota 86 M High - Dark Grey
anyone dyno'd the SA BRZs yet to see what power they put out with their custom exhaust?
#24 | |
Road Warrior
I ran a stock run with old SW and got 115wkw, I installed the Works Filter and got 118wkw 2 days later I fitted the zorst and while doing so Toyota happened to do the SW upgrade and verified with the new zorst all engine ECU readings were correct. Went straight down to dyno and got 119wkw. My test cant be deemed 100% accurate as I had the SW change, which may have dropped the total power. however IMO the exhaust did nothing to help the mid dip and may give 1 to 3 wkw. That being said, the sound is 10 times better and certainly makes the car sound like a sports car. would be interesting if someone did a before and after test to see if it does do anything.
| The Following User Says Thank You to Ryan86 For This Useful Post: | Vladror (11-11-2013) |
#25 |
thanks Ryan
just subjectively, i think the mid dip is a lot less noticeable after i installed the zorst. I still got the stock air filter, you reckon i should replace it to get the best out of the exhaust? |
#26 |
Road Warrior
Definitely recommend getting DIF, got most gains from changing the filter and cheapest gains.
K&N is available in SA. |
| Works panel filter independant dyno test results | sierra | Engine, Exhaust, Transmission | 24 | 08-16-2013 03:43 AM |
| WORKS Resonated AB and Drop in filter | phenom86 | Engine, Exhaust, Transmission | 90 | 02-28-2013 09:44 PM |
| What happened to the Works drop-in air filter thread??? | zoomzoomers | Engine, Exhaust, Transmission | 85 | 02-28-2013 05:17 PM |
| WORKS High-Flow Drop-In Filter ~ +10 HP Gains | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 354 | 02-26-2013 09:37 PM |
| WORKS Resonated AB and Drop in filter | phenom86 | Southern California | 21 | 11-05-2012 01:27 AM |
