Old 03-26-2013, 06:50 PM   #169
BRZranger
I'm curious as to how the handling feels with a very aggressive offset vs near stock offset. I'd assume since you're pushing the wheels out about 40mm on each side, the steering might feel "heavier". What is the weight of wheels and tires?
Throw those forgestars on now and take some pictures please! :-P
BRZranger is offline   Reply With Quote
Old 03-26-2013, 07:07 PM   #170
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
The steering feels more stable and planted. It makes the car feel wider, which makes sense since it has the widebody and *IS* wider. It does feel a little bit heavy but not too much. Steering feels comparable to my 06 WRX. I like the feeling a lot better though. I feel like I can stand my ground in any turn better than before and just all around more confident in cornering. It'll be a blast to see what these wheels feel like once they're on. Performance-wise the rota's with the spacers have felt amazing.
VesperLynn is offline   Reply With Quote
The Following 2 Users Say Thank You to VesperLynn For This Useful Post:
BRZranger (03-26-2013), ftc~brz (03-26-2013)
Old 03-26-2013, 07:21 PM   #171
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
yeah now im just waiting on my FS's. saying they'll be at the house next week, but im thinking 2 more weeks minimum. but then again, I wont be home till mid june to start my frs
Joeprelude is offline   Reply With Quote
Old 03-26-2013, 07:49 PM   #172
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Just don't plan on anything until you get those tracking numbers.
Old 03-27-2013, 01:54 AM   #173
RWDRIFT
Drives: 2013 Hot Lava
Originally Posted by VesperLynn View Post
Yes, yes I am! They're on they're way in today. Got tracking numbers last week and they're out for delivery. . As for suspension I have bc br coils, whiteline sway bars and endlinks, cusco bracing and will be getting cusco control arms. Tire for the 19's are going to be a Michelin pilot a/s plus 255/35/R19 in the front and a 275/35/R19 in the rear. Am thinking about getting a separate set of wheels+tires for track use.
I hope you don't run those michelin tires. That is the wrong size and wrong rolling diameter for the scion FRS. You might destroy your widebody fenders with that tire.
you need
255/30/19 front
275/30/19 rear
RWDRIFT is offline   Reply With Quote
Old 03-27-2013, 02:04 AM   #174
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
you need
255/30/19 front
275/30/19 rear
Don't worry. We realized that this is definitely the wrong tire to use. We're getting the exact same tire you're using. It's coming out of Reno so it'll be a few days, but from what I've heard from you're experience. They should work perfect. Only rubbing issue was in the side skirt correct?
Old 03-27-2013, 05:59 PM   #175
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
UPDATE: tires should be here by the end of the week. New tires have a diameter of 25". Hopefully they'll fit no worries. Can't wait to mount them.
The Following User Says Thank You to VesperLynn For This Useful Post:
NorseLegend (03-27-2013)
Old 03-27-2013, 06:34 PM   #176
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
Originally Posted by shu5892001 View Post
I would recommend 255 or 265/30/19 for front
terrible idea... the rotating diameter would be too large for even the rear...
im running a 235/35/19 and that was a lot of work...
ideally a 255/30/19 should be 625mm diameter which is perfect for the kit....
i will be stepping down to 17s in the coming months and doing an entirely new set up...
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
The Following User Says Thank You to staycrushing For This Useful Post:
6-Shift (03-28-2013)
Old 03-27-2013, 11:23 PM   #177
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Finally got the Perrin over pipe in. Much quieter without the exhaust leak and sounds amazing. The HKS is more lively with the catless pipe.
Old 03-29-2013, 10:00 PM   #178
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Got some new wheels on! Working on making them fit with absolutely no rub issues lock-to-lock. But they look amazing... More pictures to follow.
The Following 8 Users Say Thank You to VesperLynn For This Useful Post:
6-Shift (03-29-2013), fender9530 (03-29-2013), hmong337 (09-01-2014), Joveen (01-27-2019), Meehow86 (04-10-2013), NorseLegend (03-29-2013), Re~Mix (03-29-2013), SkAsphalt (04-01-2013)
Old 03-30-2013, 01:06 PM   #179
phatpanda
phatpanda's Avatar
Drives: Scion FR-S
So.. 295/30/19 in the rear and 265/35/19 front is no good..?
phatpanda is offline   Reply With Quote
Old 03-30-2013, 01:26 PM   #180
SnapOv3st3r
Drives: 400whp Scion tC
Looks good. More Low.
SnapOv3st3r is offline   Reply With Quote
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
Murseman27 (03-30-2013)
Old 03-30-2013, 09:23 PM   #181
Joeprelude
Joeprelude's Avatar
It looking good. What Suspension/Coilovers are you running/gonna run?
Old 03-30-2013, 09:34 PM   #182
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Currently I'm on stock struts with eibach pro-kit lowering springs. Installed white line front and rear end links and sway bars today. BC BR coils are going on as soon as I get them back.
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 12:34 PM
Firestorm/black project build deedz Member's Car Journals 47 11-19-2012 05:06 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
