#43 |
Drives: Subaru BRZ
Hi, everyone.
Thanks for all your help getting me back onto the forum. It is appreciated. Hope you are all enjoying the armrests. Please no armrest business conducted here. I wish that they had gone with black screws also. I wonder if we could find some black caps to fit? jpit Last edited by jpit; 03-06-2013 at 08:52 PM. |
| The Following 18 Users Say Thank You to jpit For This Useful Post: | avusblue (03-08-2013), ChiefG (12-11-2013), civicdrivr (03-07-2013), Grimlock (03-06-2013), husker741 (03-06-2013), lbroskee (03-06-2013), Lonewolf (03-07-2013), lordtakuban (03-08-2013), microbionic (03-06-2013), MrAmalto (10-04-2013), newports (06-28-2013), raul (03-19-2013), Skippman (03-08-2013), spgrizz22 (03-06-2013), Subie (03-07-2013), The Slow One (03-08-2013), TouchMyHonda (03-27-2013), zzabbas (03-08-2013) |
#44 | |
Drives: Scion FR-S
#45 | |
![]() I told you we'd get you back. |
#46 |
Drives: Subaru BRZ
A couple of members asked me to repost some observations when installing the armrest. Here are the Toyota instructions:
http://www.toyota-tech.eu/aimuploads..._002_827_0.pdf Here are some observations: use the template but drill with a very small drill bit because you will probably be off a little (no need to start right off with the 5mm bit). You can use 13/64" for the 5mm and and 5/16" for the 8mm. I drilled the passenger side first because that is where the tabs fit into the center console. The holes to be drilled on that side are in a straight line so you can tell if you are off. You can put the armrest on its side and line up the tabs and holes to get a good idea how things are going. After the 8mm holes (and remember two holes stay at 5mm)are drilled on that side, put the armrest in and see how it fits. When you are happy with the fit use an awl or sharp nail to mark where all the other holes are to be drilled. I drilled both a 5mm and 8mm hole into a thin piece of metal that I had and held that over the scratch marks so the drill bit didn't walk. If you drilling is off a little remember that all the holes are hidden by the foundation. If the 5mm holes are off a little use a guide to help drill the 8mm holes. You don't want to make those holes too big or the rubber torx thing won't have any place to grab. There are two holes which are a little ackward to get to (marked with arrows). I didn't need to remove the upper piece as I used a thin torx driver and put a piece of tape along the edge of the lid to prevent marking. When tightening the torx bolts do not put any tension on the plastic foundation or the top might not close properly. Also, the color matches much better than the photo indicates. Also, contrary to an earlier post I actually keep my BRZ very clean. Because it is my DD I have no qualms about taking my Golder Retriever along with me. Last edited by jpit; 03-07-2013 at 03:24 AM. |
| The Following 11 Users Say Thank You to jpit For This Useful Post: | Alfalasy (11-09-2014), avusblue (03-08-2013), BRZranger (03-07-2013), ChiefG (12-09-2013), HyperTech (06-27-2014), JPxM0Dz (06-24-2013), mikochu (08-14-2013), Screw Loose Dan (12-05-2013), SeanBlader (12-09-2013), soundman98 (02-15-2014), Sportsguy83 (03-07-2013) |
#47 | |
Drives: 2023 WRB BRZ (MT)
| The Following User Says Thank You to lbroskee For This Useful Post: |
#48 |
Drives: Ultramarine FR-S 6MT
Jeff, good to see you back!
Jacob |
#49 |
Drives: Subaru BRZ
#50 |
#51 |
I Love custom Turbo kits
Drives: Limited BRZ
#52 |
Drives: Hot Lava 86 MT
I want one!!
This is exactly what I have been looking for. Jpit, sent you an email. Need shipping to the UAE. Thanks RevoG
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
#53 |
Drives: Scion FRS Ht Lva(AT)
#54 |
Default User Title
#55 |
PROUD OF BOXER
Drives: Raven FR-S
Me either and I was the one promising pics installed
#56 |
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Jpit
I am very interested in this arm rest. If you're ever gonna set up another group buy or if I can get in on this please let me know! And glad to see you're back on the forum, they should never have banned you just for trying to help out some fellow members!
![]() 2013 FRS 6AT in Raven! |
| Tags |
| armrest, jpit |
| Carsmo Armrest - Short review and quick pics | Bleevin | CANADA | 3 | 09-27-2014 01:21 PM |
| new armrest | Derrick | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-24-2014 11:48 PM |
| 86 Armrest | CzechZA | AFRICA | 30 | 02-05-2013 07:44 AM |
| armrest!!! | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-07-2012 04:16 PM |
