Old 03-02-2013, 05:08 AM   #15
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Originally Posted by Mandy View Post
I keep all my spirited driving to back roads; fortunately there are no ditches near where I live.
Ha I go to historic highway, unfortunately it's a down hill pass so one side is a stone wall and the other side is a cliff, no room for error, but so much fun.
FRSfan111 is offline   Reply With Quote
Old 03-02-2013, 08:54 AM   #16
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Actually I was lucky I didn't end up across the street! Name:  ImageUploadedByTapatalk1362228847.160112.jpg
I'll be back!!
F3dzo is offline   Reply With Quote
Old 03-02-2013, 10:37 AM   #17
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Be careful! Great way to twist your chassis. Can't count how many times I've seen someone do that only to end up with warped and misaligned panels and lumpy rooflines.
CircuitJerk is offline   Reply With Quote
Old 03-02-2013, 11:18 AM   #18
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Ouch! I'm glad that you only had some cosmetic damage.
Did you have the traction control and VSC on or off?
Even when these are "off" there is still some intrusive control. In my experience, the result of this is that the car will appear to be gripping fine and stable for longer than is really good, because the tires can only do so much. When the limit of adhesion is exceeded with any driver aid still active in this car, the change is abrupt resulting in a spin or off road excursion. In my experience, it does not seem possible to approach the limit with driver's aids active and still have some control.
I you think this may have been a problem for you, try using the pedal dance next time:
http://www.ft86club.com/forums/showt...ht=Pedal+dance
The downside of this is that it requires a cautious approach and some time and patience to develop the necessary car control skills. With all of the driver's aids (except anti-lock brakes) removed, you are on your own to control the car in any slip/skid situation. Once skills are developed though, the car is more controllable at the limit after the pedal dance has been applied.
A last word of caution: public roads are so variable that surprises can happen no matter what you do or how good you are. I was driving behind another car on a twisty public road, and even though I was well within my cars limits I almost spun. Why? Because the car ahead of me dipped a wheel off the edge of the road (I didn't see it happen) which spread loose gravel on the curve which almost totally eliminated any traction. If you can, get to a track where the surface is more consistent and there is often times generous run off areas if something does go wrong.
The Following User Says Thank You to Black Tire For This Useful Post:
kwood9000 (03-02-2013)
Old 03-02-2013, 11:34 AM   #19
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
looks more FIA rallye than drift!
Huehuecoyotl is offline   Reply With Quote
Old 03-02-2013, 12:33 PM   #20
F3dzo
F3dzo's Avatar
How can I check??? Body shop??
I'll be back!!
Old 03-02-2013, 12:35 PM   #21
F3dzo
F3dzo's Avatar
This experience actually woke more interest in learn to control my car in unexpected circumstances. The aids were off by the way. So it's a lot of grey area
I'll be back!!
Old 03-02-2013, 01:55 PM   #22
CircuitJerk
Pull my finger...
If it's not noticeable, then you're probably okay.
Signs are uneven fender gaps but you have to have a good recollection of what they looked like from the start.
The roof can be a good indicator. If there are ripples, or dents, it can be in indication that an excessive amount of stress was applied.
Old 03-03-2013, 02:47 PM   #23
lazyluka
Drives: GT86
Am I doing it right?
[ame]http://youtu.be/ugQjtjTaVYA[/ame]
lazyluka is offline   Reply With Quote
Old 03-03-2013, 03:03 PM   #24
BRZnut
Drives: BRZ DGM Limited
Why would you do that?? All the dirt/rocks can't be good!!
Old 03-03-2013, 03:05 PM   #25
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I had an experience much like this recently. I took the car and my son to a parking lot for a couple power slides, left to head home. We left from a side road to the empty, wet, expressway, and quickly realized the traction control was still off. Well, needless to say the car got a bit sideways, headed towards the shoulder, and right into the grass on the other side. Fortunately I was able to keep up my momentum because the grass was super wet and the ground was really soft. After a lot of sliding around and tire spinning we got back to the road and went about our business with the traction control on. As soon as we hit the road surface I hear from the back seat THAT! WAS! AWESOME!!!!! Crazy kid, I'm up front worrying and he's having a blast. The only damage was dirty wheels and some grass stuck in the wheelwells and on the diff.
Cade01 is offline   Reply With Quote
The Following User Says Thank You to Cade01 For This Useful Post:
F3dzo (03-03-2013)
Old 03-04-2013, 03:16 PM   #26
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
wet blacktop parking lots>>>>>>>>>
Obja is offline   Reply With Quote
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 08:36 PM
What's wrong with the glass? mashal Scion FR-S / Toyota 86 GT86 General Forum 31 08-23-2012 04:05 AM
am I doing something wrong? shiud Scion FR-S / Toyota 86 GT86 General Forum 20 07-17-2012 06:21 PM
Was I in the wrong? D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 18 06-15-2012 02:46 AM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 07:08 PM
