Old 03-01-2013, 10:00 AM   #29
JC86
Drives: Whiteout FRS MT
Originally Posted by l0aded View Post
that is kind of my budget too. heres a break down of what i've done and what im planning to finish with.
- tint (150)
- unichip (375)
- Armrest (90)
- Exhaust (550)
- Intake (260)
- Opticoat and full detail (400)
- Car Washing supplies for a long time (150)
- OEM Audio+ System 400 sound (950)
- HID lights and HID DRL and LED trunk and license plate light (75)
- VG Sharkfin antenna (75)
- boxer License Plate (20)
- Toyota badges blacked out front and back (55)
3150 total
in the future i may get:
- JDM clear corners (90)
- JDM frameless mirror (100)
- GT86 headlamps (lol i wish)
- cooler taillamps (400)
- rims (1500)
I was looking into getting that OEM Audio+ System 400 how does it sound? Does it produce good enough low end with an 8" sub?
JC86 is offline   Reply With Quote
Old 03-01-2013, 10:14 AM   #30
whaap
whaap's Avatar
Originally Posted by chenshuo View Post
you can buy 7 shares of Apple stock and feel good about being an Apple stock holder.
Not bad advice. If you invested wisely and had just a little luck on your side that could end up becoming more than just your nest egg. If you retired in 40 years it could be worth somewhere around 250K.
whaap is offline   Reply With Quote
Old 03-01-2013, 10:15 AM   #31
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by raul View Post
You still get a blurry cutoff, and you kill some of your peripheral lighting, so road signs and small debris or animals on the side of the road will not be easy to see.
Here's some good examples. http://www.ej8squad.com/thread-13685.html
I have still found the lighting from HID far superior to halogen. The only detectable difference with 6000K and the squirrel finder bent is the very outer periphery isnt as good as with proper projectors. This area is not illuminated with the halogen lighting pattern. . The main field of view is way brighter and the cutoff on mine is not blurry at all.
Old 03-01-2013, 11:11 AM   #32
bdub85
bdub85's Avatar
Drives: 2013 Raven FR-S
Originally Posted by Frost View Post
If you bought the car on financing, throw it towards your principal on the loan.
If you have a mortgage, throw it towards the mortgage.
If you have neither loans above...
1- Tires + wheels
2- Advanced driver school
3- Helmet
4- Track day entry fees
5- Maintenance costs
bdub85 is offline   Reply With Quote
Old 03-01-2013, 11:14 AM   #33
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
A quality set of rims and a set of coils. The car looks great as it is lines wise and dropping with quality wheels would set it off perfect.
jadewbj is offline   Reply With Quote
Old 03-01-2013, 11:23 AM   #34
NOHOME
Drives: RAVEN
If the car is financed, pay down the loan.
If it is not financed, put it in the savings fund for the next car you will need.
If 3k is just pocket change to you, then go nuts and buy whatever it is that you want. How the heck do you expect some random group of people to know what floats your boat?
Here is one option if you really need to stand out...
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
strat61caster (03-01-2013)
Old 03-01-2013, 11:23 AM   #35
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Not blurry relative to what? Standard halogens? Park your car next to one with real HID projectors and you'll see how blurry it is.
raul is offline   Reply With Quote
Old 03-01-2013, 11:32 AM   #36
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Borrow a helmet.. and spend a small amount on a track/DE day an THEN decide. Would be such a waste to make the car a stance/ricer mobile if you haven't made a proper decision to use what the car was intended for.
Then buy:
- FT86factory/Cusco strut front tower strut brace(whatevers cheapest)
- 2nd hand 5x100 +42/47 offset wheels(with good tread remaining if you can) ideally LIGHT WEIGHT ones - possbily 45-60lbs weight loss
- Voodoo/Flossy gear knob(huge impact on your driving experience right there)
- Whiteline Positive Shift Kit(KDT926)/CUSCO Transmission brace - for racecar sounds/vibration
- Whiteline rear cross member bushings(KDT922) - for that nice tight rear end
- Borla or any cheap UEL or even EL headers(huge diff right there)
- Invidia/Perrin/SRT.. whatevers CHEAPEST(and lightest) CBE exhaust
- Remove spare wheel - 40lbs weight loss
- DEKA EXT14 battery - 19lbs weight loss
- RCE Yellows or any other decent lowering springs
- Perrin shifter mount
- Scanguage for oil/water temps, etc
- Change your oil to something DECENT(if you already haven't)
- Change your tran/diff oil too(your car will love you for it)
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 03-01-2013, 11:36 AM   #37
Clint520
Clint520's Avatar
Drives: GBS BRZ AT
Unless you plan on changing your bumper in the future, you should think about installing a clear bra. It's definitely preference, but I can't stand the look of chips peppered all over the front lol. You might not see any now but it's only a matter of time.
Clint520 is offline   Reply With Quote
Old 03-01-2013, 01:05 PM   #38
wbradley
Sarcastic SOB
wbradley's Avatar
Relative to factory HIDs, halogens, etc.. The cutoff is quite sharp. Am I that tough to understand?
Unfortunately it's not so sharp with my xB though, there is a little "hump" over each side, presumably because there is no squirrel finder to bend and the HID tube emits light different than a filament, resulting in some unwanted reflections off the halogen reflector. It's not so bad that it's unacceptable though, at least for me.
Old 03-01-2013, 01:07 PM   #39
raul
Lap time enthusiast
raul's Avatar
I guess so. I'm just incredibly annoyed when I get blinded by HID kids, flash at them, only to find they're using their low beams.
The Following User Says Thank You to raul For This Useful Post:
Old 03-01-2013, 01:25 PM   #40
husker741
Which goes back to my original statement, buy a good set of HIDs like what I got from HID Powerhouse. Not some crappy stuff from autozone that is universal.
husker741 is offline   Reply With Quote
Old 03-01-2013, 02:23 PM   #41
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I actually haven't gotten it yet. It's in my very near future. Theres a review by someone on the forum in the sound/navi sub forum though. Just about everyone says its a great deal for sound and good fit and you will only be disappointed if you want extremely heavy bass. Sound quality wise I hear its top tier.
l0aded is offline   Reply With Quote
Old 03-01-2013, 03:21 PM   #42
JC86
Oh alright cool yeah I don't need too much just low end just what is missing with the stock speaker setup.
What shocks would you recommend? CaptainSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-31-2013 02:18 PM
What should I spend my money on sf86 Scion FR-S / Toyota 86 GT86 General Forum 49 11-28-2012 05:34 PM
Got $450 to spend, what should I buy? PMok Cosmetic Modification (Interior/Exterior/Lighting) 23 10-17-2012 12:57 PM
Please be aware where you spend your money KronosPerformance User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-28-2012 09:28 AM
5000 to spend on what? MtnDrvr86 Other Vehicles & General Automotive Discussions 29 03-18-2010 05:10 PM
