Old 04-14-2013, 11:22 PM   #379
tg_1981
Originally Posted by F1point4 View Post
Did a long distance drive today.
247.6 mi
83F on the car thermometer.
Clear skies with sun beating on pavement
Average speed 85-90. Did 100 a few times
8.2 gallons of fuel used (thanks Torque app)
Oil temp read 240F
Map 3
30.2 mpg!!!! Can have FI and cake too!
Has the car shut off on you when switched into map 3? I was sitting at a stop light today and decided i wanted to do a little spirited driving switched the map to 3 and bam every light on my dash went off and car turned off.
Car started back up fine. So i tried switching it to map 3 again no problem this time. I get to a light and the idle drops below 700 and almost stalls. So I went back to map 1 and drove it home cautiously. Has anything like this happen to you guys?
tg_1981 is offline   Reply With Quote
Old 04-14-2013, 11:26 PM   #380
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Never. Which version tune are you running?
I'm always on map 3 because I enjoy the auto blip.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
Old 04-14-2013, 11:32 PM   #381
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I make it a habit to drive in map 3 only. Actually over this weekend I was driving home from dinner. I was slowing down to a stop to make a left turn. Right before I stopped the car just shut off. It didn't shudder, shake, or jolt like it was going to stall. Just a gentle, "I'm off now" from Lola. She fired right back up and finished her service.
I figured I just didn't push in the clutch in time before the car stalled. I have "gentle" stalled her before so I thought this was another one of those situations where I goofed. For those who don't know gentle stalling appears to bystanders that I turned off the car intentionally rather than stall unintentionally.
If this happened to you, maybe this has to be looked at.
I have what Perrin calls the Rev6 tune. They sent me this after I asked them to turn of the P0420 CEL code that throws when you have no catalytic converter.
I think my sarcasm meter broke.
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
Pete (04-15-2013)
Old 04-15-2013, 09:38 AM   #382
Pete
Pete's Avatar
Drives: 22 BRZ
A very similar thing happened to me the first time I switched to map 3, the idle got much more rough than usual, then I stalled in a parking lot after driving about 3 miles. Since then I haven't had another problem, but I almost exclusively use map 1. It's plenty fast. I assumed the stall was related to the rough idle I have had since I got the car, I really wish that someone would sort that out.
Pete is offline   Reply With Quote
Old 04-15-2013, 10:46 AM   #383
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
never had this happen, what intake are you guys on?
Huehuecoyotl is offline   Reply With Quote
Old 04-15-2013, 11:20 AM   #384
tg_1981
I am running the rev 5 92 octane map. I am currently filling up with 93 pump gas. Could this be the reason this happened?
Old 04-15-2013, 11:21 AM   #385
tg_1981
The intake that came with the vortech supercharger kit.
Old 04-15-2013, 11:39 AM   #386
PhastekSport
Originally Posted by Sonolin View Post
Nice that thing must be a hoot to drive
Unfortunately I wouldn't know. Maybe that is a good thing actually.
93 here as well. Do you change it on the fly while under load or just cruising? At stops or? Just wondering.
I think almost everyone is running a stock intake. My initial feeling was that even if the intake was different, it wouldn't change anything with the MAF being after the IC.
Old 04-15-2013, 12:43 PM   #387
Huehuecoyotl
I ran rev5 for a while, this sounds very odd
those of you stalling, I want to test something is it stalling when the car does a idle dip?
are you ate the factory rpm idle?
1-does it happen consistently?
2-does it happen with the air filter removed?(I can send anyone who wants to test this my hi flo filter if you send it back to me)
I like my motor with a slightly higher idle. I raised it for NVH on the perrin mounts, but love the ever so slightly higher idle's mitigation of idle fluctuation and dips that seem native to our platform
Old 04-15-2013, 01:52 PM   #388
Pete
Pete's Avatar
Drives: 22 BRZ
0-are you ate the factory rpm idle?
0-yes
1-no, it only happened once
2-I have never removed my air filter so I dunno
Jeff just sent me an updated map, I am going to flash it tonight.
Old 04-15-2013, 01:55 PM   #389
F1point4
Photo Specialist
F1point4's Avatar
0-yes
Same as Pete. I need to see if we got an updated map.
Old 04-15-2013, 02:01 PM   #390
tg_1981
0-yes
1-no, it only happened twice. I tried it out this morning again it worked no problem.
Old 04-15-2013, 02:02 PM   #391
tg_1981
I have only changed it when stopped. I can try while cruising later today and see.
Old 04-15-2013, 02:57 PM   #392
Huehuecoyotl
I think I like the raised idle, is my point...
ft86, perrin, phastek, supercharger, vortech
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 04:56 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-16-2013 12:48 AM
