| View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler | |||
| WITH Oil Cooler Spirited Street Driving < 195 F |
12 | 8.28% |
| WITH Oil Cooler Spirited Street Driving 195-215 F |
9 | 6.21% |
| WITH Oil Cooler Spirited Street Driving 215-230 F |
11 | 7.59% |
| WITH Oil Cooler Spirited Street Driving 230-245 F |
3 | 2.07% |
| WITH Oil Cooler Spirited Street Driving 245-260 F |
0 | 0% |
| WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) |
0 | 0% |
| With Oil Cooler Tracked 195-215 F |
5 | 3.45% |
| With Oil Cooler Tracked 215-230 F |
4 | 2.76% |
| With Oil Cooler Tracked 230-245 F |
7 | 4.83% |
| With Oil Cooler Tracked 245-260 F |
6 | 4.14% |
| With Oil Cooler Tracked 260-280 F |
2 | 1.38% |
| With Oil Cooler Tracked 280 + F |
0 | 0% |
| W/O Oil Cooler Spirited Street Driving < 195 F |
5 | 3.45% |
| W/O Oil Cooler Spirited Street Driving 195-215 F |
6 | 4.14% |
| W/O Oil Cooler Spirited Street Driving 215-230 F |
30 | 20.69% |
| W/O Oil Cooler Spirited Street Driving 230-245 F |
16 | 11.03% |
| W/O Oil Cooler Spirited Street Driving 245-260 F |
11 | 7.59% |
| W/O Oil Cooler Spirited Street Driving 260-280 F |
5 | 3.45% |
| W/O Oil Cooler Spirited Street Driving 280 + F |
0 | 0% |
| W/O Oil Cooler Tracked 215-230 F |
0 | 0% |
| W/O Oil Cooler Tracked 230-245 F |
2 | 1.38% |
| W/O Oil Cooler Tracked 245-260 F |
8 | 5.52% |
| W/O Oil Cooler Tracked 260-280 F |
24 | 16.55% |
| W/O Oil Cooler Tracked 280-290 F |
5 | 3.45% |
| W/O Oil Cooler Tracked 290 + F |
4 | 2.76% |
| Multiple Choice Poll. Voters: 145. You may not vote on this poll | |||
#57 |
Track Junkie
Drives: Argento Scion FR-S
I'm barely seeing 250-260 in the Houston weather, sometimes topping at 270ish. It does depend on what track I go on though...
![]() on the street, I'm seeing anywhere between 195-215(hit 215 while cruising at 85mph.) So I personally don't see the need for a oil cooler yet, but I see myself needing one if I ever decide to track the car during the summer. |
#58 |
Drives: 2013 Firestorm FR-S
I decided to call Amsoil and ask about their 0W-20 product and how it would handle sustained 280ish temps for track days. The tech rep I spoke with didn't seem phased at all about that heat level given the flash point of the oil.
I'm not an oil expert, and I know heat will break it down faster, but in terms of providing protection Amsoil seems to think the oil can take the abuse. Is the concern about oil life longevity or actual protection during use?
2013 Firestorm FR-S, MTX, build date 1/13.
#59 |
Add lightness!
Drives: 17' WRX
Is there any reason not to use a mocal laminova oil cooler? Seems like it would be a super easy install. Sandwich plate, cooler, a few lines and clamps. There are mounting brackets you can buy and could probably mount it where the stock intake resonator lives after you get rid of it. It seems like that would be ideal since it would heat up the oil faster as well as index the oil temp to the water temp.
#60 |
Track Junkie
Its probably what I'm thinking. I use amsoil products as well and my oil report from blackstone says I'm doing pretty well and could actually continue driving on the oil even after 4 track days and ~7500 miles!
| The Following User Says Thank You to The Slow One For This Useful Post: | Black Tire (03-05-2013) |
#61 |
Drives: GT86
No, as above, 105C is a good target. You want it over 100C to evaporate water moisture out of the oil. How high you go above that really depends on the oil. Lots of high performance vehicles are familiar with ~120C oil temperature, like Audi RS's, which also have oil coolers fitted.
#62 |
Drives: 2013 FRS Whiteout
Just logged some around town driving and some high rpm highway miles. 15 minute trip, the highest I got was 230 F. Car is stock with stage 1 flash, 995 miles, stock Toyota oil. I felt like I was being hard on it holding 6500 RPMs on the highway, but I guess not that bad temperature wise. Before I push it further I'm switching to motul.
#63 | |
Driving Coach
More info on test pipes losing power without an ecu tune here: http://www.ft86club.com/forums/showthread.php?t=23901 |
#64 | |
Drives: 2015 Mustang GT (on order)
Yeah, it's richer at the tailpipe because some of the unburned fuel shows up but it's not richer in the motor.
#65 |
I Love custom Turbo kits
Drives: Limited BRZ
There's a number of people who just bought the Perrin cooler recently, so we probably will start seeing more numbers with cooler soon.
#66 |
Drives: Perrin/VORTECH Supercharger TestBRZ
as a contribution to the discussion:
once you go FI, getting the oil hot is easy, even with a SC. the bigger challenge is oil cooler placement with such limited air flow and realestate. I did note the fact that in the winter time, when ambient temps are really cold, getting the car warmed up takes considerably longer with the oil cooler installed. for an NA motor, its a nice add on, but the nature 0w-20 is so very thermally conductive compared to say 10w40, so I suspect you will easliy find the cooling efficacy you seek on NA/e85 builds oil getting hot is an understatement in my geography, and it worked great on track NA for me. Now we will see how it handles FI oil heat |
#67 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Seeing @Dave-ROR street temps at 175°F-180°F made me a little concerned. While I'm far from an oil expert, to me that seems a bit low to properly evaporate moisture out of the oil.
#68 |
Drives: Thunder Silver 86 GTS
Should have mine going on this weekend if all things go well. Will do a test run with it and see how we go. Have a track morning on the 20th too so will have some feedback on both DD and Track hopefully.
| The Following User Says Thank You to invisage For This Useful Post: | Sportsguy83 (03-05-2013) |
#69 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Thanks to @Sportsguy83 for getting this discussion started. I, myself, just started considering FI, so I'm a little late to the party. Lots of good info/discussions here.
| The Following User Says Thank You to BigFatFlip For This Useful Post: | Sportsguy83 (03-05-2013) |
#70 |
Drives: Scion FR-S
The trd griffon track car with relatively stock engine has an oil cooler.
Sent from my Galaxy Nexus using Tapatalk 2 |
| Tags |
| oil cooler |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 09:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 05:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 06:42 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-22-2013 12:36 AM |
| Oil Cooler Location? | Captain Snooze | Engine, Exhaust, Transmission | 5 | 11-26-2012 06:02 PM |
