#71 |
Drives: 2013 Scion FRS
Damn that looks good!
| The Following User Says Thank You to Fresh86 For This Useful Post: | Beyer Subaru (03-05-2013) |
#72 |
Drives: SWP BRZ
I like lips and subwoofer.
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | Beyer Subaru (03-05-2013) |
#73 |
Drives: 2013 Scion FR-S (Hot Lava)
Do you have any specific info on the subs? They look pretty cool but really tiny for subs, i was considering getting one in the trunk, but this might be a nice alternative. Some dimensions would be awesome, do they need an amp, and will they be available for both the driver and passenger sides?
Thanks |
| The Following User Says Thank You to TheCzar For This Useful Post: | Beyer Subaru (03-05-2013) |
#74 | |
Drives: WRB BRZ
So a strut tower bar that isnt absolutely rigid and purposely doesnt remove this flex is pointless. Last edited by Lateapex; 03-05-2013 at 01:29 AM. |
#75 |
Drives: 04/2013 BRZ-L
#76 | ||
Glorious BRZ Master Race
Drives: Subaru Libird
Basically, this design stiffens the chassis along the axis that matters (left-right), not in the axis that doesn't (and improves comfort as a result). I'm trying to look at this just with my basic understanding of forces from freshman physics. Someone who has studied Statics (any mechanical engineer) would be better at analyzing. @ZDan or @Shankenstein, would you have any input on the effectiveness of the STI strut tower bar with a ball joint in the middle?
| The Following 2 Users Say Thank You to switchlanez For This Useful Post: | Beyer Subaru (03-05-2013), chaoskaze (03-05-2013) |
#77 | |
#78 |
Drives: FJ Cruiser 2008
I like the front spoiler under protection kit. I wonder if it will be available for those living in the U.A.E
#79 | |
Drives: 2013 BRZ SWP 6AT Ltd
It is highly unlikely that the rest of the world will receive all or any of these Accessories. |
#80 |
Drives: GT86
this forum rocks!
| The Following User Says Thank You to Alabang 86 For This Useful Post: | Beyer Subaru (03-05-2013) |
#81 | ||
You and me both.
Yes, yes it does! |
| The Following User Says Thank You to Beyer Subaru For This Useful Post: | TheCzar (03-06-2013) |
#82 | |
Frosty Carrot
Drives: The Atomic Carrot
Strut bars have 2 purposes: 1) Stiffen the tower to tower lateral movement (tower to tower bar) 2) Couple strut flex to a neutral chassis position (tower to firewall bars) Many people discuss suspension as being a parallelogram. While it's not completely true, it provides a useful illustration. Point 1 makes the top line in the parallelogram more rigid. In most cars, the other 3 lines are already very stiff. This turns your trapezoid into a parallelogram (a good thing). Point 2 makes the angles at each corner of the parallelogram more rigid. During compression, the strut towers want to bend inward. A strut bar is put into compression and resists this quite well. During cornering, one strut tower wants to move inward heavily, while the other moves outward slightly. A strut bar is put into tension and transmits the deflection from the outside strut to the inside strut. Since the inside tire's camber is less relevant to maximum grip, you sacrifice some deflection to improve the situation on the outside tire. All this is dependent on the struts flexing. Modern chassis design is rather rigid, so it's not as important as in an 80s Civic or my RAV4 (an SUV version of the Corolla). When installed my strut brace (1.5" square tubing w 1/4" plate on each tower), the handling limits did not really improve... but the consistency of when the tire broke loose was much better. Strut flex begets more camber and grip, and in many cases is not a bad thing. I value the stability and consistency more than ultimate grip. Go kart vs. muscle car, if you will. Point 2 is irrelevant if you consider the front and rear suspension as independent parallelograms. They aren't... so preventing either from differing too much from the unstressed geometry is important. Also, triangles are stronger than parallelograms, so tying into the firewall (however flimsy it may be) is still good for structural rigidity of all parts involved. Modern cars make strut braces less relevant, but if you want to install a strain gage on your cusco bar... go for it. You'll see some forces, but the system is already quite stiff, so it won't cause much deflection in geometry (especially compared to bushings). @switchlanez , a strut bar that can twist freely does add a degree of freedom to the bar (in a direction that we are OK with flexing)... but I don't see that being useful or relevant. Maybe it helps keep welds from cracking, but I can't wrap my head around any serious reason. edit: I'm copying this to my thead, since it's somewhat relevant.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | switchlanez (03-05-2013) |
#83 |
Drives: civic,vfr,BRZ
.... my thoughts exactly... How much shorter could it really get?
Because Racecar.
#84 |
Drives: '13 FR-S MT - ultramarine
those are 3" (77mm) drivers. they are not subwoofers, they're barely even woofers. (same size as the mids units in the dash)
| The Following User Says Thank You to cabasse For This Useful Post: | Beyer Subaru (03-05-2013) |
| Tags |
| brz forum, brz forums, subaru brz, subaru brz forum, subaru brz forums |
| WTS 2013 SWP Subaru BRZ Limited MT | jrodz09 | Cars for Sale/Trade | 18 | 03-04-2013 05:11 PM |
| 2013 Subaru BRZ Spotlight video by Subaru | switchlanez | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 09-25-2012 02:47 PM |
| Media: 2013 Subaru BRZ | Ko6pa90 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 25 | 04-20-2012 11:01 AM |
| 2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast | Zgrinch | Scion FR-S / Toyota 86 GT86 General Forum | 124 | 02-21-2012 03:43 AM |
