#43 |
The 2.5L turbo Subarus are pretty famous for cracking the ring landing on the #4 piston. I did many years ago when I had an EJ257 block in my 02 WRX. Poor tunes on the 08-09 WRX/STi models led to those failures even on stock cars. People got tunes as a reliability investment.
It's very easy to tell with a compression test. The smoking on startup happens with the cracked ringlands, here is a video: [ame="https://www.youtube.com/watch?v=OmdBgNEWHaQ"]2007 STI Limited - Start Up Exhaust Smoke - YouTube[/ame] But the codes you are getting aren't indicative of it and usually there is no associated noise/rough running until things get really bad. |
#44 | |
Drives: Argento
![]() Sent from my SGH-T999 using Tapatalk 2 |
| The Following User Says Thank You to slidethis For This Useful Post: | tripjammer (03-07-2013) |
#45 |
Those are cam timing codes, I doubt it has anything to do with the spark plug.
So doing a google search there are others who have received the same exact set of codes and it was due to a faulty VVTi unit, not necessarily related to the more widespread issue others have had. I guess I would agree aggressive tuning maybe caused a premature failure, hopefully that's it. Also for some reason Subaru engines seem to hate Mobil 1. |
| The Following 2 Users Say Thank You to xwd For This Useful Post: | 20valvewynn83 (02-25-2013), tripjammer (03-07-2013) |
#46 |
I'm voting for a VVTi failure. Probably not the pulley itself, more likely the oil control valve is stuck open and not letting the VVT return to 0 position. The ECU can't compensate for it so you're running somewhere north of 0 advance in timing.
#47 | |
Drives: 2013 FRS/01 Tacoma
#48 |
Track Junkie
Drives: Faster than the Stig!
Im running 5w30 and i dont run anything under 93 octane.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| The Following User Says Thank You to track_warrior For This Useful Post: | tripjammer (03-07-2013) |
#49 |
Everyone can say what they want and even do as they please but 5w30 is a little thick for our cars (my opinion). Also you say you run 93 octane I would assume its tuned for that octane but that doesn't mean the tune isn't adjusting itself. Did you add any other mods since you tuned it. But on the real seams you may need New VVTI cam gears.
#50 |
The manual states to use 5w30 if the car is under sustained load, like tracking the car.
The 0w-20 stuff is for fuel economy... I would run something like Motul 300v. |
| The Following 3 Users Say Thank You to xwd For This Useful Post: |
#51 | |
Site Moderator
Drives: Stuff
5W-30 is fine.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following 2 Users Say Thank You to Dave-ROR For This Useful Post: | D1cker (02-26-2013), track_warrior (02-26-2013) |
#52 |
Drives: 2013 Asphalt FR-S
believe i have seen this issue before and it was due to a clogged screen filter in one of the oil passages for the avcs system.. i will have to check with someone though as it may have been and evo not a subbie.
~Namaste~ |
#53 |
yep, just looked it up in the FR-s manula P0011 oil control valve filter is listed as a check item... More than likely that is the issue, these were known to fail on the sti's and were reccomended to be removed. I'll probably remove mine for good measure once i figure out how.
~Namaste~ |
#54 |
Drives: Whiteout FR-S
I'm no mechanic & the way your motor sounds reminds me of the time someone replaced my timing belt on my honda civic & they were off by 1-2 teeth & wasn't firing properly at all. Hope it's not a major issue for you.
#55 | ||
Track Junkie
This What to hear something funny, tonight i was driving the w210 E-420 when my wife and i started to feel the engine run weird and loose a bit of power, no code but it sounded like it was misfiring. As soon as i got home i was thinking a bad plug, or coilpack. Since i know this car inside out since ive had it since 1997 i checked plugs and coil packs one by one and found cylinder 4 was misfiring. I took out the plug and noticed it was a bit loose and found the inside to be soaked as well as very dirty. Cleaned the plug and coilpack put it back in the car and voila no more misfire. Next thing you know im going to start to misfire .Im praying the issue with my FR-S is as simple as it was with my w210 tonight. Pics of the issues with the w210: ![]() The culprit: Left coil pack soaked ![]() ![]() ![]() ![]()
#56 |
No I just get trained on it from corporate. And as I stated people can say what they want and do what they won't to their cars but I still think 5w30 is too heavy for this car I wouldnt go higher then 5w20 but that's me. Personally I will stay with 0w20 and run a better quality oil like eneos sustina.
| Scion/Toyota broke 3rd brake light applying tint | Lefty | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 10-31-2019 07:23 PM |
| How to wash your car in an hour or less, make it look like a pro, and not go broke... | seven | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 141 | 01-30-2015 12:32 PM |
