Old 10-25-2013, 03:48 AM   #1163
mrlizard
Drives: BT50
All sorted and everything is working fine now i just got to set up all up.
Have people been go some pictures of how they set up there home screens and what navi programs they are using
Edit play store has just stopped working tried force stopping it and clearing the data, turning off wifi even forgetting my wifi and reconnecting. Internet working fine as I can still get on the internet?
Only thing I have changed is have the brightness on the left knob when pressed
mrlizard is offline   Reply With Quote
Old 10-25-2013, 01:45 PM   #1164
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Is there a recommended store for the unit? And is there anyway to easily find the same unit on ebay?
Installed Mods:
Old 10-25-2013, 02:32 PM   #1165
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
This is where most of us bought the unit
http://www.tradesolution.hk/e/ptxweb...duct/1274.html
I can't see the exact same unit on eBay
nzer is offline   Reply With Quote
Old 10-25-2013, 02:35 PM   #1166
nzer
nzer's Avatar
Not sure why play store would stop. Mine stops when Internet connection is dodgy.
Try searching for an app using browser and selecting it and when it says how you want to install choose the play store and see if it works that way. At least that night narrow down if it is the store app or your login etc
Old 10-27-2013, 12:55 AM   #1167
advocate007
Drives: 2013 Series 10 FRS
I know I have asked this before but I still cant get the speech to work in Torque. I have tried updating to the latest version of torque, tried not having any running sound, tried rebooting with nothing loading, tried setting the navi button to torque. Even tried running the android stock music player while testing the speech function on torque but no luck. Has anyone else had this problem or has a fix.
advocate007 is offline   Reply With Quote
Old 10-28-2013, 06:09 AM   #1168
mrlizard
Drives: BT50
This is just all bench tested at the moment
I have just rebooted it and it works again but if I disconnect it from the battery and reconnect it the play store won't connect.
Old 10-28-2013, 06:12 AM   #1169
nzer
nzer's Avatar
So don't disconnect it then LOL!
Old 10-28-2013, 07:51 AM   #1170
mrlizard
Drives: BT50
Lol I'll have to wait till it is installed to see if it still dose it
Old 10-29-2013, 04:42 AM   #1171
mrlizard
Drives: BT50
I need to stop posting as soon as something goes wrong it's a bad habit.
But I have found out that if I just disconnect the acc cable and reconnect it like as if turned my car off with the key the play store and everything else works fine.
So fingers crossed that my battery never goes flat other wise I need to reboot and set everything up again
Old 10-30-2013, 11:54 PM   #1172
GreenPants
Drives: Burnt Orange GT86
Normally, the tuner stays powered up for a few seconds after the ignition has been turned off. (In my car at least, the door buzzer goes off if I try to open it before the tuner has fully powered down).
It is possible that certain settings are saved/written/flushed to flash during this period. If you simply yank the power (easy to do on the bench, not so much in a car), then it is possible that settings get lost.
Try pulling the power now that the Play store has been correctly configured (and state saved to flash). You might find it is no longer an issue.
GreenPants is offline   Reply With Quote
Old 10-31-2013, 01:09 PM   #1173
hmosquera
Drives: Honda CRV 2013
Hi !
hello my name is Hernan, i´m from argentina.
I have a honda crv 2013 and i bought this model of stereo...
http://www.tradesolution.hk/e/ptxweb...duct/1276.html
my unit unlike of the website, has buttons home, menu and back
Here some pic of my unit
Can i upgrade my stereo with version 3 of GreenPants?
is this my unit uoku plataform?
This is the specs of my unit:
cpu information: freescale i.mx53
Ram information: 512 ddr3 800
version android: 2.3.7
MCU version: 2.11.1-1-10-1
Sytem version: 2.20.21
Dvd version: 2.13.11-1200wb
my MCU is newer, replacement is required for root access?
Which files would have to put on my stereo?
Thank you very much
Last edited by hmosquera; 10-31-2013 at 05:04 PM. Reason: add pics and information
hmosquera is offline   Reply With Quote
Old 10-31-2013, 04:12 PM   #1174
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Couple of questions for you guys who have this or similar units.. Has anyone started to make a red led version of the same deck? I'll pay for the modification if someone offers a reasonable price.
Does anyone happen to have a Valentine 1 with the V1 Connection? There is an app called YaV1 that I would like to see if its compatible with this headunit. Its basically a radar detector app that shows on screen infomrmation from the V1 and allows gps lockouts as you run into electric doors or speed signs. If the app works well with these headunits, i'll surely buy one soon and ditch the phone app.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 10-31-2013, 04:34 PM   #1175
nzer
nzer's Avatar
Only LED option at this stage is to convert yourself - here's the DIY http://www.ft86club.com/forums/showthread.php?t=42023 but is only for the skilled (unlike me).
I will look at loading that app for you and seeing it it works - can only test if I can start it as won't have the compatible radar detector.
The Following User Says Thank You to nzer For This Useful Post:
Norkoastal (10-31-2013)
Old 11-05-2013, 02:24 PM   #1176
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Found this on tradesolution,
Actually wondering if it would be a perfect fit, if it would be able to run Torque out of the box and what color the leds are
http://tradesolution.hk/e/ptxwebstore_product/1707.html
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-20-2013 12:51 AM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 11:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 04:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 06:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 11:47 PM
