Old 05-15-2013, 09:46 PM   #617
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by ph0en1xtk View Post
Im gonna go out on a limb here and see if anyone has any idea whats wrong with my unit.
Whenever i connect to wifi via either my home wifi or my phone's mobile hotspot, i get internet connectivity on all my apps (firefox, facebook, etc) but when i go to google play, it just keeps saying "no connection" with a retry button. I need to download the license for poweramp full version, and i cant get google play working. This is strange because a week or 2 ago, i downloaded quite a few apps from there with no problems on my home wifi.
Also if anyone knows why my music in the stock music player app is always in reverse order...that would be cool to figure out also
If @Narcoden's solution doesn't work you should also try plugging your wifi dongle directly into the USB cable rather than into a hub.
One hub I had kept dropping the signal and some apps were more forgiving about the break in signal than google play.
nzer is offline   Reply With Quote
Old 05-16-2013, 12:02 AM   #618
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
thanks @Narcoden and @nzer for the suggestions, i will try them in the morning.
After that, the only thing i can really hope for with this unit from now is for some of the developers to make better stock apps for the radio functions. Hopefully that isnt too far off
ph0en1xtk is offline   Reply With Quote
Old 05-16-2013, 10:15 AM   #619
Poe
Fascinated Driver
Poe's Avatar
Drives: Raven FR-S
Microphone
Awesome information on this thread!!!
@2forme and all of you other guys - thanks for being innovators and doing this first...
I'm about to pull the trigger on the T7019A and have the following questions:
Does the FR-S standard microphone work with the T7019A? Is it plug and play, or will it require splicing into the wiring harness?
Thanks in advance!!
Poe is offline   Reply With Quote
Old 05-16-2013, 12:19 PM   #620
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Google announce a bunch of updates to Google Music yesterday at Google I/O and updated the Google music app.
Use caution when updating to the new app. It's got a bunch of force close errors on my android radio. I had to freeze the app so it doesn't run (Titanium Backup)... Hopefully Google will fix/update it soon. Works fine on my phone though.
Narcoden is offline   Reply With Quote
Old 05-16-2013, 04:30 PM   #621
nzer
nzer's Avatar
Thanks in advance!!
The T7019A has a built in Bluetooth mic on the head unit. It is on the left just below the volume knob so on the correct side for a LHD vehicle. For a RHD vehicle it is a bit further from the driver.
Unfortunately I can't see anywhere to wire an external mic. It may need to be soldered into the unit (beyond me).
I haven't checked all of the wires coming out the back yet but doesn't look promising.
The wiring is plug and play.
Old 05-17-2013, 07:52 AM   #622
Poe
Fascinated Driver
Poe's Avatar
Drives: Raven FR-S
Thanks, @nzer!
Old 05-17-2013, 08:20 AM   #623
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Nzer...resuming all infos.... please, what exactly needs after buying T7019A for fitting?
The package exactly what include? thx
Trap63 is offline   Reply With Quote
Old 05-17-2013, 09:15 AM   #624
nzer
nzer's Avatar
Everything you need is in the pack except
1. Antenna adapter http://www.ebay.com.au/itm/111046104...84.m1497.l2649
2. Compatible Bluetooth dongle to get torque working http://www.ebay.com.au/itm/USB-V-4-0...c023aef&_uhb=1
3. ELM327 to plug into the OBD2 http://www.ebay.com.au/itm/Super-Min...1e4efd4&_uhb=1
All pretty cheap. Links are to ebay Oz but you can get from international eBay or dx.cm too.
Actual unit fits with the OEM mounts off the OEM head unit and the OEM dash bezel. Unbolt the original, transfer the mounts from OEM unit to bew oe n bolt bak in using the OEM mount points. One plug to plug into backed the antenna adapter and that's it.
If you don't want to use torque then all you need is item 1
The Following 2 Users Say Thank You to nzer For This Useful Post:
jonzhuxD (06-07-2013), Trap63 (05-17-2013)
Old 05-17-2013, 03:26 PM   #625
Trap63
Trap63's Avatar
Thanks for the help Nzer!! I evaluate your solution the better one for replacing stock unit that we have in Italian version (very poor). :happy0180::happy0180:
Old 05-18-2013, 10:15 AM   #626
Ghostmerlott
Drives: GT86
And now.... after half a day of effort! I would like to thank all my brothers here!!:happy0180: Without which all this will not be a reality..I feel like crying....
Radio is still stuffed up, maybe I didnt connect properly...
Some feedback for folks who are considering my approach (Tun21a + beatsonic kit)... the dash trim piece fits in with great difficulty over the unit. But at last it still does fit snugly.
After installing this, I can say with full confidence... replacing leds is waaaay beyond my pay level...! Blue leds it is...blue it will be
Ghostmerlott is offline   Reply With Quote
The Following User Says Thank You to Ghostmerlott For This Useful Post:
2forme (05-20-2013)
Old 05-18-2013, 10:21 AM   #627
Ghostmerlott
Drives: GT86
Originally Posted by Ghostmerlott View Post
Anyone knows how big is the memory capacity within the Cafi knockoffs? 8Gb, 16Gb? or do all apps have to go into the external sd card
Checked the unit after installation today, in built capacity is ~ 5Gb.
And the unit has Sygic OFFLINE maps!! (Ok, i was expecting online version or one where I need to buy the maps....)
Old 05-18-2013, 12:56 PM   #628
ph0en1xtk
ph0en1xtk's Avatar
still no luck with the google play market. its frustrating the hell out of me. I tried both suggestions to no avail
Old 05-19-2013, 09:23 PM   #629
Ghostmerlott
Drives: GT86
How do you guys do back up of the system? Just in case it drops down dead and you need to reset the whole thing again
Old 05-20-2013, 06:17 AM   #630
krikke
Drives: Evo x gsr
Titanium Backup?
krikke is offline   Reply With Quote
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-20-2013 12:51 AM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 11:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 04:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 06:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 11:47 PM
