Site Moderator
Drives: Stuff
Yay got my first check engine light today
In the middle of bishops bend at Sebring the car stumbled and the CEL popped up. Not the normal code that I was expecting.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Site Moderator
Drives: Stuff
See attached for code. I can't resize as these are iPhone pics
-Dave
Drives: Asphalt AT
I thought I dodge the bullet crossing the 10k mark, 7k more miles here I come!!
Drives: 2013 SWP BRZ Limited
Wow this is the first time seeing a CEL that's not the normal... U know. I won't say it.
ZC6A2B82KC7J
Drives: 2002 WRX
Guessing you already have this, but here it is for others
Site Moderator
Drives: Stuff
On the plus side oil temps haven't gone past 235F based on the gauge (sender right after the cooler).
-Dave
Site Moderator
Drives: Stuff
And she fixes herself. Fifth time starting it since it happened and no cel.
-Dave
Sarcastic SOB
And why?
...probably because racecar!
Glad it fixed itself.
#10 |
Grip>Drift
Drives: FRS
My guess is the heat under the hood caused a coil issue and you had a misfire. If the problem isn't replicated in so many cycles the light will go off.
But, WTF do I know?
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | JesseE (02-24-2013) |
#11 |
Drives: Whiteout FR-S
At least we know the car does a good job of protecting itself from damage/overheating
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#12 |
Drives: LS Swapped BRZ
that is a sign that the more track based car are going to need upgraded coils to withstand the extra heat and abuse... one thing you could try for now is attach a heat sync to the top of the coil the nice thing cpu heat sync is prolly very easy to convert to work and not to mention cheap.
#13 |
Site Moderator
Drives: Stuff
And it came back.
-Dave
#14 |
Site Moderator
Drives: Stuff
And I doubt it's heat related. Happened 10-15 minutes into the session and lasted 5 30 minute sessions before and 1.5 after. I think it's just a bad coil. LD's car did fine with the same usage this weekend.
-Dave
| Check engine light just came on after 2k miles. | danthedirt | Issues | Warranty | Recalls / TSB | 604 | 01-31-2015 04:26 PM |
| Check engine light? | czar07 | AUSTRALIA | 0 | 09-01-2012 02:50 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 09:50 PM |
| Check engine light code reader | FRSCoupe | Engine, Exhaust, Transmission | 14 | 06-13-2012 05:06 PM |
