86WORX
Old 03-08-2013, 09:50 PM   #15
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Did you take temp readings? I have remote canisters (on a different car) and it is also by the engine, although not as close as yours.
iLuveKetchup is offline   Reply With Quote
Old 03-08-2013, 10:06 PM   #16
ayau
Drives: Some rust bucket
Here's a pic of the R2's similar mounting location.
Old 03-08-2013, 10:21 PM   #17
xwd
After driving pretty hard the drivers side one isn't even warm in any way. The passenger side canister gets a little warmer but not much. I guess I can get out the pyrometer tomorrow and check them before and after driving. The engine itself doesn't really give off enough heat n that area to make a difference but the passenger side sits above the exhaust.
Old 03-14-2013, 04:37 PM   #18
xwd
So after driving fairly hard and then letting the car sit for a few minutes for things to heat soak it registered 96 degrees on the outside of the driver side canister and 102 on the one sitting above the exhaust. The engine block itself was about 160 degrees. This is from a standard pyrometer. I measured the before and after nitrogen pressure and the difference was 2-3psi.
I'm not worried about it but if someone was you could certainly use some reflective tape or heat blanket material around them.
The Following User Says Thank You to xwd For This Useful Post:
iLuveKetchup (03-14-2013)
Old 03-14-2013, 10:23 PM   #19
TeamZleep
Drives: 2013 FRS/2011 TDI
This setup looks amazing...
TeamZleep is offline   Reply With Quote
Old 07-25-2013, 04:35 PM   #20
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Any updates?
Acree is offline   Reply With Quote
Old 11-13-2013, 02:02 PM   #21
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
@dwx: Any longer-term updates to what you've said above? These are beautiful.
Anthonytpt is offline   Reply With Quote
Old 11-13-2013, 10:00 PM   #22
xwd
Look just as good and work just as well as when I installed them 9 months ago. I've re-mounted the canisters onto the Grimmspeed front strut bar, that's about it.
I am getting ready to take them off the car to get them re-valved for higher spring rates and a couple other changes since I'm moving to STX next year.
Anthonytpt (11-14-2013)
Old 05-22-2014, 01:01 PM   #23
Anthonytpt
Anthonytpt's Avatar
@dwx: Did you end up re-valving for higher spring rates? If so, how's that working in STX for you?
Old 08-05-2014, 04:05 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
hey @dwx do you have shock dyno's of these?
Old 08-06-2014, 12:46 PM   #25
xwd
I have them printed somewhere I will see if I can find them.
Old 10-17-2014, 01:07 AM   #26
toby714
Drives: whiteout
what kind of sway bar or front endlink are you using? my mcs with whiteline front end link and stock sway bar binds like crazy. I need to find someone that produces shorter endlinks. a lot of popping sounds from the front turning
toby714 is offline   Reply With Quote
Old 10-29-2014, 10:03 AM   #27
xwd
I am using the WL front bar with WL end links. I've used the Strano bar as well, never had any issues. I have never tried the stock bar with different end links.
Old 02-21-2015, 11:24 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Update on those shock dyno's
Search this Thread:
Advanced Search
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 03:42 PM
Deft Motion | Suspension Specials Deft Motion Brakes, Suspension, Chassis 4 07-12-2012 03:48 PM
