#351 |
Drives: 2013 Scion FR-S Raven
Where did you purchase the sensor and pins?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#352 |
First 86 Driver Baby!
Drives: FR-S, Flex
I ordered the sensor from Subaru Parts Warehouse (10% discount this weekend), and the pins I'm getting from Tweaked Performance.
#353 |
Drives: 2013 scion fr-s ultramarine
so have we figured out that the wires are not there from the factory and we will have to run the wires to the bcm in order for it to work?
#354 |
Drives: FR-S, Flex
The wires for the auto function are NOT there. You'll need to add 3 wires from the sensor to the MB ECU, and 1 wire from the stalk to the MB ECU. I have a separate thread on this and will update it once I get the parts I need for install.
| The Following 2 Users Say Thank You to kmbkk For This Useful Post: | civicdrivr (05-27-2013), Dadhawk (05-27-2013) |
#355 |
Drives: 2013 Toyota 86/Scion FRS
If anyone is planning to install EDM/JDM headlights with auto level, looks like there will not be any harnesses available for plug and play.
![]() Anyone with GT86 headlights can confirm what the grey connector is for? and if they also have the same plastic capped wire bundle? |
#356 |
Thanks to all for their efforts and guidance.
Will FRSFirestorm ever has his pictures again?
#357 |
Any updates?
#358 |
Drives: FR-S, Flex
Nah, I've been out of town the past 3 weeks. I haven't been able to find a connector for the sensor. Worst case I connect the wires directly to the sensor.
#359 |
Drives: Subaru BRZ
is there a similar option for BRZ ? or dose one need to pay 300usd for the original kit ?
#360 |
Bang Bang
Drives: 2013 Raven FR-S
Let me see if I got this straight. Just use the H11 connectors from the fogs, run hot wire to white/red on passenger side, and red/white on drivers side, ground the fogs and I'm done? Fogs will come automatically come on with the headlights?
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers |
#361 |
86 Owners of New England
Drives: Toyota GT86
what wire do I tap into to make the fog indicator on the dash illuminate? I already have the fogs installed with the push button switch.
#362 |
Drives: Ultramarine FR-S
By push button switch do you mean through the USDM fog light kit? I don't think there's any way to have the dash light illuminate with the fogs without using either the harness the USDM foglight kit uses or pin #4 on the turn signal socket
#363 | |
Drives: Toyota GT86
It would just be nice that when the switch is pushed in (fogs are on), the fog indicator on the dash would also come on; I'm sure it can be done, I just dont know what wire I would have to tap into to make that work.
#364 | |
How is the switch hooked up? Directly to a relay to the fogs or through a factory harness? I don't think you can get the indicator to illuminate if you don't use any factory wiring in your install |
| Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 11:54 PM |
| Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 01:44 PM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 06:09 AM |
| new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 04:20 AM |
| for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 01:53 AM |
