Old 05-10-2013, 06:02 PM   #309
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
On a different note, can someone take a pic of the auto headlight sensor on the BRZ? I'm goin to order one and just wanted to see where it's mounted.
kmbkk is offline   Reply With Quote
Old 05-10-2013, 06:20 PM   #310
Sco2355
Originally Posted by Tama-Y View Post
Oh, so the BRZ USDM stock has the REAR fog option as well?
Thats weird because images on the web indicate otherwise.
Sorry, I guess I miss read what you asked. Kmbkk is the only one to get the EDM stalk. The rest of us have the same one Nigel offers on his site which is the USDM BRZ stalk.
Sco2355 is offline   Reply With Quote
The Following User Says Thank You to Sco2355 For This Useful Post:
Tama-Y (05-10-2013)
Old 05-10-2013, 06:22 PM   #311
Sco2355
I have a feeling it's mounted in one of the "clips" that hold that plastic vent just under the windshield. But honestly I haven't looked.
Old 05-10-2013, 06:44 PM   #312
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
Apparently, @kmbkk also got it from Nigel. So is Nigel changing his inventory or did he just get lucky?
Tama-Y is offline   Reply With Quote
Old 05-10-2013, 06:48 PM   #313
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
i have a BRZ switch FS =)
GT86drifter is offline   Reply With Quote
The Following User Says Thank You to GT86drifter For This Useful Post:
Sco2355 (05-10-2013)
Old 05-10-2013, 06:51 PM   #314
Sco2355
Like he said a few posts up, more of a special order lol.
Old 05-10-2013, 07:36 PM   #315
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
It may be special order, but he also may have ordered more than one when he ordered mine.
The Following User Says Thank You to kmbkk For This Useful Post:
Old 05-10-2013, 09:51 PM   #316
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
The BRZ Light Sensor Location is Certainly Easy to Find
The automatic light sensor should be installed at the passenger end of the Defroster Nozzle Garnish on top of the dashboard. That is if there is a socket for it in the FR-S build.
To investigate that, you'd need a Molding Remover to remove the Garnish plastic piece (long one with about 16 holding clips underneath) to inspect if a receptacle socket for the sensor exists underneath.
If the socket is there, the sensor is $72 from Subaru. If you break the Garnish plastic piece, the replacement also comes from from Subaru. The graphic is on page 1435 of the FR-S repair manual.
I can send you a Subaru PDF containing all the details, however, I tried everything to attach a PDF one page file to this message, but still could not do it.
My theory is that the socket exists, same like the socket and harness for the auto dimming mirror.
In general, Toyota added all the necessary parts for upgrades. If you're interested tell me how to send you the PDF graphic to investigate all the above.
Zagmeister is offline   Reply With Quote
Old 05-10-2013, 09:58 PM   #317
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I am very interested
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 05-10-2013, 10:01 PM   #318
Zagmeister
Zagmeister's Avatar
The attached Subaru PDF is for the physical location of - and how to get to - the socket that is the receptacle for the light sensor. The sensor is physically not there; otherwise you will be able to see it poking out of the passenger side of the Defroster Nozzle garnish. If the socket is there, the sensor is $72 from Subaru.
I also think that the socket (not the sensor) may be there and it's just the sensor for the headlights that is needed. The OBDII port observation, for the "ambient light" parameter is already set, such observation confirms my own belief.
The Subaru PDF attachment is pretty much the same on the Scion FR-S Manual page 1435 of the repair manual. The FR-S manual is already on this Forum.
Finding and confirming the existence of the receptacle socket would make the job much easier to just buy the sensor, drill a hole in the Defroster Nozzle garnish and plug the sensor into the pre-existing socket - if it's really there.
The Following 2 Users Say Thank You to Zagmeister For This Useful Post:
civicdrivr (05-10-2013), Retro86 (05-12-2013)
Old 05-11-2013, 01:31 AM   #319
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Do you know if the same automatic light sensor is used for the GT86 headlights? I have the auto leveling ECU and sensor from Nigel but the sensor doesn't look the same as the one shown in the diagram.
iketiak is offline   Reply With Quote
Old 05-11-2013, 08:08 AM   #320
Sco2355
Honestly I don't know but I assume it is.
Old 05-11-2013, 11:20 AM   #321
iketiak
iketiak's Avatar
The sensor that Zagmeister showed is sticking out of the hole in the nozzle garnish on top of the dashboard. The one I have right now seems to have the same receptacle socket but doesn't look like it's visible at all once installed.
Old 05-11-2013, 11:45 AM   #322
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I may pull off the garnish and verify this today, provided it stops raining! Also, by looking at the PDF, do you think there is a different garnish for cars with the sensor? My guess is there is one pre-drilled/fabricated with the hole you could order. Thy is if you want it as OEM as possible.
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
