86WORX
Old 04-14-2013, 09:11 AM   #267
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
So basically someone could start making and selling pre built harness that plugs into the side maker connector and jumps to the foglight h11? Shit I wish I was I'm America
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-16-2013, 08:24 PM   #268
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Originally Posted by Retro86 View Post
okay guys, finally finished. after a couple of noob moves i got my stuff done.
picture time!
female connector with the lock removed, i took out the black wire just to see which female pin to use
This one rght here as you can see there is a blue plug that you need to push out so you can put your female pin connector.
Luckily i remembered i had a couple of these laying around, its not the same one but i tweaked it a little bit to make it fit
as you can see the bottom left of the connector with the orange/red wire goes directly to your fog socket.
ground it out then test it up, shiii works
finally! thanks guys!
How did you remove the lock?????
Willsonk is offline   Reply With Quote
Old 04-16-2013, 08:49 PM   #269
Retro86
Retro86's Avatar
Drives: Awesome
i used a safety pin and basically unhook it. its like unzipping a ziptie.
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
Willsonk (04-17-2013)
Old 04-18-2013, 09:48 AM   #270
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
http://www.ft86club.com/forums/showthread.php?t=34078
full fog light kit
put my own kit together for 150 ..
imravenit is offline   Reply With Quote
The Following User Says Thank You to imravenit For This Useful Post:
Sco2355 (04-18-2013)
Old 04-18-2013, 02:39 PM   #271
Sco2355
full fog light kit
Someone has been following our threads lol.
Sco2355 is offline   Reply With Quote
The Following User Says Thank You to Sco2355 For This Useful Post:
Retro86 (04-18-2013)
Old 04-19-2013, 12:15 AM   #272
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
If anyone wants to make harnesses just to sell here's a picture of the harness for reference:
CamryDS is offline   Reply With Quote
The Following User Says Thank You to CamryDS For This Useful Post:
PANDA86 (04-19-2013)
Old 04-19-2013, 12:35 AM   #273
PANDA86
Old School Status
Drives: .
is there a complete listing of parts list? i.e. stalk, light harness part/model# etc? TIA.
PANDA86 is offline   Reply With Quote
Old 04-19-2013, 12:41 AM   #274
CamryDS
Nope. got the pic off of ebay.
Old 04-19-2013, 05:16 AM   #275
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Heres everything you need to know how to install a fog light on your frs..
Here's all the references I used..
FRS Fogs using BRZ Stalk http://www.ft86club.com/forums/showthread.php?t=29263
Fog Light Powered with Factory Stalk and BCM http://www.ft86club.com/forums/showthread.php?t=33025
Scion Frs Fog Lights http://www.ft86club.com/forums/showthread.php?t=27581
for more information and guide please visit these threads above..
Parts Needed:
1. L&R Fog Lights $84
-2 Outback Fog lights Part #84501AJ00A
http://www.subarupartsforyou.com/cp_...p?partid=19073
L&R Fog Light Cover $25
RH Fog light cover - SU00301518
http://www.amayama.com/search/?q=su00301518
LH Fog light cover - SU00301519
http://www.amayama.com/search/?q=su00301519
BRZ Stalk Switch $60
Item#: 83115FJ070
http://subarupartsforyou.com/cp_part...p?partid=23294
H11 Harness $15-25
Any h11 harness you prefer, wether you buy one from amazon.com or get Nigel fog light harness kit.
Mounting Hardwares $5
You need 4x m5 or m6 Allen bolts, 4x m5 or m6 washer, 4x nylon m5 or m6 nuts.
Extra Harness Pins, to make a new harness with your h11 connectors, to connect to the signal lights connectors.
http://www.ft86club.com/forums/showt...=29263&page=12
Or get the full kit at Ishii Motors http://www.ft86club.com/forums/showthread.php?t=34078 for $385
2. Start by disconnecting the battery
3. Positive Terminal disconnected
4. 3x fuses for the Horn were taken off. Heres a reference http://www.ft86club.com/forums/showthread.php?t=12257
5. Now take off plastic splash guard underneath the bumper, both passenger and driver sides, there 1x 10mm nut you need to take off and 2 pop offs on each side..
6. take off the plastic cover on passenger side, be patient, you can actually pull it off once you get a corner off.
7. Now same for the driver side just carefully take off driver side plastic cover
8. Here both driver and passenger side plastic covers are taken off
9. Now its time to take the steering wheel off, first you need to take the airbag off. once again dont forget to disconnect battery off. now go to the cabin and push the pin forward the center of the steering wheel on all three holes. while pulling the airbag itself towards you. Reference http://www.ft86club.com/forums/showt...ghlight=Airbag
10. remove the orange, black harness and ground for the horn off the airbag. remove the nut that's holding the steering wheel, then gently pull the steering wheel towards you.
11. make sure to tape the steering angle sensor so it does not move I used a tape to make sure it does not move, basically you want the orange to be visible in the window just like the picture.
12. remove two bolts to take upper and lower plastic steering cover.
Remove the two screws from the wheel covering. Gently remove the bottom cover by seperating top from bottom.
13. now remove the white connector on the steering angle sensor
14. remove all off the sensors underneath, the yellow one is a tricky one you actually need to push it from the end.
Next unplug everything you basically see. Lower left side is a white connector for the headlamp assembly. Lower Center is a white and yellow connector for the steering position sensor. The yellow connector has a specialty lock that has to be slid forward to get it disconnected. There is also a connector to the right side and rear of the steering sensor. There are 3 clips that hold the steering sensor. Unsnap them and gently pull it off. Keeping it clocked to the same location. Keep the yellow indicator in the window.
15. You need to remove the steering angle sensor, so unclip the clip on the 12 oclock position to remove the steering angle sensor
16. Then unclip the clip on the 9 oclock position to remove the steering angle sensor
17. Finally, unclip the clip on the 3 oclock position to remove the steering anlge sensor
19. You need to remove the wiper switch first before you take the light switch stalk.
18. After removing the sensor, locate the clamp thats holding the switch, the clamp is at the back at your 12 oclock, just squeeze the clamp thats holding the original stalk switch at the back and wiggle the stalk out towards you.. It might take some time but be patient and wiggle it in and out towards you. The idea is to push it away first to get it off the notch that's holding it then quickly pulling it towards you.
20. you should see this when you take the original stalk switch while depressing the clamp and pulling it towards you.
To remove the headlamp stalk you need to compress the clamp on the back side and pull up the plastic lock underneath the spring at the 12 O'clock position and gently wiggle it off. Its. not easy.... Once you have it off transfer the turn signal switch to the new stalk and reverse the procedures to put everything back.
The new stalk with fog light switch puts in a new circuit that basically grounds the fog light input to the BCM and activates the outputs to power the fog lights along with turning on the indicator.
21. Then install your new brz stalk switch and pull the red lever once its in position, then install the wiper switch.
22-23. take off the original turn signal lights driver and passenger side harness, and make a new one by putting a new pin on the fourth slot. and tappping into the black wire for ground. Refer to..
picture time!
24-25. install fog lights. your choice of hardwares. Just so you know the top is larger than the bottom. So you might wanna buy two different sizes of bolts. Also an Allen stylel bolts works best for me.
26. you should now end up with this
27. turn fog light switch on
28-29. enjoy!
30. Also ere is a fog light indicator inside the cabin!
For more higher resolution pictures please click the link below:
http://s1353.photobucket.com/user/im...%20Light%20FRS
If youre having s hard time following you need to read the first three references for you to fully understand what is going on.. Please take the time to do some research... as I did as well.. But I hope these pictures will guide you.. If you have any questions feel free to send me a message!! Have a good one!
To the op's , if you guys have any suggestion on the write up I can make some changes. As I was rushing typing this down..
The Following 5 Users Say Thank You to imravenit For This Useful Post:
BabaYaga (02-23-2015), charged86 (09-18-2013), civicdrivr (04-19-2013), nigel-jdmparts (04-30-2013), PANDA86 (04-19-2013)
Old 04-19-2013, 06:07 PM   #276
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
^ Thanks @imravenit
Seems like no one is able to get the part number for the EURO GT86 Stalk to enable the rear fogs though.
Tama-Y is offline   Reply With Quote
Old 04-19-2013, 06:45 PM   #277
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by Tama-Y View Post
^ Thanks @imravenit
euro guys doesnt wanna share their parts. bloody basterds lol
Old 04-19-2013, 06:53 PM   #278
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Hopefully I'll have my Euro stalk in a week or two and I'll post up the part number
kmbkk is offline   Reply With Quote
The Following 3 Users Say Thank You to kmbkk For This Useful Post:
civicdrivr (04-19-2013), lbroskee (04-19-2013), Retro86 (04-19-2013)
Old 04-28-2013, 04:56 AM   #279
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
btw how come the fog lights does not fit the legacy socket?
Old 05-03-2013, 01:31 PM   #280
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
@kmbkk
Any word on receiving that shipment? Want to order it soon too.
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
