86WORX
Old 04-08-2013, 02:12 AM   #253
Retro86
Retro86's Avatar
Drives: Awesome
okay guys, finally finished. after a couple of noob moves i got my stuff done.
picture time!
female connector with the lock removed, i took out the black wire just to see which female pin to use
This one rght here as you can see there is a blue plug that you need to push out so you can put your female pin connector.
Luckily i remembered i had a couple of these laying around, its not the same one but i tweaked it a little bit to make it fit
as you can see the bottom left of the connector with the orange/red wire goes directly to your fog socket.
ground it out then test it up, shiii works
finally! thanks guys!
Retro86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Retro86 For This Useful Post:
BabaYaga (02-23-2015), civicdrivr (04-08-2013)
Old 04-08-2013, 03:21 AM   #254
Elite Darkness
Drives: N/A
Nice Retro!
Elite Darkness is offline   Reply With Quote
Old 04-08-2013, 04:15 AM   #255
Sco2355
Originally Posted by FRSFirestorm View Post
Since its a European option there is nothing in the BRZ manual I have. Can't help.
Yes you could.
I was pretty sure there was a small section in that manual for it. I remember seeing it somewhere. I'll have to look.
Sco2355 is offline   Reply With Quote
The Following User Says Thank You to Sco2355 For This Useful Post:
kmbkk (04-11-2013)
Old 04-08-2013, 01:36 PM   #256
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Subarupartsforyou got back with me and said there isn't a separate harness available for sale, so the search continues...
kmbkk is offline   Reply With Quote
Old 04-08-2013, 06:15 PM   #257
Retro86
Retro86's Avatar
Drives: Awesome
or find some harness/pins at the wreckers
The Following User Says Thank You to Retro86 For This Useful Post:
Old 04-11-2013, 12:17 AM   #258
jcat5150
Is everybody just running a H11 plug and splicing the wires?
jcat5150 is offline   Reply With Quote
Old 04-11-2013, 12:38 AM   #259
Sco2355
Pretty much. The fogs we are buying use h11 bulbs so yeah. Couple people did different LED setups, not sure if they use the h11 adapter or not.
Old 04-11-2013, 11:49 AM   #260
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
When I get my FR-S, I would love it if we could get together and have you show me how to do this. It seems like there is minimal wiring to get fogs. I like that.
picture time!
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 04-11-2013, 02:38 PM   #261
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Is this DIY noob friendly?
Enraged21 is offline   Reply With Quote
Old 04-11-2013, 02:43 PM   #262
Sco2355
It is now with the new way to wire it.
The Following 2 Users Say Thank You to Sco2355 For This Useful Post:
Enraged21 (04-11-2013), Retro86 (04-11-2013)
Old 04-11-2013, 06:30 PM   #263
Retro86
Retro86's Avatar
Drives: Awesome
sure. its the easiest wiring i did lol
Old 04-11-2013, 07:10 PM   #264
Elite Darkness
Drives: N/A
Same here, Show me as well
Old 04-12-2013, 12:22 AM   #265
MemphisR
Memphis
MemphisR's Avatar
How are was it to wire the BRZ stock?
Old 04-12-2013, 03:40 AM   #266
Retro86
Retro86's Avatar
Drives: Awesome
the steps on here was on point. the only thing i had trouble with was removing the horn relay and the fuse lol
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
