| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#29 |
Drives: 13 BRZ, 07 WRX
I guess I'm old to and rather wax the car.
So is this Opticoat as expensive as I hear?
13 BRZ Premium. 07 WRX.
#30 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I try to wax most of my cars once or twice a year. The wax lasts longer than most people's cars since mine are garaged all the time, and since I work nights, they don't get the sun beating down on them very much. Might get a clearbra on the front of the BRZ this spring to help protect against (further) cone damage.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#31 | |
Drives: BRZ DGM Limited
And, the Zanio seems to stay on the opti-coat...if I missed a spot buffing the zanio out, that hazy are can be found on the car days later! With the Zanio it makes the surface very smooth and adds another layer of protection. |
#32 |
Member of the year - 2016
Drives: Scion FRS
Opti-Coat is still over hyped.
| The Following User Says Thank You to dem00n For This Useful Post: | ZionsWrath (12-20-2015) |
#33 | |
Drives: Some rust bucket
For the purists, traditional wax is still the preferred method. However, unless you like waxing your daily driver every 2-4 weeeks, then I believe Opticoat is the better solution as far as paint protection goes. |
| The Following User Says Thank You to ayau For This Useful Post: | Zgrinch (02-15-2013) |
#34 | |
#35 |
$70 a bottle, which will be enough for 2-3 cars. The expensive part is the correction process. You want your car to be scratch free before applying the Opticoat layer because it's a permanent coating. It's not mandatory but it's highly recommended.
#36 | |
Drives: 2013 Subaru BRZ MT Limited
That means you MUST clay bar, iron-x and polish your car as well as rub your car down with isopropyl alcohol to remove any oils or residue from polishing BEFORE applying the opticoat. Not only that but any imperfections in applying the opticoat are very difficult to remove because the coating is so hard. It will usually cost someone $400 to get an application of opti-coat by a professional. The cost of a full detailing ($350) plus the cost of a tube of opti-coat.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#37 |
Drives: FR-S MT
I like the spray waxes, they only last a month or so, but you don't have to mask off the plastic and rubber parts on the car.
#38 | |
Drives: MT WRB BRZ Limited, 2007 911s
Personally, I still wax and polish (only the minor stuff, anything bigger is done professionally) with a random orbital during the summer. For the winter, it gets a coat of sealant because I really don't want to be outside once a month freezing my butt off. It's looking pretty funky right now. |
#39 | |
Drives: Murano
I'm from the old school and have polishing cars for 17 years, but even I realize the benefits of this new technology. Ease of maintenance along with truly protecting your paint, coatings are the future, embrace it. Coat your car and top it with wax for nostalgia purposes if you like
#40 | ||
Spaceman
Drives: 2013 Firestorm Scion FR-S
#41 |
Drives: Ultramarine FR-S (MT)
oh look, another opticoat vs wax debate? Pros and cons to each, and to each their own. Though, there is an unusually large opti-coat following on this forum.
I wax my car almost every other month and in between I use some sealant, tire dressing, clean windows, etc. the works. I enjoy every second of it and also because I have the time to do it. I'm not that old, yet I guess I have an old school mentality. It might not be as good as a professional detailer, but it's my own work and i'm proud of it. It's all about convenience and 'soul', much like Manual vs Auto. Waxing has soul
| The Following User Says Thank You to Books For This Useful Post: | TennisHsu (02-19-2013) |
#42 |
I still use Collinite 845 insulator wax. I put on 1-3 coats every year or less. It holds up great, the car stays cleaner and water beads right off. I have tried other synthetic sealants such as Zaino and end up back to using the 845.
Two to three coats of 845 will add that deep wet look that I like. The key is to use good car wash soap from Adams, Zaino or something similar. If you go to the touch-less car wash regularly you will strip the wax of sooner due to the strong chemicals they use. As a former professional body man who has spent quite a bit of time detailing I am not drinking the "opticoat" koolaid. I do not want to add a semi permanent coating on top of the clear. I clay bar my car and touch up what is needed with the buffer before applying wax. That would remove any coating such as opticoat. There is nothing wrong with a quality wax. I got a small dent in my hood driving my car home from the dealer from a rock that fell out of a truck. I also have a few chips up front here and there. For me I will plan on repainting the front in a couple years if the chips get bad. Personally I would rather do that then look at a clear bra. I can do this myself for little cost though. Pat |
| Windows dont auto anymore | _F-R-S_ | Issues | Warranty | Recalls / TSB | 23 | 02-06-2014 11:41 AM |
| Lemon law? Not sure what to do anymore. | yayforaddison | Issues | Warranty | Recalls / TSB | 19 | 12-05-2012 12:14 AM |
| Does anybody use their blinker anymore? | Shagaliscious | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 11-20-2012 03:14 PM |
| Not taking orders for anymore? | Dorb | BRZ First-Gen (2012+) -- General Topics | 22 | 11-08-2012 08:43 PM |
| I can't thank people's posts anymore?? | FRSjeff | Site Announcements / Questions / Issues | 2 | 08-09-2012 09:12 PM |
