86WORX
Old 02-15-2013, 01:32 AM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by LeeMaster View Post
I had a dead spot on my Injen intake until I got it replaced with a better one. The first one I received had some seriously bad welds that somehow made their way inside the tube which to my own guess, disturbs the airflow. How does your tube look like from the inside, is it smooth or does it look like this?
Mine is the aFe. Its not metal but a modeled like plastic. I will keep an eye on things.
Old 02-15-2013, 01:39 AM   #16
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
One more thing I like to add, I currently have an Injen intake and a Greddy Evo 3 exhaust. The last time I reset my ECU I did NOT get a dead spot, only the first time when I still had the stock exhaust /w Injen. Soooo.....I dont know what to explain out of this but just want to share something for you guys for what its worth.
Also, the last time I reset my ECU my mileage was around 4K vs 1.5k when I first experienced my last dead spot after an ECU reset.
LeeMaster is offline   Reply With Quote
Old 02-15-2013, 09:04 AM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
sounds like you've got a bog problem and not a dead pedal problem.
get a tune or put the stock intake back on.
The Following User Says Thank You to xjohnx For This Useful Post:
jflogerzi (02-16-2013)
Old 02-15-2013, 09:32 AM   #18
2forme
If you're on the stock flash it will take 50-100 miles for the ecu to adjust and remove the dead spot. Happened to mine whenever I reset the ecu.
Old 02-15-2013, 03:00 PM   #19
jflogerzi
jflogerzi's Avatar
getting the FA20CLUB Stage 2 tune today. :happy0180:
Old 02-15-2013, 03:06 PM   #20
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
That's how my air raid felt when I first put it on. Now it feels great, I don't remember how long it took, but give it time and drive it.
Asphaltfrs1 is offline   Reply With Quote
Old 02-15-2013, 03:11 PM   #21
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
back in the day i had a roomate who purchased a ebay cold air intake. when installing the cone filter he shoved the filter all the way onto the pipe so that the end of the pipe was mated to the very end of the filter..basically sealing off nearly all air becasue the piping was pushed up agains the rubber end of the filter. He then drove it and the car stalled a few times before he asked for my help then realized he had the filter shoved on the pipe to far.
The Following User Says Thank You to norsamerican For This Useful Post:
ozne99 (02-15-2013)
Old 02-16-2013, 03:02 PM   #22
jflogerzi
jflogerzi's Avatar
This is a much better description. FACLUB20 Stage 2 tune purchased. Whats weird is the "bog" might be making the torque dip more pronounced. I will update the thread when I get my ECU flashed.
Old 02-16-2013, 08:37 PM   #23
jflogerzi
jflogerzi's Avatar
After looking at the install of the intake, I can see where there might be a problem. Its not sealed completely. Only on the bottom side which is hard to see unless you are looking. Wait for the car to cool down before fix it. I will try to post a picture, its hard to see.
The Following User Says Thank You to jflogerzi For This Useful Post:
619_FRS (02-23-2013)
Old 02-23-2013, 06:08 PM   #24
619_FRS
Drives: Ultramarine Scion FR-S
I've been having the same problem with my Injen intake. It bogs out when it goes into idle and its even stalled out 2 or 3 times. I wanna try reseting everything after reading some of the suggestions. Any word from anyone if that solved your issues?
619_FRS is offline   Reply With Quote
Old 02-23-2013, 06:11 PM   #25
jflogerzi
jflogerzi's Avatar
Its better. I think I still might have loss a bit of power. But I think this is due to me running rich on my AFR. Waiting to flash tune file sometime next week. So far no stalls or any idle issues, and no cels.
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 01:33 PM
afe takeda intake installed and lovin it clayrush Engine, Exhaust, Transmission 38 05-06-2016 10:30 PM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) -- General Topics 6 12-08-2012 05:14 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
STEVE JOBS IS DEAD!!! LONG LIVE THE QUEEN! WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 6 10-06-2011 01:22 AM
