#57 | |
Seņor Member
LINK
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | diss7 (12-16-2013) |
#58 | |
Drives: AE86, 2x GT86, TE27
| The Following User Says Thank You to diss7 For This Useful Post: | Turdinator (12-16-2013) |
#59 |
I like those wheel specs.
#60 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Are there still good shops and people that port and polish their heads for japanese engines (of course, I'm sure there is a lot that still do it in the hotrod/domestic world..but japanese head worx is a different story). I remember it was a big thing in the 90s..but it seems most people these days and in the 00s are going straight to FI.
Hopefully some good companies will start releasing NA cams soon...maybe Toda? Imo, a relatively affordably priced NA build (without touching the bottom end) would be a good port&polish + a good set of cams + either mill a little off the head or use thinner head gaskets to raise the CR just a tad...all this could probably be done for around $2k ..which isn't too bad. After that, I would say ITBs (since we are avoiding spending a ton of money on rebuilding the bottom end). But, like the cams/head work, I don't think anyone's released a good set of ITBs yet for the frs/brz. And, if they did, I totally forgot how much these usually go for...I think $5k-10?? And also an ecu to make it work and tune it of course. The last step and extreme setup would be a bottom end build. Stock is already looking honestly decent with 12:1 pistons (similar to ITR already ). But, maybe we can go 13:1 or 14:1 forged pistons. Finish it off with lightened and forged con rods and lightened high rev crankshaft. This will surely make it into a high rev, high compression, monster. But, this would be beyond the budget of 99% of us lol.Realistic for enthusiasts with normal budgets... I would think that a port&polish + camshafts are the best way for NA. For hard core racers and people with big budgets... the above (cams + port&polish) + ITBs + fully built bottom end for NA. |
#62 | |
Drives: toyota mr2/ Toyota GT86
thing is whats the bottom end good for on rpm anyway? as folks are saying it needs a stronger valve springs to up the rev limit so yes you also need some cams and a shorter inlet tract to get it to tune higher up but what are we going for here on standard pistons, rods and crank 9K? 10K? Is anyone doing this and doing it reliably? I'd say cams are coming but I doubt they'll push the rev limit up |
#63 | |
#64 |
Stig's dark passenger
NA power:
FB25 crank Custom rods 14.5:1 pistons e98 tune ~210-220 to the wheels |
#65 | |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
[CENTER]
Build thread |
#66 |
Drives: UM86 - 6MT
True but its getting closer to 200 whp on 91/93. I saw a thread, I would need to find it, where someone hit 193 whp on 93, which is pretty darn good.
#67 | |
I was going to run either 205/45/16's or 225/45/16. Toyo make a few models in that size, R888, R1R, T1R; Federal have 595 SS and EVO in those sizes as well. All around $200 - $280, which isnt bad in NZ. |
#68 |
WUB WUB
Drives: 2013 Firestorm
i managed to get 200.5 on 93 octane. it's in my build thread before the box of happy. We might have been able to push it beyond 200 with more work on the tune, but not sure.
| Will Demon Eyes affect light temperature output? (also the legality) | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2013 06:37 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 05:42 PM |
| Control Your Thorttle Output with the Weapon R I-Throttle Controller !! | PRO Import Tuners | Engine, Exhaust, Bolt-Ons | 16 | 08-14-2012 08:10 PM |
| Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 329 | 10-16-2011 09:51 PM |
