#29 |
Drives: Attitude
Yep, but doesn't balancing require the entire rotating assembly? May as well say fuck it and do pistons too!
#30 | |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
truth, exactly why F1 cars have like no trq but all hp up top its about the cornering and use of the power rather than the trq. you dont want wheel spin you just want rotation increase |
| The Following User Says Thank You to DanoFA20 For This Useful Post: | TouchMyHonda (02-08-2013) |
#31 |
Drives: Whiteout Scion FR-S
Here's what Toyota did with 100 octane race fuel and just a few mods:
http://www.ft86club.com/forums/showt...ota+grand+prix
#32 | |
Add lightness!
Drives: 17' WRX
#33 | |
And yes, I do agree, that the FA20 is rather impressive that it makes 200hp at *just* 7000 RPM. I'd gladly sacrifice some driveability for more top end hp. AUC for the powerband I use on track is what I care about. |
#34 |
MODERATOR-SAMA
Drives: Swagtron Scooter
I think 190-200whp is doable on this engine with a budget, around 15k at the most if you do the work yourself. I think the limit to this engine would be 280hp.
But then again this engine in particular has a bit of mystery to it, I don't know any other 2.0 4 cylinder n/a than can scavenge peak TQ at low RPM...which leads me to believe that intake acoustic tuning makes much more drastic changes to the efficiency of the output. I also don't know any 2.0 4 cylinders n/a that make 200hp or more without aggressive cam profiling like vtek or some serious blueprinting. if you compare all the engines together in the same class. including the R500 duratec engine, and the K20Z ariel atom mugen. The FA20 with only 200hp is pretty impressive for being an average production engine
#35 | |
Kuruma Otaku
If people want to make mid range or high end power with a header it will be by paying attention to which returns occur at what rpm. For maximum effect, the same should be done with the intake system and resonators.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | WingsofWar (02-08-2013) |
#36 | |
Vtec Jesus
| The Following User Says Thank You to TouchMyHonda For This Useful Post: | WingsofWar (02-08-2013) |
#37 |
Red wine
Drives: Subaru BRZ(R.I.P)
You might also want an oil cooler if you plan on tracking your car. Also, lightweight underdrive pulleys would be something to consider as well if you want to maximize power for racing. Getting rid of unsprung weight would be beneficial.
#38 | |
Drives: Nevermorange FRS
All good points, especially about the F20C. That's part of the reason I have looked at racing a Supercharged S2k as opposed to a N/A one because of how it makes power. The F20C makes its peak power right at the moment you need to SHIFT! It really needs to rev to 10k. Which is possible but then the calculation for cubic dollars spent changes.
Consider a ruleset like that of Improved Touring. I'm thinking the Twins get classified into IT-R when they are eligible to be so (must be in production for 5 years). In Improved Touring you're allowed to balance/blueprint/mill and increase piston size by .040" but you are not allowed to increase compression by more than .5 point. So buying fancy forged/high compression pistons would be unnecessary/disallowed. Also, since IT doesn't allow for head porting or cams then pursuing a higher red line would be an exercise in futility if the stock head/cams won't facilitate it. The problem I see with IT-R is the weight penalty the Twins might receive. Currently the S2000 has a minimum weight of 3005lbs. Awful. I bet if the FRS was classed in IT-R it would have a weight penalty putting it at something like 2800lbs or higher.. ugh. Other classes are Like SPU, ST (Conference ST not SCCA), or NASA Performance Touring (PTE, PTC..etc). The FRS could be a really fun PT car. I was hoping some guys like Visconti would chime in and say something like: "yeah, we can do 215whp on 92octane with bolt-ons!" However, I think may have set myself up for disappoint.
SCCA T4 - FRS
#39 |
Drives: Attitude
Lightweight pistons, to reduce rotating mass?
#40 |
Kuruma Otaku
@rice_classic
What does IT say about valves and how do they define porting? If you are allowed valve replacement and seat modifications, you could pick up some low lift flow by going to bigger valves and seating them properly, maybe 5 angle job.
Because titanium. |
#41 | |
PT it's allowed but I believe you take a "point hit" on that. Would need to verify. However, many racers like having their car be legal for multiple classes. Right now my car is legal for ITA, PTE and H4. If I did the "lightweight" pistons it would disqualify me for ITA and H4. Kind of a bummer but a challenge folks face on deciding to build their cars to the "limits" of the rules or build it to be competitive in multiple classes so a racer can race with more than 1 organization.
IT it's not allowed. Piston must be of factory dimensions including weight with the exception of being .020 or .040" over bore. Quote:
You are not allowed to change the valvetrain beyond OEM parts and spec. The ONLY thing you can change in the valve train is the valve guide material which is "unrestricted". The rule book doesn't say anything about oversized valves and valve jobs. That's how you know it's not allowed. IT Rules work like this: "If it does not say you can then you cannot." That simple statement go a long way at simplifying things. Every once in a while I'll hear a conversation at the track that starts out like this: "So show me where in the rule it says you can do that..." Uh oh!
SCCA T4 - FRS
#42 |
LOL,
Just saw this thread: http://www.ft86club.com/forums/showthread.php?t=24283 300bhp with full-race valvetrain. Like Orbital said that thread: E85 or RaceGas most likely. Still though... That's quite nice for guys looking to play with their race cars in classes that allow this type of modifcation but don't allow FI. Super cool.
SCCA T4 - FRS
| Will Demon Eyes affect light temperature output? (also the legality) | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2013 06:37 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 05:42 PM |
| Control Your Thorttle Output with the Weapon R I-Throttle Controller !! | PRO Import Tuners | Engine, Exhaust, Bolt-Ons | 16 | 08-14-2012 08:10 PM |
| Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 329 | 10-16-2011 09:51 PM |
