#29 | |
I think that people associate the top of the tire with the fender as being "flush" which is what a 25mm spacer does. Sadly, there is a touch of "stretch" on the stock rims with the stock tires, leaving a bulge sticking out past the rims. It simply wasn't working for me. This looks GREAT on muscle cars where the tire is wider than the rim, but when the sidewall sits out further than the tread of the tire, it looks like it has a spacer IMHO (might change with different tires or more camber as MPI_Jack mentioned). Sorry to argue on this. I literally have the car sitting right in front of me. I can take pics of what ever you want. You can see in my pics on post above. (Sorry, just took these pics. Car is dirty, and I haven't driven it in a couple days) ![]() ![]()
| The Following 2 Users Say Thank You to suaveflooder For This Useful Post: | DAEMANO (10-21-2013), Trettiosjuan (02-26-2015) |
#30 |
Time Traveller
@suaveflooder Not that I'm trying to get into some internet debate about it, but I also have tons of pics with 25mm in the rear & 20mm in the front and it does not poke at all. The wheels (and tires) are flush with the top of the fender. Same with a lot of other people on the board. Don't know why yours were poking at these sizes, nobody else I've seen has reported that. The stock tires do have "sidewall protection" (an extra layer of rubber on the sidewall that makes them look stretched when they're not), but even that really doesn't seem to poke at these sizes.
http://www.ft86club.com/forums/showp...3&postcount=72 http://www.ft86club.com/forums/showthread.php?t=22596 http://www.ft86club.com/forums/showthread.php?t=42516 http://www.ft86club.com/forums/showthread.php?t=27873 And my FRS with 20mm and 25mm REAR - Raven FRS 25mm spacer vs stock WRB BRZ As you can see the rear 25mm on the Raven FRS has another 5 - 10mm of gap still available to be filled if someone wanted to go 30mm. ![]() Another pic same car 25mm Rear - 20mm Front - Neither is poking whatsoever beyond the top of the fender. ![]()
| The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | Astroboy (09-14-2015), suaveflooder (10-21-2013) |
#31 | |
Wheel Spacer Size??
If you look at the pics closely, the TOP of the tire is very close to even with the fender. It's not easy to see in pictures, but in person, the tire would be past the fender. That's what I didn't my like on mine |
| The Following User Says Thank You to suaveflooder For This Useful Post: | DAEMANO (10-21-2013) |
#32 |
Drives: Subaru BRZ Limited
I had stock wheels with Sportlines for a few months. 20mm front looked great. 25mm rear looked good, but sometimes I felt like it was a bit off. From a side view I'd see too much shadow on the top of my tire and it would look like the rear needed to come out more. If I looked at the car from the rear however it looked like the wheels poked out a little from the frame which I did not like. It's hard to say what is perfect. Nothing is going to be perfect for everyone. It's just a matter of what look you feel is closest to what you want.
#33 |
I have a new question about wheel spacers. I'm looking for 10mm wheel spacers for my front wheels. 15mm is poking out a little too much for me.
Can I just order any 10mm spacer that is 5x100? Or is there something else I should be looking for? Just want to make sure before I purchase anything.
#34 |
Drives: 2013 BRZ WRB
![]() What setup is on this spacer and spring combo? (20mm front 25mm rear spacer?) springs?? This is perfect for stock wheels!
#35 |
Drives: old
Has anyone noticed any difference in steering feedback with the spacers?
#36 |
Drives: 86 & GRB
I have a question. Do I need someone to step on brake to get the hub to stay still when torqueing it down while it's in the air? Can it be done alone?
#37 |
Drives: 2013 Subaru BRZ
#38 |
Drives: 86 & GRB
#39 |
^putting the car in gear and yanking the handbrake doesn't do much to the front hubs.
#40 |
Drives: Toyota GT86
Do we have to cut the stock bolts to get the spacer n wheel fit ?
Lets say H&R 20mm front, H&R 30mm rear. As I saw somewhere they said that 20mm I'll have to trim the front stock bolts ? |
#41 |
Depends on wheels. I highly recommend doing it right and just replacing the stock studs with lingers ones. With hub centric spacers they just against the hub and wheel once torqued down to spec. If your after market wheels have pockets next to the lug holes then you can buy spacers that have built un lugs into them
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
#42 |
Drives: fr-s
I see alot of questions and I have run spacers on a lot of cars so here's stuff I learned
1. front hub you would do best with a air gun doing it with a torque wrench wont really cut it unless you have a friend with their foot on the brake. 2. If you run multi pattern wheels the stock lug may protrude from the spacer if its a press in. you have to run 25mm for no protrousion but stock rims this isnt a problem for. 3. Use some anti sieze on the sock and spacer lugs. 4. I would likely run open ended or extended lugs with spacers if the spacer lugs are extended. 5. Dont over torque the lugs- 90lbs should be the most. Hope this helps |
| The Following 3 Users Say Thank You to executivekoala For This Useful Post: |
| Wheel Size vs. Balance | jellygorilla | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-11-2012 02:23 PM |
| wheel spacer to 5x114 | derka-derka | AUSTRALIA | 12 | 07-03-2012 12:27 AM |
| Wheel Hub Bore Size | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 01:01 AM |
| Wheel size and fitment | bsclywilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 03-27-2012 01:34 PM |
| Wheel size, what's your opinion? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 02-24-2010 04:06 PM |
