#29 |
Drives: 2013 Subaru BRZ Limited AT
Sorry, I'm confused - is 215/45R-17 larger or smaller than 225/45/17?
#30 | |
86 Noob
Drives: Firestorm FR-S
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
#31 | |
Drives: Venza, Mustang, Acura, F150
#32 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
#33 | |
Shift Down
if anything youll have more tread and a bit more tire surface to the ground i may do this size or might just go factory size with way better tires havent decided yet
#34 |
Drives: asphalt fr-s
i actually like the stock rims on my asphalt . i do think they are sharp looking. just i too hate how skinny they look. so you guys are saying 225/40/17 is the widest i can put on this rim? will it look alot fatter at least from behind?
#35 |
Drives: Scion FR-S
Tires have shipped. I'll snap some pics as soon as I get them mounted. You might be able to go up to a 235 but it will depend on tire and wether you are going for a certain look or ultimate performance.
#36 |
Drives: 2013 Whiteout FR-S AT
You probably won't notice too much of a difference. 215 to 225 is only 10mm, less than half inch
#37 | |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#38 |
Drives: Skoda Yeti DSG diesel 4x4
That size will make the speedo over read by another 2.2%. Why not fit 225/45-17 which are 1.3% bigger and will make the speedo more accurate?
#39 |
Drives: BRZ Ltd WRB
I drive 225/45-17 PSS on 17x8" rims and am very happy with the overall performance; dry, wet, track, threadwear. For ultimate dry grip I would check out the new Dunlop ZII or go with the well proven Yohohama AD08. I think the ZII's will kick ass in the next tirerack test.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
#40 |
Chief
Drives: 2013 DGM BRZ Premium 6MT
But the OP was looking for the stock rim, which is 17x7, not 17x8.
From this thread, it looks like going from 215 to 225 won't be too bad, but as some others have said, I would like to see some pics of these mounted. |
#41 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
#42 | |
That looks like a very worthwhile increase in the actual contact area and it also looks a fit instead of being stretched. From that pic 235/45-17 would be be too much for the 7" rims. From the initial owners dislike of the OEM rims i've had many favourable comments, so i'm not in a rush to change them but the tyres are way below the requirements of this car. |
| Tire +/- size guide for FR-S/BRZ | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 12-11-2016 01:12 PM |
| Tire size advice | Lost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 11-28-2016 07:42 PM |
| Tire Size help! | J-Money | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-04-2013 01:04 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| A Simple Tool for Tire Size | DIE1000DEATHS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-30-2012 06:05 PM |
