#15 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
You can't just look at the number because the brands are different. 215 star specs are as wide as 225 stock michs. Sounds from the above guys that the PSS are wider as well.
#16 | |
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Azenis has changed their tread design and compound, and has fallen far from where it was in the mid-2000's, but much stickier than a all-season. Check out vulcantire.com for current pricing, usually pretty reasonable. Most of the tires I have spoken about aren't great in heavy rain, and pretty sad in any snow, so caveat emptor. As for the Conti DW's, check out the Nitto Invo's for complete tire 'rotationability.' With respect to all seasons/non-stickies, check out the Kuhmo Ecsta 4x. A bit cheaper, I put a set on my Focus SVT before my 5k summer trip and was waaaaay happy with them, and I believe according to tirerack, they scored better than the conti's, IIRC. Eric G |
#17 |
Drives: '15 STi Ltd
#18 |
Drives: 2015 Mustang GT (on order)
I'm just about to order some Conti DW in stock size for the stock rims. No increase in weight, a lot more grip...sounds good to me.
| The Following User Says Thank You to jeebus For This Useful Post: | DanoFA20 (02-10-2013) |
#19 | |||
Drives: '23 BRZ
So, speedo most likely *is* more accurate with 225/45-17s. But odometer most likely will read low... Quote:
Strictly dry grip, Dunlop Direzza ZII and BFG Rival probably have more. But on the street, PSS is up there with *Spec, RS3, AD08 in the dry, and much better in the wet: http://media.caranddriver.com/files/...res-tested.pdf Quote:
#20 | |
Drives: Skoda Yeti DSG diesel 4x4
http://www.iwsti.com/forums/3302084-post1.html |
#21 | |
Seņor Member
Drives: white BRZ 6MT
that's going to make a big difference, and not to mention that brz/frs have stiffer springs vs weight vs the sti
#22 |
Drives: Subaru BRZ
That post is for the Conti DWS - all season tires. He eventually changes over to the DW and thought they were great.
#23 |
#24 |
Drives: 2015 BRZ Limited 6MT
Anyone have experience with the 245/40/17 on a stock rim. Will they fit without rubbing?
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
#25 | |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
id saygo with a 225/45/17 or 40/17 |
#26 | |
Shift Down
#27 |
Drives: Scion FR-S
I've decided to go with 225/45/17. Looks like this size come stock on quite a few cars with 17x7 wheels. It's more of a look thing for me than additional grip.
#28 |
Drives: Scion FR-S
show us some pics if you get a chance
| Tire +/- size guide for FR-S/BRZ | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 12-11-2016 01:12 PM |
| Tire size advice | Lost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 11-28-2016 07:42 PM |
| Tire Size help! | J-Money | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-04-2013 01:04 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| A Simple Tool for Tire Size | DIE1000DEATHS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-30-2012 06:05 PM |
