#71 |
Which SPC arm did you get?
#72 |
frstrm-frs
Drives: Red FR-S
#73 | |
Drives: 2013 FR-S Argento
If you're fixing uneven camber in the rear with LCA's on lowering springs, then you had uneven camber on the stock springs (which is common) Camber adjustment in the rear with a mild drop (1") is overrated for those who want a 'budget' drop. Bottom line, if you're fine with the way your car handles on stock springs, you'll probably be ok with just lowering springs and no rear camber adjustment. Camber will increase yes, but not excessively so - you still need alignment to make sure your toe is correct. Are adjustable LCA's better? Sure, but I'm seeing a lot of people saying they're *required*. For a 1" drop, they're not, especially for those who are just street drivers. Also spring for crash bolts for front, dial in an extra bit of camber on the fronts. |
#74 | |
frstrm-frs
Drives: Red FR-S
#75 |
Drives: Subaru BRZ Limited
Hey guys, I had Sportlines put on my car a week ago. Ever since then I've definitely noticed the ride is a lot harsher and I can hear clanking in the rear tires. Could something be loose or do you think my shocks are screwed up already?
What would be my options to get the ride quality back while keeping the car on the Sportlines? I see a lot of posts about Koni yellows. Are those just after market struts that you swap with the factory in order to improve the ride quality when you lower your car? I appreciate any feedback. I'm going to take my car back to the shop and ask if they can check out the struts to see if they are damaged. If so then I'm definitely just going to buy something upgraded so that the ride isn't so bumpy. |
#76 | |
Drives: 2013 Subaru BR-Z Limited
I'm almost to 10k miles and my stock shocks have held up great..really surprised!! Once I install my turbo setup and start spending more time on the track and less on the streets I will be installing coilovers but for pure street use, I think the sport lines are the best option available. Great ride, handling, and looks all at an affordable price backed by a hive company with awesome customer support. Great choice on springs..just get the install checked out as it should be quiet as stock.
| The Following User Says Thank You to chadstyle For This Useful Post: | ericmpena (09-23-2013) |
#77 |
Master Troll
Drives: 2013 BRZ Limited
I am also on sportlines and only notice the harshness on big dips on the freeway. I'm trying to figure out my rear camber as it is currently a bit negative and I can't figure out if its the alignment shop or if I need rclas.
Sent from my XT1080 using Tapatalk 2 |
| The Following User Says Thank You to Thongpocket For This Useful Post: | ericmpena (09-23-2013) |
#78 |
Update: took the car back to the shop and they knew what the issue was right away. The rear sway bar was a little loose. No more clanking! Thanks for your input guys. I was starting to regret getting the Sportlines. I had renewed faith again.
#79 | |
#80 | |
I do lift the inner rear wheel when pulling into steep drives at a sharp angle and low speeds but when cornering the car has been AWESOME!
| RS*R Lowering Springs Soon to be out! | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 01-16-2013 03:39 PM |
| Lowering springs HELP | FRS_13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-27-2012 11:03 PM |
| Mach V Lowering Springs! | Mach V Dan | Brakes, Suspension, Chassis | 0 | 08-01-2012 01:14 AM |
| Coilovers or lowering springs | Hawk77FT | AUSTRALIA | 9 | 07-30-2012 10:41 PM |
| Lowering springs? | Jeff Lange | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-11-2012 12:36 AM |
