| Member's Car Journals Car journals by our members. |
| View Poll Results: If I were to repaint/vinyl wrap this car, what color should I go with?? | |||
| Stay with Lightning Red! |
42 | 45.16% |
| Silver |
0 | 0% |
| Gunmetal |
26 | 27.96% |
| Black |
5 | 5.38% |
| White |
6 | 6.45% |
| Other |
14 | 15.05% |
| Voters: 93. You may not vote on this poll | |||
#197 |
Just a dude
Drives: Scion FR-S 2013
There's been talk of this new Excedy STG 2 clutch having no chatter and slightly heavier peddle feel over stock and suppositively very DD friendly. Is that accurate in your opinion??
#198 | |
Track Junkie
Drives: 2013 Subaru BRZ Limited, 2005 S2000
I have one issue where sometimes it's difficult to get into 1st gear (at times it feels like the gate isn't fully open) but I also had this issue with the ACT clutch. Having said that though, my situation is a little different due to the engine/transmission mounts and LSD so my observations might be a little different than someone with a stock car.
#199 | |
Just a dude
Ok and no chatter that you have observed as of yet?
#200 |
Track Junkie
No chatter so far
| The Following User Says Thank You to ImperiousRex For This Useful Post: | OICU812 (07-07-2014) |
#201 |
Boosted
Drives: Not a supra....yet
I would recommend pushing your rad forward, it would help you a decent amount
#202 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#203 | ||
Track Junkie
The point about boost is valid though. The boost chart didn't taper off at higher rpm's so I had ruled out a boost leak but perhaps something else is going on regarding heat expansion with the piping inside the engine bay. We also had another FI FT86 on the dyno that day and the power loss was similar at those IAT ranges. I'm pretty sure the ECU is pulling timing at that heat range but we'll be back on track at the end of the month and I'll try to get the datalog for you then.
#204 | |
NASA SpecE30 Racer
- King Tut
#205 | |
Track Junkie
Also after re-reading through my updates, I don't want to come off as demeaning the turbo kit in any way. The design comes with some inherent issues but overall the car has been pretty solid after many hard track days. I think it's a testament to Greddy's quality control and the issues are just giving us a clearer path to improve the car
#206 |
Cliuless
Drives: Whiteout Scion FRS 2014
How loud is that Greddy exhaust? I've had my eyes on it for a while. Will it draw too much attention? I DD my FRS.
#207 | |
Track Junkie
![]() [ame="https://www.youtube.com/watch?v=qNLKubCqMhk"]Silent but Deadly turbo BRZ - YouTube[/ame] But in all seriousness, I like the exhaust quite a bit. The 70mm diameter was a selling point but so were the silencers that it comes with (which are demonstrated in the video above). Certain tracks like Laguna Seca have a strict dB limit and I wanted to be sure that I had an option to quiet it down if I needed. When I'm running a straight pipe and no silencers with the turbo kit however, the car gets loud inside the cabin. For some reason the noise doesn't travel very far from the car but it all seems to channel inward
Last edited by ImperiousRex; 07-07-2014 at 01:31 PM. Reason: Forgot to add the quote... |
#208 | |
There is a very weak correlation at best. Lets dig into why this is. As the IAT gets hotter, it has a larger differential from ambient. The psi coming out of the turbine is the same, but because the IAT is hotter, the air is cooled more (relatively speaking) by the intercooler, causing a large pressure drop. While the PSI is lower, the mass of air flow into the engine has not changed from before/after the intercooler. The absolute mass is lower, since the turbo itself is not able to pack as much air into the same amount of volume. Remember, PSI is a pressure measurement, not a flow measurement. If you look at datalogs, the heat soaking happens within the first outlap. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ImperiousRex (07-12-2014) |
#209 |
Drives: 2013 Scion FRS
this build is so amazing
| The Following User Says Thank You to Fresh86 For This Useful Post: | ImperiousRex (07-12-2014) |
#210 |
Drives: 2018 Subaru BRZ
Subscribed!
On my fourth 86... and everything in between
| The Following User Says Thank You to Scracho For This Useful Post: | ImperiousRex (07-19-2014) |
| StockySnail's Lightning Red 6MT BRZ Limited Build Thread | stockysnail | Member's Car Journals | 205 | 12-22-2022 09:26 PM |
| LIGHTNING RED BRZ Compilation | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 408 | 05-29-2020 01:47 PM |
| The lightning lap | Gixxersixxerman | FR-S / BRZ vs.... | 35 | 09-17-2014 02:15 PM |
| Lightning Red Ft 86 | Acid18 | Member's Car Journals | 6 | 12-28-2012 03:27 AM |
| SD: Lightning Red BRZ Limited 6MT tastefully modded | epson1 | Cars for Sale/Trade | 2 | 09-24-2012 01:56 PM |
