Old 02-01-2013, 10:13 PM   #1
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
A/T BRZ fitted with AVO Stage 1 Turbokit
Drift Office just finished up the install of the AVO Turboworld BRZ/FR-S Stage 1 Turbo Kit on a BRZ Automatic. The turbo kit supplied was our first full production kit with the updated exhaust manifold, heat shield and other touch, and with the full ceramic coating. From their report, the install went smoothly with little to no issues. Straight onto the dyno it went, flashed with our Stage 1 basemap for the Automatics.
it's a little rich, but it was running on 92 octane vs. the 91 octane we have planned for as minimum
The dyno runs were done at 4.7psi with a stock cross-over pipe, stock secondary catted pipe, and a HKS 2.5" resonated cat-back exhaust. Wheels were 18-inch TSW Nurburgrings. No other modifications.
Gains are quite good for the bolt in and go setup with basemap. And it comes in quick!
AVOturboworld is offline   Reply With Quote
Old 02-01-2013, 10:48 PM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I'm sure Bob will be massaging a bit more out of this as well. Very nice!
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 02-01-2013, 10:50 PM   #3
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
@brzranger - I should ride along with you sometime soon. I want to feel that turbo
mechaghost is offline   Reply With Quote
Old 02-02-2013, 02:04 AM   #4
AVOturboworld
[ame="http://www.youtube.com/watch?v=WM4M6r267dc"]Automatic BRZ with AVO Turboworld Stage 1 Turbo Kit - YouTube[/ame]
Old 02-02-2013, 02:16 AM   #5
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Was waiting for this!!
Congrats on MO POWA, David!
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 02-02-2013, 02:50 AM   #6
thebear21
thebear21's Avatar
Drives: scion fr-s (RIP)
awesomenesss!!!! thank you!!!
thebear21 is offline   Reply With Quote
Old 02-02-2013, 08:22 PM   #7
mact
Drives: 13 GTI
Originally Posted by AVOturboworld View Post
What is that hose/tube going to nowhere at the 00:35 mark?
mact is offline   Reply With Quote
Old 02-02-2013, 08:30 PM   #8
AVOturboworld
That's the now-useless sound tube that goes into the passenger cabin.
Old 02-02-2013, 08:37 PM   #9
BRZranger
For sure!
BRZranger is offline   Reply With Quote
Old 02-02-2013, 11:05 PM   #10
peter-tai
Drives: toyota 86
Good job!
peter-tai is offline   Reply With Quote
Old 02-03-2013, 12:19 AM   #11
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Install Mini-Review
So here are my thoughts on the first PRODUCTION AVO Turboworld Turbo Kit for the FRS / BRZ.
This being our second install, I can clearly say that the fit and finish is MUCH better than the pre-production model we had previously. The quality of the ceramic coating too, is well worth the extra dollars.
Truthfully, the kit will take you somewhere between 10 and 12 hours to install, given an average and depending on your skill(s), your mileage will vary of course. Upon unpacking the kit, you'll find a comprehensive manual (in ENGLISH) that would serve you well as a guide as you go down the path of force induction; know that with each passing page, you are THAT much closer to achieving your next "upgrade" for the car.
There are bags clearly labeled that correspond with the parts list in the manual, and almost everything is supplied sans a pair of gloves and some basic supplies like grease / lubricants and tools. Just about the only thing we found to be of a hindrance in completion was how tight fitting everything is, fittings included. I suppose when you build it to a certain tolerance and knowing how little room we have (relatively speaking) - AVO has done an incredible job here.
When working on custom jobs of any sort, it pays to be prepared. I was pleasantly surprised that after our through installation, nothing leaked, and everything worked as we put the vehicle on the dyno for our Pro-Tune session... But that's another story altogether.
The bottom line : If there was an OEM level turbo kit for the FRS / BRZ, it would be AVO, no question about it!
My 2 cents!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 02-03-2013, 02:16 AM   #12
Drift-Office
Tuned Stage 1 Result YouTube Video here :
http://www.ft86club.com/forums/showp...0&postcount=18
Cheers!
Old 02-03-2013, 04:11 AM   #13
sw20kosh
Drives: 2013 Black FR-S
That's quite a useable powerband lol wow
Old 02-03-2013, 04:23 AM   #14
Drift-Office
I'd say...
  • 215 WHP / 176# TQ (SAE Corrected) @ 4.6PSI (Stage 1 Tuned)
  • Peak Boost @ 2700 RPM (!!!)
  • > 150# Torque 2700 RPM - 7000 RPM
Now just imagine what Stages 1.5 & 2.0 would do...
Cheers!
Search this Thread:
Advanced Search
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
DBA T3 rotors fitted AVOturboworld Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-16-2013 02:28 PM
BRZ fitted with LS2 V8 Tman08 Engine, Exhaust, Transmission 9 12-13-2012 06:28 PM
1st FR-S TRD Kit fitted w/jdm lights SpecPer Cosmetic Modification (Interior/Exterior/Lighting) 160 09-08-2012 12:32 AM
Anybody fitted any STI bits yet ICantAffordAnLFA BRZ First-Gen (2012+) — General Topics 4 07-12-2012 07:59 PM
