86WORX
Northwest AK, ID, OR, WA
Old 02-01-2013, 04:22 AM   #15
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by BRZPDX View Post
Yea I wasn't too crazy about their service, but again I expect an un professional style from a tuner shop, and perhaps that is attractive for the tuner crowd.
Had to reschedule my alignment since I waited there for 2 hours, and noticed my car was still in the lot, untouched. I think it is pretty typical, and having low expectations with tuner shops is the attitude I go in to mitigate frustrations.
I usually (after dealing with cobb perrin and pre and other local shops) clear my day of when my car is being worked on. Usually do it on a day off and chill ahaha. weird if you had an appointment and waited 2 hours though?
NickFRS is offline   Reply With Quote
Old 02-01-2013, 02:22 PM   #16
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
So uh, no one is asking what this "other software" is? Or did I miss that?
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 02-01-2013, 11:45 PM   #17
NickFRS
Have more info monday
Old 02-02-2013, 02:48 AM   #18
seven
Tells it like it is
seven's Avatar
Cool
Old 02-13-2013, 09:49 PM   #19
NickFRS
Went in today to put down my $300 bucks for the tune. They didn't go with ECU Tek. They went with a the new tuning software. It's very similar to open source and this month will only cost $300 bucks to tune your car. You don't need to buy a cable or license of any kind. After their 50% off FEB TUNE special the tune will cost $600. My car will be the first tuned and i'll post dyno graphs n what not after. More info coming soon.
Old 02-14-2013, 02:13 AM   #20
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
What is the tune gonna be like? do they take parts off the car and put them back together? How long is the tune going takes? couple of days?
Old 02-14-2013, 05:29 AM   #21
NickFRS
Old 02-14-2013, 05:32 AM   #22
NickFRS
Software is called BRZedit
Old 02-14-2013, 01:57 PM   #23
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Most likely just an ECU reflash. It shouldn't take too long.
P.S. guys can we try to answer these questions in an adult manner? I hate to see new car enthusiasts mocked just for asking a question.
Freeman is offline   Reply With Quote
Old 02-14-2013, 09:40 PM   #24
NickFRS
Tuning process: (How it usually works)
Bobby will take your car and put it on the dyno. Strap it down. Then hook everything up. He will then do a base pull to get a data read out. Basically see what your ECU is doing. AFR levels, Timing, Tuning stuff. Then he will adjust all the various things he can and start doing pulls until he finds what he is looking for in the brain of our cars. This isn't a reflash and you drive away w.o actual real time adjustments made on a dyno. This is an actual dyno tune. Most tunes take 5-30 pulls on the dyno to get perfect. But as soon as you get in your car and drive away you will be like
^ it's in the first post. But yes it's changes to your ecu. Bobby puts your car on the dyno and changes stuff does some witchcraft and makes your car go faster. This is a tune that is made directly for your car on the dyno. You get real time info. also a before n after dyno sheet. Bobby will also explain to you what he changed/did and why he did it. Give PRE a call if you want to ask the professionals about the software and how they tune the car.
*edit add*
But PRE can do anything you want. Even boost your car or make a custom exhaust. Just call n ask. They can also order any parts you may want or need.
Old 02-14-2013, 10:11 PM   #25
NickFRS
*edit add*
*second edit* wasn't trying to be mean.
Old 02-17-2013, 12:45 AM   #26
NickFRS
[ame="http://www.youtube.com/watch?v=yDnIcm_7bFo"]PREracing Harlem Shake - YouTube[/ame]
Old 02-26-2013, 12:09 AM   #27
NickFRS
Posting results tomorrow night.
Old 02-26-2013, 10:12 PM   #28
wrohdejr
Drives: 2013 subaru limited wrb brz
Looking for the results of the tune?
wrohdejr is offline   Reply With Quote
Search this Thread:
Advanced Search
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
August 26th KOP Meet @ 4:00PM Laika NY / NJ / CT / PA 99 01-22-2013 01:50 PM
SCCA - Solo 2 - San Diego - Aug 25/26th whataboutbob Tracking / Autocross / HPDE / Drifting 25 09-06-2012 02:08 PM
Wekfest Event in Edison, NJ - Aug 26th kykiee NY / NJ / CT / PA 1 08-26-2012 12:53 AM
Open Track Day - Big Willow Aug 26th fastlaneracingschool Tracking / Autocross / HPDE / Drifting 0 08-24-2012 01:32 PM
