Old 01-31-2013, 08:57 PM   #85
wootwoot
Drives: FRS
UPDATE:
It has been confirmed that the IS300 doesn't come with a final drive of 4.55. I just got off the line with the Lexus parts department in my area....
What I have learned:
The IS300 and IS250 have different differentials as well as different axles. There is no way both of them will bolt on to the 86. It would have to be one or the other as they bolt up differently and have different axles.
Also, even if one did fit, they never came with a 4.55 final drive, at least not in the USA.
Seems that my dreams of an easy swap have been destroyed. Carry on....
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
duder (06-01-2013)
Old 01-31-2013, 09:37 PM   #86
J-Money
J-Money's Avatar
Drives: GT-86
The cusco 4.55 is a direct swap? no mods? just take out the old put in the new and boom?
J-Money is offline   Reply With Quote
Old 01-31-2013, 09:53 PM   #87
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
I will def. be looking for more info on this. Its funny, I have never heard or thought about doing it before and my friend actually suggested it a lunch today before even seeing this.
thanks RCE!
JadeBRZ is offline   Reply With Quote
Old 01-31-2013, 10:06 PM   #88
Racecomp Engineering
hence my thread...yes.
mw
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
NWFRS (07-16-2015)
Old 01-31-2013, 10:30 PM   #89
thanks RCE!
No worries. I personally think this is one of the best mods if youre staying NA.
Myles
Old 01-31-2013, 10:50 PM   #90
Originally Posted by TouchMyHonda View Post
Sick tits. I have a 4.785 fd in my 5 speed trans. I sit 5k exact at 80 mph in top gear. With 240whp I never down shift on the highway ever haha.
THATS SICK !!
YOu can also rev to 9900 rpm too!
Myles
Old 01-31-2013, 11:15 PM   #91
kosoku
Drives: 2013 fr-s
wow, this is a refreshing post! I've been trolling this forum and haven't seen anything like this yet!
Good information. Keep on posting!
kosoku is offline   Reply With Quote
Old 02-01-2013, 01:07 AM   #92
4U-GSE
Drives: 2013 Scion FR-S MT Ultra Marine
If you switch to a 4.55 FD, won't that lower the shift points on your car? For example, let's say I am on a track with the stock FD and I come up to a corner that I can take with an entry speed of around 55 mph and an exit speed of about 50 mph after i pass the apex. With the stock setup I would take that corner in second gear because my shift point is 59 mph. With a 4.55 FD I would probably have a second gear shift point around 50 mph. With the stock FD I can accelerate faster out of the corner in second gear then I would if I had to exit that corner in 3rd gear with a 4.55 FD because my stock second gear is still more aggressive than a 4.55 FD 3rd gear. Granted, I'll have to up shift into third shortly after I pull out of that corner, at which point the 4.55 FD will have the advantage in acceleration because his 3rd gear is better than mine.
But the point is that wouldn't the optimal final drive have to depend on the track you are racing at?
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE
4U-GSE is offline   Reply With Quote
Old 02-01-2013, 02:41 AM   #93
in "theory" yes but the reality is on the track carrying speed is FAR more important than the acceleration in a LOWER (mph limiting) gear only, as you cited, to have to upshift( loss of time) shortly there after. So the overall shorter FD allows for an easier gear to be pushed. When I reviewed my in car at MY track its win win for my lap times. I think a SHORTER FD than the 4.55 for ME at MY track would cause for an extra shift in 3 points on the lap.
The other thing is and I see it in my students for the last 15 years, is the tendency to buzz around in the lower gears which makes the car MUCH more jerky when you lift a hair which causes weight transfer and loose handling. Its better to commit to the taller gear and put your foot down and save a shifter later when its possible.
Myles
CxG (08-05-2015)
Old 02-01-2013, 03:18 AM   #94
[ame="http://www.youtube.com/watch?v=iGFHgbe0Epw&feature=player_embedded#"]86 TRD Griffon Concept(タイãƒ*アタックãƒ*ービー) - YouTube[/ame]!
aside from how SICK this car sounds, I think this car runs the 4.81 final drive !
At 2200 lbs its sick !
Enjoy!
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Hawk77FT (01-08-2014), JadeBRZ (03-01-2013), Lonewolf (02-13-2013), mangostick (02-01-2013)
Old 02-01-2013, 04:38 AM   #95
serialk11r
Drives: '06 AM V8V Coupe
How deaf are you? :O
80mph in my car is about 4400, my ears are bleeding by 3700 already.
I DUN GET HOW PEOPLE CRUISE AT 5000 RPM
The Following User Says Thank You to serialk11r For This Useful Post:
muffinman (03-04-2013)
Old 02-01-2013, 09:10 AM   #96
Captain Insano
That Griffon vid is awesome.
Old 02-01-2013, 09:33 AM   #97
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
Myles
I was taught the same. Use the highest gear you can in a corner without falling took far out of the power band. The corner speed is more important than the exit unless you are setting hot laps And really need the accel. In reality less shifting And smoother braking is more important for avg lap time. Depends on where You are And What You drive too. It's not a black And white kinda skill. You figure It out with enough seat time And trying corners different ways.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 02-01-2013, 10:10 AM   #98
OrbitalEllipses
Drives: Attitude
My WRX was at 3500-4000 by 65-70MPH...it was hellish. 3" turboback and straight through muffler. Sounded glorious, but the drone...never again!
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 08:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 10:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
