#15 |
Drives: '04 350Z/ 2013 LR BRZ (LM)
#16 |
Drives: Subaru BRZ Limited
Here is my alignment sheet. I used the eibach sportlines. They are rated at 1.5 drop i believe.
| The Following User Says Thank You to gdrider77 For This Useful Post: | phm14 (04-24-2020) |
#17 |
Drives: 2013 BRZ Limited 6MT GBS
this is only springs no other suspension mods?
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
![]() SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist |
#18 |
GreddyBRZ meets GreddyFRS
Drives: SSM Limited BRZ
Subscribed. I'm looking into which rear control arm will bring back the rear camber the best currently.
In the mean time, just wondering if anyone knows if certain coilovers come with camber plates that will allow us to adjust to within -(1.5-1.7) camber range in the rear? |
#19 |
Drives: Black frs project
3" drop front and rear
custome front arms with camber,castor,track,rollcenter, and anti-dive corrections. Bump steerable front tierod ends. Raised front camber plates and raised rear damper mounts. No other rear equiptment otherwise. Front camber -3.7 zero toe 10 degrees caster/rear -2.5 degrees camber zero toe (all with stock arms. (FULL RACE SETUP) can you tell? for a look go here http://www.ft86club.com/forums/showt...=robispec+mule and here http://www.ft86club.com/forums/showt...light=robispec never ran out of travel tires wearing on the inside as expected but getting 10+ track days out of them (RS3's/R1R's) |
#20 |
2S Crew
Drives: a 2013 FR-S
Eibach sportlines for me also no other modifications to the suspension..as follows:
![]() Is that alright? I'm completely clueless when it comes to this..though I'm doing allot of reading on the matter to try and learn it.. but it looks strange to see so many different incriments like the left and right aren't in sync.
#21 | |
#22 | |
Drives: '13 FR-S Argento
Small differences between left and right toe and camber values are normal for road cars from the factory. These differences can be caused by manufacturing/assembly techniques, as well as setting up suspension to ride on public roads that are usually cambered to the passenger curb and the fact that the majority of the time a car will only have a driver throwing off weight balance. As long as toe and/or camber are within spec at each corner and the cross camber/total toe are within spec as well there isn't anything to worry about. In the rear right it looks like they adjusted the toe to zero which probably affected the camber a little bit. Otherwise everything looks fine. |
| The Following User Says Thank You to DM7 For This Useful Post: | SP86 (02-05-2014) |
#23 |
Drives: 2013 FR-S, 2012 MCS
RS-R Superdowns (about a 1.2" drop)
Alignment: 1.1FL 1.3FR (with crash bolts) 1.9RL 2.3RR basically 0 toe Its an excellent alternative to the Sportlines. Cheaper, less camber, and a great ride. |
| The Following User Says Thank You to BlueDubbinTDI For This Useful Post: | phm14 (04-24-2020) |
#24 |
USMC
Drives: 2013 FR-S 6-MT Raven
No crash bolts yet but this is with the pro kit.
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 07:06 AM |
| camber kit? | iHeartmyFR-S | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 02-15-2013 08:30 PM |
| Who is going to buy the FRS DROP DROP Shop? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-18-2012 06:45 PM |
| Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 07:51 PM |
| Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 11:09 PM |
