#15 | |
Drives: BRZ Limited
Do you think I have to remove my license plate leds as well ? Also, do you think the dealership will blame you for aftermarket taillights or relay flasher ? |
#16 | |
Drives: 2013 WRB BRZ Limited
Sent from my SGH-M919 using Tapatalk
2013 WRB BRZ Limited "Belle"
Innovate SC STG2 Innercooled-70mm pulley DeliciousTuning/Moto-East Flex Fuel Tune TOMEI UEL Header/Overpipe, Stock Midpipe, Perrin Resonated CB RCE Yellows + RCE Front and Rear sway bars with TSW Nurburgring 18x8/BFGoodrich g-Force T/A KDW 2 in 245/35/18 |
#17 |
Drives: gt86
hi
is BIU same thing as ECU? Thanks |
#18 |
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
.. had the same issue here,.. Body Controll unit blew up,.. it is the main controll unit,.. the hole fusebox gets it signals from it! And when you produce a short cut while placing the leds in,.. the fuse does not blow, but some part in the Body ecu blows up,...
The Body ECU is providing GROUND to the bulbs,.. and when you get a short,.. the ground is not supported anymore,.. |
#19 |
Drives: gt86
you right, Do have to replace ECU? Can be fix?
#20 |
Drives: WRB Subaru BRZ Limited
No, the BIU is not the same thing as the ECU. It is a separate unit.
Please refer to the following link. http://www.subaruforester.org/vbulle...ed-unit-41719/ |
| BRZ Driver's Door Courtesy Light Won't Work | delusional | Issues | Warranty | Recalls / TSB | 31 | 05-29-2022 08:15 AM |
| Door lights on FRS | DanoFA20 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-02-2013 10:05 AM |
