Old 02-26-2013, 04:55 PM   #85
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by Batman View Post
Bump?
Before the weekend.
Drift-Office is offline   Reply With Quote
The Following 3 Users Say Thank You to Drift-Office For This Useful Post:
Batman (02-26-2013), dabocx (02-26-2013), DriftEightSix (02-26-2013)
Old 02-26-2013, 05:12 PM   #86
Raven604
ill test a kit, send one to hongcouver
Raven604 is offline   Reply With Quote
Old 02-26-2013, 10:08 PM   #87
Drift-Office
Lol.
Bob @ Drift-Office, LLC
Old 02-26-2013, 11:02 PM   #88
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I'll second that, some good high altitude testing 6k-10k feet!!
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 02-27-2013, 05:03 AM   #89
troek
troek's Avatar
Drives: 2012 Toyota 86
need to test a kit on jdm high octane in the mountains japan? haha
The Following User Says Thank You to troek For This Useful Post:
nix (03-03-2013)
Old 03-01-2013, 03:08 AM   #90
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Update:
A more polished Stage 2 by Drift Office was completed today. Made some minor changes here and there, and finished up the hardware of Stage 2.
Here is the dyno of the runs made today. It should be noted, this was run on straight from the pump Costco 92 octane (10% ethanol). We left the big wheels and tires on even though it probably costed us a few percentage points on power figures.
A short video of one of the runs today.
[ame="http://www.youtube.com/watch?v=u4pwCGinyww"]Stage 2 tuning on the AVO Turbo FR-S - YouTube[/ame]
The tune was totally clean, I'm happily surprised at how well it's running at 8psi. This was on stock injectors, stock fuel pump. What has been changed from Stage 1 is the addition of a 7psi wastegate actuator (with a boost controller), high flow front pipe, 2.5" cross-over pipe, 3bar map sensor. This is all flowing into a 2.5" AVO catback as well.
AVOturboworld is offline   Reply With Quote
The Following 11 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-01-2013), Apex Chase (03-01-2013), BRZranger (03-01-2013), Calum (03-01-2013), civicdrivr (03-01-2013), cmss2000 (03-01-2013), cobrabyte (03-03-2013), nix (03-03-2013), Sportsguy83 (03-01-2013), TRD_07 (03-01-2013), vubaru (03-01-2013)
Old 03-01-2013, 03:25 AM   #91
Drift-Office
Here are some larger pics... For the sake of argument, I'm also posting those specific runs in STD Correction, since some have resorted to using that as a basis of comparison...
and again now in SAE , enlarged.
That way you can see it isn't that much of a difference, but enough to skew the numbers ever so slightly, possibly to sway an opinion one way or the other. Aside from the larger and heavier wheels that were on the car, I also noted based on the logs that the quality of gas wasn't as seemingly as good as we might have hoped but in anycase, this would be pretty representative of the 8 PSI requirement now set forth by the SC contenders...
And just for giggles, here's a dyno run from a DynaPack dyno (reads at the hubs) from a HKS SC Kit (Version 1 I'm told) @ 8 PSI as well... 230 WHP @ the hubs...
More to come, as always.
Cheers!
The Following 11 Users Say Thank You to Drift-Office For This Useful Post:
Apex Chase (03-01-2013), BRZranger (03-01-2013), Calum (03-01-2013), civicdrivr (03-01-2013), deucethemoose (03-01-2013), Mr.Jay (03-03-2013), nix (03-03-2013), sf86 (03-01-2013), Sonolin (05-14-2013), Sportsguy83 (03-01-2013), TRD_07 (03-01-2013)
Old 03-01-2013, 04:01 AM   #92
JD86
Drives: 2013 Toyota 86 GT
That looks great! Torque dip? What's a torque dip?!?
JD86 is offline   Reply With Quote
Old 03-01-2013, 04:07 AM   #93
Drift-Office
You can see from the HKS SC kit that even @ 8 PSI, the torque dip is still there, though it isn't as pronounced. Let's see what Innovate's design will put out. We're still waiting on that dyno sheet that was promised...
On the AVO 8 PSI tune, a minimum of 200#s TQ @ 3500 RPM to 7000 RPM!
Let's see which other kits can give you that sort of performance.
Cheers!
The Following 5 Users Say Thank You to Drift-Office For This Useful Post:
Alienate (03-01-2013), BRZranger (03-01-2013), cmss2000 (03-01-2013), cobrabyte (03-03-2013), JesseE (03-01-2013)
Old 03-01-2013, 05:36 AM   #94
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Jeez, that graph is smoother and has more space under the curve then my old 3.2l V6 dynos.
Are those numbers with the stock secondary cat still in place?
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 03-01-2013, 04:31 PM   #95
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
flat torque :happy0180::happy0180:
shu5892001 is offline   Reply With Quote
Old 03-01-2013, 05:21 PM   #96
dabocx
dabocx's Avatar
Drives: Scion FRS
Can you overlay the stage two dyno over the stock baseline?
At what point is this turbo going to run out of steam?
dabocx is offline   Reply With Quote
Old 03-01-2013, 05:30 PM   #97
Drift-Office
I can do the overlays a bit later... As for the turbo running out of steam? You'll max out your stock injectors and clutch before that, and that's not Stage 2 anymore either.
Regards!
The Following User Says Thank You to Drift-Office For This Useful Post:
Old 03-01-2013, 08:21 PM   #98
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
I wonder if a different intake would help with power and also turbo spool sound?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
My Beltronics STi-R Plus Installation - Work in progress xjohnx Electronics | Audio | NAV | Infotainment 27 07-20-2013 12:10 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 01:06 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 09:38 PM
Our FRS work in progress! detainu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-24-2012 11:36 PM
