86WORX
Old 02-06-2013, 02:11 AM   #71
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by SilverSkyline210 View Post
i really hope stage 2 makes at least 300 whp, cause i just saw a visconti tuned p&l kit thats making 320whp at 11psi on 91 octane, which is tempting, but i really like the AVO kit for the turbo positioning, uel headers, and stealthiness under the hood, hope you guys push the limit a bit
AVO kit is not about being a WHP dyno queen. It is about WIDE torque bands where you have useable power on tap and very very little transient delay in spooling.
Look at FBM or P&L for god-like WHP numbers where the torque comes in and never drops from 4.5k - 8.5k rpms. Mmmmmmm
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Alienate (03-01-2013), BRZranger (02-06-2013)
Old 02-06-2013, 08:40 PM   #72
Sidewayss
Drives: WRX
For those wanting higher peak HP from this kit - you can always just change the 18G compressor to a 20G, which will be more efficient at high flow rates. AVO have clearly gone with the 18G for driveability.
Sidewayss is offline   Reply With Quote
Old 02-19-2013, 04:27 AM   #73
Mrqb22
Drives: 2013 FR-S Whiteout
dumb question. I am not looking for dyno queen peak number. But is there another turbo out there that would spool quicker than the one that is being used currently in this kit. My car is just a street car I want torque and I want it on tap like avo has it now I dont wan to wait til 4.5 rpm.
I like what AVO has now with the useable power. But I am not so concenered with peak HP. If you went with a small or different type of turbo could you get even more of that torque to come on quicker. I d be willing for fork out the extra cash for top of line turbo charger even if its smaller if it packs the punch off the line through out the power band not just top end.
2013 Whiteout
2013 XB black pearl.
Mrqb22 is offline   Reply With Quote
Old 02-19-2013, 05:47 AM   #74
sw20kosh
Originally Posted by AVOturboworld View Post
While it's fun to chase peak whp figures, high peak whp is usually found at high rpm's. If you notice from those dyno charts of the automatic, peak torque was reached at 2700-2800rpm - not, say, 4500 rpm like some turbo's. And it's maintaining it over a very long band. It makes for *excellent* driveability and overall performance.
So let's just say that, theoretically (cough), at 8-10psi we could peak at 230ft/lbs of torque and maintain over 200ft/lbs from 3300~7000rpm, it wouldn't produce the same peak whp as a turbo that made a bit more torque at 7400~8000rpm. But boy is it fun. I mean, it would be.
Lets say 200 tq at 7000 rpm ... 270 whp. I like.
The Following User Says Thank You to sw20kosh For This Useful Post:
Calum (02-19-2013)
Old 02-19-2013, 12:30 PM   #75
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
Update please.
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Old 02-19-2013, 01:52 PM   #76
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
You haven't seen the dyno chart for the kit on an automatic then.
That's at 5psi, and yes, it can go to much higher boost levels.
Any turbocharger you use will have a general range of operation, which will depend on the sizing of the turbo, size of the engine, exhaust flow, etc. A lot of variables, but the one constant being that it won't be efficient throughout the entire rpm range. The setup we picked here *is* about as small as we would want to go on this motor.
Looking at the chart, it really starts picking up from 2500rpm, reaches efficiency at 2800rpm, and holds that to 7000rpm where it starts dropping off. Now if we used a larger turbo, all we would be doing is moving that range 500-1400 rpm further down the rpm range. And if we used an even smaller turbo, it would start running out of breath at 6000-6500rpm.
A good example is the twinscroll turbocharged 2.0-liter Legacy in Japan. I drove that for three years. It would come in around 2000-2500rpm, a bit sooner, but it absolutely started running out of breath at 6000rpm. At 6500 it was like hitting a wall.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 02-19-2013, 03:06 PM   #77
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
So, question.. I've been following the AVO kit since it was announced. This stage 2 business really has me convinced this kit is the one. However, I too aim to be in the 300whp club, and look forward to seeing what that would entail. (*Cough* hurry up with that )
Questions, however, would be: What modifications would have to be made if I wanted to redline closer to 8600, meaning bigger turbo, etc, and since I love mean noises, how hard would it be to switch to an external wastegate?
Just thoughts from the Batcave..
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 02-19-2013, 03:38 PM   #78
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Raising the redline safely would entail upgrading the valvetrain to handle those high revs, and the parts to make power up there(turbo size mainly) Going with more aggressive cams and head porting will shift the powerband to the right.
Adding an EWG would require a modification to the header which will be pricey and likely unneeded. An EWG helps with regulating boost creep and AVO has designed their turbos to hold the given boost the turbo is rated for very well.
Tansey86 is offline   Reply With Quote
Old 02-19-2013, 03:45 PM   #79
Batman
Easy, Tiger.
Batman's Avatar
with the EWG i just love the fire-spitting sound, but I can live without it. With the redline raising, Ive just read about Visconti going to 8600-9600 with other Turbo kits safely, without any cams etc. I would assume the bigger turbo to keep up the boost would be the main point of concern.
Old 02-19-2013, 10:43 PM   #80
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
when will this be for sale?
Huehuecoyotl is offline   Reply With Quote
Old 02-20-2013, 12:35 AM   #81
Mrqb22
I am very impressed with the results of the AVO kit and the stealthness of it.
I understand it may be a price increase and this may be a dumb question as the turbo that comes with the kit is doing its job completely.
Is there any other turbo out there or anything that we could request from AVo as far as turbo is concerned for maybe something that may be a little more costly but would spool up quicker and bring on the torque sooner.
Basically question is , is there another turbo out there as I am not familiar with turbos or turbo companys for that matter that would pack more punch off the line and deliver more power and spool faster to put me back in my seat quicker. I not looking for a dyno queen but if there is another turbo out there that packs more punch down low what would it be ? I have seen different companies offer different types and again have no clue as I used to be a mustang vortech guy.
Can anyone offer any information on if they think maybe a smaller turbo that spooled quicker and delivered quicker is out there?
2013 Whiteout
Old 02-20-2013, 12:44 AM   #82
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You haven't seen the dyno chart for the kit on an automatic then. .......
Was your account hacked this morning? Where you high posting these? Are you a bot??? Just messing with you.
AVO answered your first post, why are you asking the same thing again?
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 02-20-2013, 04:58 AM   #83
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by fred_boosted View Post
Update please.
Sorry for the lack of updates, I've been gone for a few weeks out of the country, and when I get back, more stuff to show and talk about from the likes of AVO Turboworld!
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
BRZranger (02-20-2013)
Old 02-26-2013, 02:19 PM   #84
Batman
Easy, Tiger.
Batman's Avatar
Cheers!
Bump?
My Beltronics STi-R Plus Installation - Work in progress xjohnx Electronics | Audio | NAV | Infotainment 27 07-20-2013 12:10 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 01:06 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 02:30 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 09:38 PM
Our FRS work in progress! detainu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-24-2012 11:36 PM
