#603 |
86-er
Drives: BRZ tS
brz fog light part number
84912FJ100
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
#604 |
Drives: 2023 WRB BRZ (MT)
#606 |
#1362
Drives: 2014 Ice Silver WRX
The gap really isn't an issue unless the fixture isn't properly sealed. Buy this isn't the case so I wouldn't worry about it.
Sent from my HTC Rezound using Tapatalk 2
#607 |
Drives: Bagged RB8Six
Does anyone know of another site I can buy the subaru outback lights? I click on the link but its not showing up anymore
I just looked at the site yesterday and it said out of stock but today its not even showing up
#608 |
First 86 Driver Baby!
Drives: FR-S, Flex
My fogs installed!
#609 |
Drives: Scion FR-S Asphalt AT & XB
Hey HRTROB ...... do you know if the wiring harness from Nigel is negative trigger relay???
To Justin91M .... here's the link for fogs http://www.subarupartsforyou.com/cp_...p?partid=19073 |
#610 | |
Drives: 2013 Asphalt Scion FR-S
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
#611 |
Hey b$m1th91 Did you receive the Nigel harness already????? Can you or anyone provide a pic of the relay????
I'm going to use the Nigel wiring harness ( ordered )and the BRZ stalk. Anyone with some input would be great. Anyone try to power the fogs by tapping into the fuse box where the fog light fuses are suppose to be buy using fuse tap????? |
#612 |
Drives: 2013 Whiteout FRS
Fixed my issues. Just extended the harness with more wire!
#613 |
Drives: 2013 FR-S Ultrmarine MT
These are all great questions, Willsonk. I'm using the same setup, hence, following your exact foot-steps.
Also, thanks for your response to my PM. So, getting answers on this setup configuration is becoming more of a community popular request. Thanks. Last edited by Zagmeister; 03-21-2013 at 09:05 PM. |
#614 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
Am I missing something? A relay is a relay right? Typical 12v relays come in either 4 pin or 5 pin. Either a set of NO contacts or NO and NC contacts. Depending on how it's wired. Either providing a ground or voltage to the coil via a switch determines wheter its positive or negative trigger.
#615 | |
#616 |
thanks b$m1th91
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 09:38 PM |
| FINALLY - Got my FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-03-2012 06:16 PM |
| FINALLY GOT IT! | Ayaz2589 | NY / NJ / CT / PA | 8 | 07-28-2012 03:52 AM |
| Finally got it!! | percyng | CANADA | 21 | 06-17-2012 02:50 AM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 1 | 06-16-2012 08:29 PM |
