Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 01-25-2013, 06:15 PM   #57
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
It's been posted over on NASIOC now:
http://forums.nasioc.com/forums/show....php?t=2460064
Old 01-25-2013, 07:37 PM   #58
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by chulooz View Post
Good point, what ever happened to the 'holes in the dash for roll bars' ?
If you took out the upper speakers I think they would be in about the right place no? Might be part of the reason they put them there.
The dumbest thing about roll cages that bend around the dash is that most racing governing bodies won't allow them as they really compromise the ability of the cage to not deform when the car rolls, and B. you shouldn't have any cage unless you're wearing a helmet so they're worthless on the track and worthless on the street, so why bother?
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
switchlanez (01-25-2013)
Old 01-25-2013, 08:15 PM   #59
ayau
Drives: Some rust bucket
I just realized something. How can the disk brakes be 16 and 15 inches? The rim itself is 16". Was there some translation error?
Old 01-25-2013, 08:28 PM   #60
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
They size the brakes over there by the size of the wheel that can fit over them.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
ayau (01-25-2013)
Old 01-25-2013, 08:30 PM   #61
ayau
Ah ok. Thanks for clarifying. I know the lower spec JDM models have ventilated fronts and solid rears. The US gets ventilated fronts and rears. It appears that this JDM RA model gets the same brakes as the USDM model.
Old 01-25-2013, 10:58 PM   #62
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
XD
WingsofWar is offline   Reply With Quote
The Following 5 Users Say Thank You to WingsofWar For This Useful Post:
Beyer Subaru (01-26-2013), chanomatik (01-26-2013), Dark (01-28-2013), ichitaka05 (01-25-2013), switchlanez (01-25-2013)
Old 01-26-2013, 12:31 AM   #63
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
you guys.......
none of this is even badged as sti.. this is just subaru brz RA racing. no sti.
anyone else think that the harnesses just mount to the isofix points? :/
look at the angle of them behind the seat... not good..
crap harness mounts, crap cage... all that glitters is not gold ..
Surok is offline   Reply With Quote
Old 01-26-2013, 01:13 AM   #64
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Originally Posted by Surok View Post
you guys.......
yeah we know its not an STI, we just went on a tangent on the logo and how its changed.
As far as the cage and harness mounts (which i cant see on the pictures), iv seen plenty of Overkill to really nice to passable setups. As long as they are FIA approved that's all that really matters. FIA has done some pretty extensive research on proper racing gear and setups, and updated constantly for strict guidelines. Even if the cage and harness points are the meet only the bare minimum requirements of safety per FIA rules, they are still very reliable.
You may find that the mount angle is wrong, and the harness mounts are crap, and the cage is crap, and you probably have more experience than me in building such systems or working on pit with a crew, or whatever and thats cool, but its really hard to see your points.
Id love to agree with you if you found evidence that the setup on the RA doesn't meet FIA specs, or wont offer the driver substantial safety during HPDE.
The Following User Says Thank You to WingsofWar For This Useful Post:
Surok (01-26-2013)
Old 01-26-2013, 01:28 AM   #65
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
you guys.......
You were saying something about STI... sorry, I was too busy seeing "STI" license plate & "STI Performance" sticker
Yes, we know it's not Subaru BRZ STI. It's Off-topic stuff we were debating
On-topic, one thing that confuse me is, in the PDF file, BRZ RA Racing package weight 1450kg (reference: PDF) which equal to 3196lbs (btw, that's w all the fluids in)... roll cage weight down that much?!?!?!
switchlanez (01-26-2013)
Old 01-26-2013, 01:42 AM   #66
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Shoulder belts must run from the shoulders horizontally or down, at no more than a 20° angle. LINK FROM SCHROTH
AND tillet From the FIA guidelines.
see below.. that looks like about a 45 degree angle.. too much!
Windscreen pillar reinforcement part 253-15
from http://www.fia.com/sites/default/fil...%282013%29.pdf
Cars homologated as from 01.01.2006 only :
It must be fitted on each side of the front rollbar if dimension
"A" is greater than 200 mm (Drawing 253-15).
It may be bent on condition that it is straight in side view and
that the angle of the bend does not exceed 20°.
Its upper end must be less than 100 mm from the junction
between the front (lateral) rollbar and the longitudinal
(transverse) member (see Drawing 253-52 for the
measurement).
Its lower end must be less than 100 mm from the (front)
mounting foot of front (lateral) rollbar
Ain't none of that shit FIA legal.
Old 01-26-2013, 02:03 PM   #67
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Sorry, took me awhile, i just got off the phone with a seasoned race inspector about Z bends on the forward bar. Apparently FIA does approve of them, but only allows them to be used in sanctioned FIA events for certain situations. This is to weed out and deter cage builders from offering similar systems, because non-oem cage builders should only be encouraged to build pass through dash forward bars with only 1 bend.
Apparently Several GT300 JGTC cars run z bend forward bars in their cage diagrams, and meet JAF and FIA specs. Probably the reason why you only see these kinds of bends in Japanese cars for rally and drifting events.
In the downwards direction, the shoulder straps must be
directed towards the rear and must be installed in such a
way that they do not make an angle of more than 45° to the
horizontal from the upper rim of the backrest, although it is
recommended that this angle should not exceed 10°.
The maximum angles in relation to the centre-line of the seat
are 20° divergent or convergent.
If possible, the anchorage point originally mounted by the car
manufacturer on the C-pillar must be used.
Anchorage points creating a higher angle to the horizontal
must not be used.
In that case, the shoulder straps of 4-point safety harnesses
may be installed on the rear seat lap strap anchorage points
originally mounted by the car manufacturer.
within 45degrees or strapped to the rear seat lap by the manufacture..Seems to meet FIA regulation to me...
measurement).
The Following 4 Users Say Thank You to WingsofWar For This Useful Post:
chanomatik (01-26-2013), ichitaka05 (01-26-2013), Surok (01-26-2013), switchlanez (01-26-2013)
Old 01-26-2013, 03:10 PM   #68
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
You can tell it's a race car because all race cars have steel wheels.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 01-26-2013, 03:43 PM   #69
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yes! It's official then! I have race car!
(old pic)
The Following User Says Thank You to chanomatik For This Useful Post:
Old 01-26-2013, 03:59 PM   #70
ichitaka05
Site Moderator
ichitaka05's Avatar
(old pic)
LMAO
Wheel Directory: Volk Racing TE37 18x8.5 +38 / 18x9.5 +40 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 04-18-2013 04:25 PM
Lachute Performance & EcuTeK support SWAG Racing for the FR-S Tuner Challenge Edition Cotnoir Scion FR-S / Toyota 86 GT86 General Forum 2 01-16-2013 03:35 PM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ STI Concept and PROVA BRZ Black Edition from the TAS 2012 Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 66 05-13-2012 05:28 PM
