86WORX
Old 03-13-2013, 10:25 AM   #57
Supermassive
Supermassive's Avatar
My Wilwoods are doing fine right now, even though I have yet to get an opportunity to test them on anything more than spirited driving on public roads. Without taking it to the track I feel that I can't give any real insight as to the way they deal with track conditions.
Supermassive is offline
Old 03-13-2013, 10:44 AM   #58
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by Margovincent_22x View Post
AP BBK : will this fit 17x8 44offset Volk Racing TE37 Wheels?
Your best bet is to check (or have your wheel seller check) the fitment templates. Here are all the templates for the kits we offer:
Essex Sprint Kit wheel fitment template
Essex Endurance Kit wheel fitment template
AP Racing Formula Big Brake Kit Six piston front wheel fitment template
AP Racing Formula Big Brake Kit Four piston front wheel fitment template
AP Racing Formula Big Brake Kit Four piston rear wheel fitment template
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing
www.essexparts.com
JRitt is offline
Old 04-05-2013, 04:46 AM   #59
Ceylon
Drives: SW20 MR2
Wilwood makes decent brake products however they are nowhere in the same league as AP Racing. Just walk down any top level motorsports (Formula 1, WRC, Super GT, Aussie Super Car, Lemans, etc.) paddock and see what brake/friction products they are using.
Ceylon is offline
The Following 2 Users Say Thank You to Ceylon For This Useful Post:
FT-86 SpeedFactory (04-05-2013), Huehuecoyotl (04-05-2013)
Old 04-05-2013, 07:27 AM   #60
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We're rocking the AP Sprint kit on our road race car.
FT-86 SpeedFactory is offline
Old 08-27-2013, 03:56 PM   #61
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
I assume that since the AP Racing Sprint fits the Enkei RPF1 17x9 +35; there Should not be a problem with the Enkei RPF1 17x8 +35....right?
kurbkilla is offline
Old 08-27-2013, 04:27 PM   #62
You may need a minimal spacer (2mm) for peace of mind
CSG Mike is offline
Old 08-27-2013, 05:15 PM   #63
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
here is their post about why you should always test the wheel. 17x8 +45 worked, but 17x9 +45 did not.
http://www.essexpartsblog.com/news/c...ance-templates
G-Man is offline
Old 08-27-2013, 07:25 PM   #64
kurbkilla
kurbkilla's Avatar
I dont have the rims or the brakes at the moment. But I want to make sure it all fits and works together before I buy anything. And hopefully without spacers.
Thanks for the link
The Following User Says Thank You to kurbkilla For This Useful Post:
BRZ NA (09-13-2013)
Old 09-13-2013, 12:34 AM   #65
BRZ NA
Drives: WR blue
So no one confirmed what offset will fit for the ap bbk on 17x9?
BRZ NA is offline
Old 09-13-2013, 12:39 AM   #66
FT-86 SpeedFactory
Each wheel is different due to spoke design. No one single offset will work, as each wheel spoke design is not the same.
The 17x9 + 35 Enkei RPF1 will fit. Other wheels that may be 17x9 +40 could work, but a 17x9 +40 RPF1 would not as an example.
Old 09-13-2013, 12:47 AM   #67
BRZ NA
Drives: WR blue
Sorry,I meant for 17x9 + 35 Enkei RPF1,ur set up. Did u find out the clearance after heat yet?Thx.by the way,is that the only/best offset for 17x9 TODAY?
BRZ NA is offline
Old 09-13-2013, 01:22 AM   #68
Dezoris
Dezoris's Avatar
AP all the way. Someone had their dust boots melt down on the Wilwood kit already if I am not mistaken from track use?
Dezoris is offline
Old 09-13-2013, 01:31 AM   #69
utekineir
blowhard
Drives: frs, project forester
when i had researched wilwood previously (few years ago for forester) the calipers had stainless pistons and no dust boots
has that changed?
utekineir is offline
Old 09-13-2013, 11:48 AM   #70
FT-86 SpeedFactory
The rotors will not touch the spoke at any time with the AP kit. We have had plenty of hard lapping days with this setup and there are no issues.
35-45 offset are just right for a 17x9 wheel on our cars, IMO.
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
