Old 01-31-2013, 03:01 PM   #29
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
I ran a set of wilwood's on my s2000 and my old civic Si and was EXTREMELY happy with both sets. In both cases, the improvement over stock was dramatic, both in sudden stops and also with track use.
hamlet is offline
Old 02-02-2013, 04:50 PM   #30
D1cker
Drives: B9 S4/ND2
Originally Posted by FT-86 SpeedFactory View Post
We're going to be VERY close then, but I think still fine. I'll round up a calliper tomorrow to be sure.
-Jeremy
PICTURES???!?!?!?!?! Sorry this just has me very excited.
D1cker is offline
Old 02-02-2013, 07:03 PM   #31
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
I am grabbing them off our camera as I type this. Will have them edited and posted this evening.
Cheers!
-Yo
FT-86 SpeedFactory is offline
Old 02-02-2013, 08:51 PM   #32
FT-86 SpeedFactory
More coming, we got measurements and more. Off to dinner for now.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Surok (02-02-2013)
Old 02-03-2013, 01:49 AM   #33
FT-86 SpeedFactory
Well, back from dinner a bit late. Had a few cocktails downtown tonight :happy0180:
Nonetheless, here are the clearance and measurement shots of the AP Sprint kit and Enkei 17x9 +35 RPF1.
Using a spark plug gap and feeler tool to measure clearance. This was measured at the point where the spoke of the wheel had the least clearance.
Clearance for the AP Sprint kit with this particular wheel was measured at 2.45mm
The Following 10 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
03Z33 (02-14-2013), Anthonytpt (03-12-2013), B L U E S L A T E (02-03-2013), Boris_Petrov (06-30-2019), D1cker (02-03-2013), Gixxersixxerman (02-03-2013), ICantAffordAnLFA (02-03-2013), JRitt (02-04-2013), track_warrior (02-05-2013)
Old 02-03-2013, 02:36 AM   #34
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
does this mean it works? i doubt it! spokes will bend wont they?
a bit of flex
Surok is offline
Old 02-03-2013, 02:43 AM   #35
OrbitalEllipses
Drives: Attitude
a bit of flex
2mm recommended minimum clearance.
OrbitalEllipses is offline
Old 02-03-2013, 03:03 AM   #36
B L U E S L A T E
Drives: BMW E84
Bravo.
B L U E S L A T E is offline
Old 02-04-2013, 04:12 PM   #37
benster
Drives: none yet
it's on the inside of the spokes. if it flexes over 2.45mm there you're not just running race slicks on a road course, you're crashing the vehicle. if that clearance was on the outside edge of the spokes, maybe your flex theory would work, just not in the area the brakes are.
benster is offline
Old 02-05-2013, 06:46 AM   #38
Paragon
Guest
Posts: n/a
Not sure what ur trying to say here, are you for or against?
Old 02-05-2013, 07:09 AM   #39
benster
Drives: none yet
i don't think we can account flex at that part of the wheel, hence I'm pretty sure it won't contact, sorry if I didn't make it clear.
benster is offline
Old 02-05-2013, 08:11 AM   #40
mad_sb
Drives: 2013 Asphalt FR-S
In Summary:
willwood kit for the showwhores
AP kit for the trackwhores
I drool a little bit every time i see the AP kit.
mad_sb is offline
Old 02-05-2013, 09:35 AM   #41
FT-86 SpeedFactory
Correct, since it is at one of the stronger points of the wheel where the clearance is the closest.
We're excited to get this thing out of the shop once it warms up. Might be tomorrow. We shall see, roads are pretty salty yet.
Old 02-05-2013, 11:08 AM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd have to find the article I read, but it was GRM talking about their results where some heavier versions of the same wheel was faster in autox/track use than lighter versions because the wheel didn't have as much flex between the hub and the rim, in other words, across the spokes.
I would say that the farther in the less flex will be an issue. There's also heat related expansion to consider though. I've seen an EVO at the track have wheel to caliper contact when it never did on the street, no real damage but the owner was confused by it, whether he did something wrong (side loading impact for example) or it was just heat/flex I'm not sure.
Either way, 2mm is enough and there looks to be even more than the 2mm available here so it should be fine anyways. I think Brembo says 3mm though. Either way, with that measurement from Jeremy I'd rock it until they hit
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
