Old 01-30-2013, 06:58 PM   #15
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Comparison of stopping distance would be nice. I know it's not that simple because of cost.
It would be nice if the manufacturer could provide info on this.
andrewFT86 is offline
Old 01-30-2013, 07:28 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by FT-86 SpeedFactory View Post
It's really close. I couldn't find my caliper to measure, and getting anything up to temp when it's snowing is hard. lol Should be enough for heat expansion though. Absolute worse case is 5mm spacer.
You got an estimate on how much everything expands? Makes me wonder if any studies have been done on that... hmmmmm
-Jeremy
No idea here either. I think the number I've heard before is that you want 2-3mm clearance at least.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 01-30-2013, 07:30 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Slight difference if you keep them at the edge of lockup (ie not into ABS). If you just floor the pedal there will be no real difference unless they are fixing a bias problem (or making a bias problem). OEM brakes lock up the tires, so will these and the tires stop the car.
BBK's have other benefits which is why people buy them. I buy because the OEM components can't handle extended track abuse IMO.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following User Says Thank You to Dave-ROR For This Useful Post:
wparsons (02-11-2014)
Old 01-30-2013, 07:44 PM   #18
D1cker
Drives: B9 S4/ND2
This makes me happy.
It's like Boner Jams '03 over here.
D1cker is offline
Old 01-30-2013, 08:59 PM   #19
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by Tansey86 View Post
Whats the weight of both vs stock?
Link to Essex blog comparing AP vs. Brembo vs. stock
http://www.essexpartsblog.com/news/E...em-Development
Wilwood weight measurements we did in-house
http://www.ft86club.com/forums/showt...t=25550&page=2
Hope that answers your question.
Cheers!:happy0180:
-Yo
FT-86 SpeedFactory is offline
Old 01-30-2013, 09:11 PM   #20
OrbitalEllipses
Drives: Attitude
-Yo
that's a comparison of the Endurance kit when you clearly specified you were comparing the Wilwood to the Spring kit. Since I'm assuming you're just grabbing the OEM weights out of there, I won't insinuate anything.
OrbitalEllipses is offline
Old 01-30-2013, 09:18 PM   #21
FT-86 SpeedFactory
whoops! my bad. I didn't even check to see what kit they were weighing.
I know there are weights on the forum for both somewhere, just need to dig deeper.
Thanks for pointing that out.
-Yo
Old 01-30-2013, 09:39 PM   #22
FT-86 SpeedFactory
Here is the Sprint kit weights and etc...
http://www.essexparts.com/essex-comp...-frs-gt86.html
-Jeremy
Old 01-30-2013, 09:40 PM   #23
FT-86 SpeedFactory
We're going to be VERY close then, but I think still fine. I'll round up a calliper tomorrow to be sure.
-Jeremy
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
D1cker (02-02-2013)
Old 01-30-2013, 10:08 PM   #24
jamal
jamal's Avatar
Drives: Legacy GT
How about the important things like caliper stiffness and brake torque (bias change).
Also how do the hats attach on each rotor?
jamal is offline
Old 01-31-2013, 05:37 AM   #25
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
No chance of a comparison vs the OEM STI Brembos?
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline
Old 01-31-2013, 07:02 AM   #26
Supermassive
Supermassive's Avatar
I have to say I was debating between these two and the AP endurance kit and in the end I went with Wilwood. I'm not gonna lie, the real determining factor was cost. The AP kits are amazing but I wasn't about to put the sprint kit on my car simply because I wanted at least slightly larger rotors so my only option was the AP endurance or the wilwoods. The endurance kits are $500 more than the sprint kit and $900 more than the Wilwood, so this is where I was comparing them hard...I had to find $900 worth of improvement to make my mind. I don't run this car solely on tracks, but with the turbo kit in place I needed to be able to bleed speed more effectively than the stock setup. Wilwood brakes are actually pretty damn good, and I am willing to bet that among the members of this forum few if any will actually push these brakes on this car. The AP's are awesome and if I didn't have about 100 other things on my list to buy in the next few months i would have probably gone with the endurance kit without a thought.
I plan on running my car in local AutoX events and maybe even some SCCA events if I can work up the nerve to subject the car to that. For the most part though i drive my car daily and I just felt that in this particular instance the Wilwoods fit exactly what I need at a price that doesn't seem outrageous *cough* Endless *cough*
Supermassive is offline
Old 01-31-2013, 07:15 AM   #27
Paragon
Guest
Posts: n/a
-Jeremy
Really hope they clear the 17x9 +35 Rpf1 so awaiting pics very muchly
Old 01-31-2013, 08:11 AM   #28
FT-86 SpeedFactory
Sorry we don't have any of those on hand.
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
