#43 |
Drives: 86 GTS
What you're looking at is a different intake manifold with different length runners, different cams and to a lesser extent headers. You have to understand though that to close that hole you are going to be taking power from somewhere else. This isn't a 1:1 kind of thing but ultimately the parts have been designed to have maximum efficiency at a certain point in the rev range so to improve the efficiency in a different point you are going to gurt it somewhere else. What I would expect to see is some cams and probably new intake manifold which will be optimised for mid to high range so will fill the hole but also knock off the peak from 2000 - 3000rpm.
#44 | |
Drives: Skoda Yeti DSG diesel 4x4
You only lose power elsewhere if the changes are fixed. Variable solutions will work and maintain power throughout the range, they are just difficult to implement and the best variable cure so far is a turbo. |
#45 |
Drives: ex500r
#46 |
The Mechanic
Drives: Civic Turbo,FR-S
back in the day it use to be universal wiring nightmare. now its plug and play applications. They are made for most every car. i run a series 1, but there is now the series 2 and the infinity which theyre are pushing alot..this is the company the makes the proper sounding launch controls and anti lags lol
| The Following User Says Thank You to Grip Ronin For This Useful Post: | sierra (01-27-2013) |
#47 |
First 86
Drives: Scion FRS Argento Automatic
I'm surprised Subaru wasn't able to tune the torque dip out.
Life is short...NO BORING CARS |
#48 |
Red wine
Drives: Subaru BRZ(R.I.P)
I think the torque dip is the cause of the Toyota direct injection system. The Lexus IS which uses the exact same D2S has the same torque dip.
#49 |
Boosted
Drives: Sideways
Dump the clutch, what torque dip?
#50 |
Drives: GT86 First Edition
Hi all, I personally tuned my ECU and I can confirm what been said in this thread, the direct injection is used to compensate the low air flow in that rpm range which is from 2800 to 3800 rpm (more or less). If you enable port injection the sound change but you get disappointed by generated torque. the car use AFR map to allow the fuel flow and another map to decide the % of DI or PI. DI injection anyway gives more torque but his efficiency decrease along the rpm range so it's better to combine DI and PI, infact the stock % at full torque request is 50-50 %
you can clearly see that at those rpm range the car can't breath as it would even with sport air intake Hope this might help clearing some ideas
#51 |
is better than you
Drives: 2013 raven FRS
omg its a 2l NA motor. What the fuck do you guys expect.
#52 |
yes it is, but it's a really good one and obviously if you want some powa you need some modifications
![]() The awesome is the handling of the car which can make it really competitive against other street cars
#53 |
Drives: 4wd zooks
The torque dip is not a problem with the manual gearbox.
When i need more torque i just change down a gear. This car is about driver involvement and fun. |
#54 |
Drives: FR-S 6MT
I agree.. While it does exist.. In normal driving, it's not an issue. You can drive around it.. Which just adds to the character of the car.
For normal commuting, driving below the dip there is plenty of tq to where you don't need to rev too much.. Play time keeps the tach above 5k and u don't worry about bogging in the dip.. I've been to the track too and the dip wasn't an issue for me.. A compromise had to be made and I think the OEM made a good choice on keeping tq down low and up high.. Great discussion !! |
#55 |
Sure, every NA car has this problem.
It's much more important above 4800 rpm. Looking at the map I found a limitation in the fuel map and fuel injector which makes you gain enough to feel the car much better, especially while drifting or mountain driving ![]() besides this car is limited above 220 km/h (throttle close to 50% at 230 km/h) |
#56 |
Drives: 2013 Asphalt FR-S
Header+tune=torque dip free.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 12:53 PM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 07:56 PM |
| Wheel Re-Torque to 89 ft-lb | Brzce | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 08-22-2012 11:55 PM |
| It has more power, but less torque. | white_knight | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-09-2012 02:46 AM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 01:22 AM |
