#29 | |
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I think it's the volume per cylinder, not volume per second. That would make it much less dependent on RPM. |
#30 |
Drives: 86 GTS
You can be more aggressive with the tune when you're only running direct injection as it's fundamentally more detonation resistant. My read is that the combination of the intake and the cams have been designed to give a big hump in torque low down for daily driving and a hump up top for when you're driving hard. This leaves a hole in the middle which they have been really aggressive in the tune in an attempt to minimise as much as possible.
#31 |
The Mechanic
Drives: Civic Turbo,FR-S
you didnt know about them? i been running one in my civic for years. best ecu ever. closes think to a motec and a sub normal price
#32 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
@Visconti perhaps he could comment on adjusting the direct/port injection overlap and its affects on the torque dip in his tunes?
#33 |
Boosted
Drives: Sideways
At the time we were using ProEFI.
#34 | |
Drives: Skoda Yeti DSG diesel 4x4
I've been picked up many times by women for the blue/green border, they have a better sensitivity to colour so who knows? Good point with the volume. If that's the case then the chart should indicate volumetric efficiency. The only problem with that is that the lines climbs from just below 3,000rpm to 3,600rpm when it's losing power? |
#35 | |
#36 | |
#37 |
#38 | |
Drives: 86 GTS
You also have to remember that direct injection only gives better torque, not worse. As it's able to deliver the fuel charge very close to the plug the flamefront propogates through the fuel charge quicker minimising the risk of detonation, this lets you run more timing to maximise torque. A number of tuners have remarked that the tune is very aggressive through this area in the maps which re-inforce that the issue is intake harmonics, not tune. The fact that no-one has been able to tune this out even though they have contol over when the port injectors are used also tells you that the problem is harmonics, not tune. Everything in an engine is about compromise and to me it screams that they've compromised on cost by not using variable lift or variable length intakes (also a reliability issue for that one) which will result in losing VE somewhere which they've placed at the least important spot in the rev range. To minimise this they've gone aggressive in the tune however you can only make up for a lack of air so much in the tune so we're still left with a hole. |
| The Following User Says Thank You to IMOA For This Useful Post: | Mikem53 (07-21-2013) |
#39 |
Drives: 2013 Subaru BRZ
Very interesting thread...
Hoping one of the guys who has been able to mess with the tuning on this car can shed some light... |
#40 | |
#41 | |
Drives: 13 CSB BRZ Ltd
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
#42 | |
On the positive side it gives it character. Even at less than 1/2 throttle it lights up at 5,000rpm giving great performance while literally sipping fuel. The only way I can think to get more air in there is by blowing it in. A free flowing panel filter will maximise the air at those rpm's. |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 12:53 PM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 07:56 PM |
| Wheel Re-Torque to 89 ft-lb | Brzce | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 08-22-2012 11:55 PM |
| It has more power, but less torque. | white_knight | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-09-2012 02:46 AM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 01:22 AM |
