Old 01-24-2013, 11:47 PM   #15
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by b.e View Post
I think some of you are missing the importance of the green (INJECTION VOLUME) curve. The fuel rate isn't dropping when the type of injection changes.
Blue injection volume curve?
The problem with that is if it's showing the total fuel being injected at full throttle? Then why is it only showing another 10% of fuel being used at 5,600rpm than is being used at 3,500rpm? Or almost the same fuel at 7,600rpm as at 4,900rpm?
sierra is offline   Reply With Quote
Old 01-24-2013, 11:54 PM   #16
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
they should run both much earlier because that mix of port and di give the car its best performance. giving the benefit of the doubt i assume the tuners have tried this already
IG-Joey_Soul
Old 01-25-2013, 12:08 AM   #17
sierra
They do both run much earlier but for some reason the port injection shuts down in the torque dip range.
You would assume they have but have you ever seen this mentioned before?
Old 01-25-2013, 02:11 AM   #18
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by ziggz501 View Post
has nobody messed with the ECU to keep the port injectors on? it would be interesting to see what the torque curve would look like if they were just kept on and tuned to keep proper air:fuel.
but yeah, a major objective of the direct/port injection system is for emissions.
I was running on 100% port injectors for a little while. Doesn't help your argument because I wasn't anywhere near stock though.
Old 01-25-2013, 02:12 AM   #19
Synack
Boosted
Synack's Avatar
Drives: Sideways
the torque curve dips around 4000~rpms if i recall correctly, but the port injectors open up at 5000, which almost doubles the amount of fuel being dumped into the engine. my guess is that the engine is using the DI mainly for the purpose of emissions in the early rpms.
Bingo
Old 01-25-2013, 02:28 AM   #20
sierra
Did it do anything to the torque dip?
Old 01-25-2013, 02:28 AM   #21
Grip Ronin
The Mechanic
Grip Ronin's Avatar
nope i havent seen anything about the details of their tunes. id really love to cut the bs and put a AEM in it and bring it to my tuner over here in newark.
IG-Joey_Soul
Old 01-25-2013, 02:38 AM   #22
sierra
Just googled AEM tuning and found a whole new world!
Old 01-25-2013, 03:00 AM   #23
Synack
Boosted
Synack's Avatar
Drives: Sideways
I was turbocharged and had an extremely custom tune. Can't really attest to anything.
Old 01-25-2013, 03:03 AM   #24
sierra
No, turbocharging always fills the torque dip too.
Do you know if Ecutek can turn the port injection back on?
Old 01-25-2013, 03:29 AM   #25
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Interesting question - but wouldn't doing so likely hammer the fuel economy?
Sport-Tech is offline   Reply With Quote
Old 01-25-2013, 04:54 AM   #26
ziggz501
ziggz501's Avatar
unlikely. the fuel economy would take a tiny hit at best. keep in mind that the air:fuel remains relatively constant throughout the powerband. the biggest issue is usually getting the air into the cylinder chambers since the camshaft on most cars is usually designed for low end torque. this is why Honda's VTEC is a thing; although, most people have no idea what it does because they have never sat in an S2000 or TypeR.
what would take the biggest hit is the emissions, but if you are messing with the ecu, emissions is probably not your concern.
ziggz501 is offline   Reply With Quote
Old 01-25-2013, 06:26 AM   #27
sierra
As Ziggz has said, the mixture can be kept constant. If restricting the injection to direct, for emissions at that rpm, is restricting the the available power then keeping the port injection operating will restore that power. The fuel consumption might suffer slightly because direct injection is more efficient and the emissions would be slightly higher but let's face it, they look to have done this to pass specific rpm emission requirements which is bending the rules anyway.
The Following User Says Thank You to sierra For This Useful Post:
Sport-Tech (01-25-2013)
Old 01-25-2013, 08:50 AM   #28
whtchocla7e
Drives: 2013 FR-S Hot Lava
The torque dip is overrated. I don't even feel it..
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following User Says Thank You to whtchocla7e For This Useful Post:
strat61caster (01-25-2013)
Search this Thread:
Advanced Search
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 07:56 PM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 11:55 PM
It has more power, but less torque. white_knight Scion FR-S / Toyota 86 GT86 General Forum 9 08-09-2012 02:46 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
