Old 01-23-2013, 03:11 PM   #15
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
AT Transsmision as the others say. My engine cranks like its right in the middle of the summer even at -20c.
Rayme is offline   Reply With Quote
Old 01-23-2013, 03:14 PM   #16
ST185RC
Drives: White Out FR-S
10 minutes of warm up is way excessive and it's just burning money. Once the idle rpms of the engine reaches normal operatinging RPMS around 800-1000 the oil has circulated enough. If it's that cold, the rest of the driveline might have frosted over. Best to start it moving after 2-3 minutes of getting the oil going.
The first start on a cold morning is by far the most harmful thing an engine sees and there's really no way around that. Any other regular engine (barring redlining it and choking it like a chicken) wear and tear will be a small fraction of first start wear and tear.
ST185RC is offline   Reply With Quote
Old 01-23-2013, 03:55 PM   #17
_hollywood
Drives: 97 itr sold
I know anything over 30 seconds is a waste but i am guilty of letting it sit for 5 minutes on cold mornings, and man i love that crunch sound everytime i open the door, sounds so nice on a brand new car....
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 01-23-2013, 04:04 PM   #18
so26
Drives: Raven FR-S 6MT
I don't know about an AT but with a MT most of the gears are spinning in the transmission when the shift is in neutral and the clutch is released.
[ame="http://www.youtube.com/watch?v=ftdgB93QOD8"]gear box operation - YouTube[/ame]
The spinning gears will stir the oil and genetrate some heat. How much not sure.
so26 is offline   Reply With Quote
Old 01-23-2013, 04:34 PM   #19
joop1987
Drives: 2013 FRS, Raven, Auto
I had no problems today at 7:30am in NJ. I let it warm up for 30 seconds before I drove to work.
joop1987 is offline   Reply With Quote
Old 01-23-2013, 04:49 PM   #20
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Yes that's true, but not nearly as much as the heat generated by the frictional losses that comes with power transmission...by driving the car. It's the same thing as letting the engine idle, yes that will eventually warm up, but in the end your brakes, bearings, & differential can't get warm until you drive the car.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 01-23-2013, 06:20 PM   #21
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
I had some issues starting up last night after work. It was 13 degrees Fahrenheit and took 3 turns of the key to finally fire up.
Pooverdam is offline   Reply With Quote
Old 01-23-2013, 07:50 PM   #22
xcelir8brz
Drives: 2013 BRZ Limited
Get an Optima battery. It will solve all your issues.
xcelir8brz is offline   Reply With Quote
Old 01-23-2013, 08:45 PM   #23
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
I've noticed that after driving through the hills in cold weather, it seems as if the car seems to lose power. It'll take longer to hit the higher RPMs and just feels sluggish overall. This is usually accompanied by difficulty starting up or very weak start-ups. Does anyone else have this problem?
jlu is offline   Reply With Quote
Old 01-23-2013, 09:34 PM   #24
PRORICAN
PRORICAN's Avatar
It's funny you say that. I have one of those small racing battery kits that I've used for about 3yrs now and the last two winters were here in Mass with zero issues. So far this week has been well below 20degrees and start ups have been quick and on the first try.
PRORICAN is offline   Reply With Quote
Old 01-23-2013, 10:02 PM   #25
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by pheoxs View Post
Even if you let the engine warm up for half an hour the transmission fluid is still cold and doesn't flow smoothly. This is why you're supposed to drive gently for a while even if your coolant/oil is at temp.
+1
I drive a Manual Impreza winter beater and have to let the car warm up first. Even when the motor is blazing hot, if the transmission oil is cold then the revs will be high and the shifting would feel a bit sluggish.
My 98 Honda Civic AT, however, does not suffer from this problem so it must be a Subaru thing???
LeeMaster is offline   Reply With Quote
Old 01-23-2013, 10:15 PM   #26
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Forgive my ignorance, but what is "WOT"?
Exhaust is offline   Reply With Quote
Old 01-23-2013, 10:40 PM   #27
Pooverdam
Pooverdam's Avatar
wide open throttle
Old 01-23-2013, 10:45 PM   #28
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Originally Posted by Pooverdam View Post
wide open throttle
How exactly do you achieve this? Accelerating while not under load?
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 10:32 AM
cold weather & remote starter jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 11-10-2012 07:03 AM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 12:42 PM
Pretty sure car hates the cold weather HuntingtonFRS Issues | Warranty | Recalls / TSB 28 10-21-2012 05:52 PM
